Hello, trying to change my prop file, and keep receiving error when uploading.
Arduino: 1.8.19 (Windows 10), Board: “Proffieboard V2, Serial + Mass Storage, SDCARD (SPI), 80 MHz, Smallest Code”
`In file included from E:\extra\ProffieOS\config\s3config.h:36,
from E:\extra\ProffieOS\ProffieOS.ino:575:
E:\extra\ProffieOS\props\saber_fett263_buttons.h:1180:3: error: ‘ALT_COLOR2_ARG’ was not declared in this scope; did you mean ‘ALT_COLOR_ARG’?
1180 | ALT_COLOR2_ARG,
| ALT_COLOR_ARG
E:\extra\ProffieOS\props\saber_fett263_buttons.h:1181:3: error: ‘ALT_COLOR3_ARG’ was not declared in this scope; did you mean ‘ALT_COLOR_ARG’?
1181 | ALT_COLOR3_ARG,
| ALT_COLOR_ARG
E:\extra\ProffieOS\props\saber_fett263_buttons.h:1200:3: error: ‘STYLE_OPTION2_ARG’ was not declared in this scope; did you mean ‘STYLE_OPTION_ARG’?
1200 | STYLE_OPTION2_ARG,
| STYLE_OPTION_ARG
E:\extra\ProffieOS\props\saber_fett263_buttons.h:1201:3: error: ‘STYLE_OPTION3_ARG’ was not declared in this scope; did you mean ‘STYLE_OPTION_ARG’?
1201 | STYLE_OPTION3_ARG,
| STYLE_OPTION_ARG
E:\extra\ProffieOS\props\saber_fett263_buttons.h:1203:3: error: ‘IGNITION_OPTION2_ARG’ was not declared in this scope; did you mean ‘IGNITION_OPTION_ARG’?
1203 | IGNITION_OPTION2_ARG,
| IGNITION_OPTION_ARG
E:\extra\ProffieOS\props\saber_fett263_buttons.h:1208:3: error: ‘RETRACTION_OPTION2_ARG’ was not declared in this scope; did you mean ‘RETRACTION_OPTION_ARG’?
1208 | RETRACTION_OPTION2_ARG,
E:\extra\ProffieOS\props\saber_fett263_buttons.h: In member function ‘void SaberFett263Buttons::SaveGestureState()’:
E:\extra\ProffieOS\props\saber_fett263_buttons.h:1241:27: error: ‘class GestureControlFile’ has no member named ‘WriteToRootDir’
1241 | saved_gesture_control.WriteToRootDir(“gesture”);
E:\extra\ProffieOS\props\saber_fett263_buttons.h: In member function ‘void SaberFett263Buttons::DoInteractivePreon()’:
E:\extra\ProffieOS\props\saber_fett263_buttons.h:1780:9: error: ‘CheckInteractivePreon’ was not declared in this scope; did you mean ‘DoInteractivePreon’?
1780 | if (CheckInteractivePreon()) {
| DoInteractivePreon
E:\extra\ProffieOS\props\saber_fett263_buttons.h:1781:27: error: ‘EFFECT_INTERACTIVE_PREON’ was not declared in this scope
1781 | SaberBase::DoEffect(EFFECT_INTERACTIVE_PREON, 0);
E:\extra\ProffieOS\props\saber_fett263_buttons.h: In member function ‘void SaberFett263Buttons::DoInteractiveBlast()’:
E:\extra\ProffieOS\props\saber_fett263_buttons.h:1790:9: error: ‘CheckInteractiveBlast’ was not declared in this scope; did you mean ‘DoInteractiveBlast’?
1790 | if (CheckInteractiveBlast()) {
| DoInteractiveBlast
E:\extra\ProffieOS\props\saber_fett263_buttons.h:1791:28: error: ‘EFFECT_INTERACTIVE_BLAST’ was not declared in this scope
1791 | SaberBase::DoEffectR(EFFECT_INTERACTIVE_BLAST);
E:\extra\ProffieOS\props\saber_fett263_buttons.h: In member function ‘void SaberFett263Buttons::ForceQuote()’:
E:\extra\ProffieOS\props\saber_fett263_buttons.h:4727:27: error: ‘EFFECT_QUOTE’ was not declared in this scope; did you mean ‘EFFECT_MODE’?
4727 | SaberBase::DoEffect(EFFECT_QUOTE, 0);
| EFFECT_MODE
E:\extra\ProffieOS\props\saber_fett263_buttons.h: In member function ‘void SaberFett263Buttons::DoBattery()’:
E:\extra\ProffieOS\props\saber_fett263_buttons.h:4742:20: error: ‘class SoundLibrary’ has no member named ‘SayBatteryPercent’; did you mean ‘SayBatteryLevel’?
4742 | sound_library_.SayBatteryPercent();
| SayBatteryLevel
E:\extra\ProffieOS\props\saber_fett263_buttons.h: In member function ‘void SaberFett263Buttons::ChangeVolume(int)’:
E:\extra\ProffieOS\props\saber_fett263_buttons.h:4791:25: error: ‘EFFECT_VOLUME_LEVEL’ was not declared in this scope
4791 | SaberBase::DoEffect(EFFECT_VOLUME_LEVEL, 0);
E:\extra\ProffieOS\props\saber_fett263_buttons.h: In member function ‘virtual bool SaberFett263Buttons::Event2(BUTTON, EVENT, uint32_t)’:
E:\extra\ProffieOS\props\saber_fett263_buttons.h:5671:31: error: ‘EFFECT_USER7’ was not declared in this scope; did you mean ‘EFFECT_USER5’?
5671 | SaberBase::DoEffect(EFFECT_USER7, 0);
| EFFECT_USER5
E:\extra\ProffieOS\props\saber_fett263_buttons.h:5679:31: error: ‘EFFECT_USER8’ was not declared in this scope; did you mean ‘EFFECT_USER5’?
5679 | SaberBase::DoEffect(EFFECT_USER8, 0);
| EFFECT_USER5
E:\extra\ProffieOS\props\saber_fett263_buttons.h:5961:31: error: ‘EFFECT_USER6’ was not declared in this scope; did you mean ‘EFFECT_USER5’?
5961 | SaberBase::DoEffect(EFFECT_USER6, 0);
| EFFECT_USER5
E:\extra\ProffieOS\props\saber_fett263_buttons.h:5970:30: error: ‘EFFECT_OFF_CLASH’ was not declared in this scope; did you mean ‘EFFECT_CLASH’?
5970 | SaberBase::DoEffectR(EFFECT_OFF_CLASH);
| EFFECT_CLASH
E:\extra\ProffieOS\props\saber_fett263_buttons.h: In member function ‘virtual void SaberFett263Buttons::SB_Effect(EffectType, float)’:
E:\extra\ProffieOS\props\saber_fett263_buttons.h:6317:12: error: ‘EFFECT_INTERACTIVE_BLAST’ was not declared in this scope
6317 | case EFFECT_INTERACTIVE_BLAST: hybrid_font.PlayCommon(&SFX_blast); return;
E:\extra\ProffieOS\props\saber_fett263_buttons.h:6318:12: error: ‘EFFECT_TRACK’ was not declared in this scope; did you mean ‘EDIT_TRACK’?
6318 | case EFFECT_TRACK: PlayEffectTrack(); return;
| EDIT_TRACK
E:\extra\ProffieOS\props\saber_fett263_buttons.h:6319:12: error: ‘EFFECT_QUOTE’ was not declared in this scope; did you mean ‘EFFECT_MODE’?
6319 | case EFFECT_QUOTE: hybrid_font.PlayCommon(&SFX_quote); return;
| EFFECT_MODE
E:\extra\ProffieOS\props\saber_fett263_buttons.h:6320:12: error: ‘EFFECT_NEXT_QUOTE’ was not declared in this scope
6320 | case EFFECT_NEXT_QUOTE:
E:\extra\ProffieOS\props\saber_fett263_buttons.h:6324:12: error: ‘EFFECT_FAST_OFF’ was not declared in this scope; did you mean ‘EFFECT_FAST_ON’?
6324 | case EFFECT_FAST_OFF:
| EFFECT_FAST_ON
E:\extra\ProffieOS\props\saber_fett263_buttons.h:6325:12: error: ‘EFFECT_OFF’ was not declared in this scope; did you mean ‘EFFECT_JAM’?
6325 | case EFFECT_OFF:
| EFFECT_JAM
E:\extra\ProffieOS\props\saber_fett263_buttons.h:6331:17: error: ‘OFF_FAST’ was not declared in this scope; did you mean ‘OFF_BLAST’?
6331 | Off(OFF_FAST);
| OFF_BLAST
E:\extra\ProffieOS\props\saber_fett263_buttons.h:6338:12: error: ‘EFFECT_SECONDARY_RETRACTION’ was not declared in this scope
6338 | case EFFECT_SECONDARY_RETRACTION:
E:\extra\ProffieOS\props\saber_fett263_buttons.h:6356:12: error: ‘EFFECT_INTERACTIVE_PREON’ was not declared in this scope
6356 | case EFFECT_INTERACTIVE_PREON:
E:\extra\ProffieOS\props\saber_fett263_buttons.h:6372:12: error: ‘EFFECT_ON’ was not declared in this scope; did you mean ‘EFFECT_NONE’?
6372 | case EFFECT_ON:
| EFFECT_NONE
E:\extra\ProffieOS\props\saber_fett263_buttons.h:6380:12: error: ‘EFFECT_SECONDARY_IGNITION’ was not declared in this scope
6380 | case EFFECT_SECONDARY_IGNITION:
E:\extra\ProffieOS\props\saber_fett263_buttons.h:6388:12: error: ‘EFFECT_TRANSITION_SOUND’ was not declared in this scope
6388 | case EFFECT_TRANSITION_SOUND: hybrid_font.PlayCommon(&SFX_tr); return;
E:\extra\ProffieOS\props\saber_fett263_buttons.h:6389:12: error: ‘EFFECT_SOUND_LOOP’ was not declared in this scope
6389 | case EFFECT_SOUND_LOOP: SoundLoop(); return;
E:\extra\ProffieOS\props\saber_fett263_buttons.h:6390:12: error: ‘EFFECT_BEGIN_BATTLE_MODE’ was not declared in this scope
6390 | case EFFECT_BEGIN_BATTLE_MODE:
E:\extra\ProffieOS\props\saber_fett263_buttons.h:6393:12: error: ‘EFFECT_END_BATTLE_MODE’ was not declared in this scope
6393 | case EFFECT_END_BATTLE_MODE:
E:\extra\ProffieOS\props\saber_fett263_buttons.h:6396:12: error: ‘EFFECT_BEGIN_AUTO_BLAST’ was not declared in this scope
6396 | case EFFECT_BEGIN_AUTO_BLAST:
E:\extra\ProffieOS\props\saber_fett263_buttons.h:6399:12: error: ‘EFFECT_END_AUTO_BLAST’ was not declared in this scope
6399 | case EFFECT_END_AUTO_BLAST:
exit status 1 `
