Running latest beta and this style is throwing some errors.
{"Rey","tracks/Rey.wav",
OS6.7 v4.014
Base Style: Hyper Responsive Rotoscope (Sequels)
Base Color: Rgb<255,97,0> (0)
PowerUp Effect: Rey TROS Spark
PostOff Effect: Emitter Glow (Emitter Size)
Lockup Effect: Responsive Lockup, Begin Effect: Real Clash, End Effect: Dissipate
Melt Effect: Intensity Melt
Stab Effect: Normal Stab
Blast Effect: Responsive Blast Wave (Sound Based)
Clash Effect: Real Clash V3
StylePtr<Layers<Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<14000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-4000>,Int<-400>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>,TransitionEffectL<TrConcat<TrJoin<TrDelay<200>,TrInstant>,AlphaL<Green,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-500>>>,TrFade<300>,AlphaL<DeepPink,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-500>>>,TrFade<500>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<180,130,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,MultiTransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<0,255,255>>,Scale<WavLen<>,Int<100>,Int<400>>,Int<100>,Scale<WavLen<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,AlphaL<TransitionEffectL<TrSelect<Scale<ClashImpactF<>,Int<0>,Int<4>>,TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<100,100,150>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<8000>,Int<12000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<100,100,150>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1500,-3000,RgbArg<CLASH_COLOR_ARG,Rgb<100,100,150>>,Mix<Int<16384>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<100,100,150>>>>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<100,100,150>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<100,100,150>>,TrFadeX<Scale<ClashImpactF<>,Int<300>,Int<500>>>>>,EFFECT_CLASH>,Scale<ClashImpactF<>,Int<24000>,Int<32768>>>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<100,100,150>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<100,100,150>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<100,100,150>>,TrFade<400>>,TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<100,100,150>>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,Rgb<100,100,150>>,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<100,100,150>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<100,100,150>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<100,100,150>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<100,100,150>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<55,255,169>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<55,255,169>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<White,Int<0>>,TrJoin<TrDelay<1000>,TrInstant>,AlphaL<RgbArg<POSTOFF_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-2000>>>,TrSmoothFadeX<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>>>,EFFECT_POSTOFF>>>(),
Arduino: 1.8.15 (Windows 10), Board: "Proffieboard V2, Serial + Mass Storage + WebUSB, SDCARD (SPI), 80 MHz, Smallest Code"
In file included from C:\Users\twbpo\Documents\ProffieOS-v6.7\ProffieOS\ProffieOS.ino:563:
C:\Users\twbpo\Documents\ProffieOS-v6.7\ProffieOS\config\Mini_brick.h:154:781: error: 'Purple' was not declared in this scope
154 | StylePtr<Layers<Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<14000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-4000>,Int<-400>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>,TransitionEffectL<TrConcat<TrJoin<TrDelay<200>,TrInstant>,AlphaL<Green,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-500>>>,TrFade<300>,AlphaL<Purple,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-500>>>,TrFade<500>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<180,130,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,MultiTransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<0,255,255>>,Scale<WavLen<>,Int<100>,Int<400>>,Int<100>,Scale<WavLen<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,AlphaL<TransitionEffectL<TrSelect<Scale<ClashImpactF<>,Int<0>,Int<4>>,TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<100,100,150>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<8000>,Int<12000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<100,100,150>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1500,-3000,RgbArg<CLASH_COLOR_ARG,Rgb<100,100,150>>,Mix<Int<16384>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<100,100,150>>>>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<100,100,150>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<100,100,150>>,TrFadeX<Scale<ClashImpactF<>,Int<300>,Int<500>>>>>,EFFECT_CLASH>,Scale<ClashImpactF<>,Int<24000>,Int<32768>>>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<100,100,150>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<100,100,150>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<100,100,150>>,TrFade<400>>,TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<100,100,150>>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,Rgb<100,100,150>>,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<100,100,150>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<100,100,150>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<100,100,150>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<100,100,150>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<55,255,169>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<55,255,169>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<White,Int<0>>,TrJoin<TrDelay<1000>,TrInstant>,AlphaL<RgbArg<POSTOFF_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-2000>>>,TrSmoothFadeX<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>>>,EFFECT_POSTOFF>>>(),
C:\Users\twbpo\Documents\ProffieOS-v6.7\ProffieOS\config\Mini_brick.h:154:839: error: template argument 1 is invalid
C:\Users\twbpo\Documents\ProffieOS-v6.7\ProffieOS\config\Mini_brick.h:154:851: error: template argument 4 is invalid
C:\Users\twbpo\Documents\ProffieOS-v6.7\ProffieOS\config\Mini_brick.h:154:869: error: template argument 1 is invalid
C:\Users\twbpo\Documents\ProffieOS-v6.7\ProffieOS\config\Mini_brick.h:154: error: template argument 2 is invalid
C:\Users\twbpo\Documents\ProffieOS-v6.7\ProffieOS\config\Mini_brick.h:154: error: no matching function for call to 'StylePtr<<expression error> >()'
In file included from C:\Users\twbpo\Documents\ProffieOS-v6.7\ProffieOS\styles\fire.h:4,
from C:\Users\twbpo\Documents\ProffieOS-v6.7\ProffieOS\ProffieOS.ino:426:
C:\Users\twbpo\Documents\ProffieOS-v6.7\ProffieOS\styles\style_ptr.h:93:16: note: candidate: 'template<class STYLE> StyleFactory* StylePtr()'
93 | StyleAllocator StylePtr() {
C:\Users\twbpo\Documents\ProffieOS-v6.7\ProffieOS\styles\style_ptr.h:93:16: note: template argument deduction/substitution failed:
C:\Users\twbpo\Documents\ProffieOS-v6.7\ProffieOS\config\Mini_brick.h:154: error: template argument 1 is invalid
