@Streen which hilt and what setup, lit button, etc? See the two other replies after this for example configs.
@ryryog25 Sabertrio’s stock configs work fine with standard OS, you just need to undefine their prop file (put two // in front of it) and define Fett263’s prop (remove the two // in the front of that line). *You do need to setup for blade detect and the OLED screen if equipped is all. The two config examples after this show the basics for that.
For example their new Power Core Krosgaard config titled s3config_PowerCore_Kros.h compiles fine at 80% once you switch the prop selection. The only thing still is the BladeDetect component of this.
// ProffieOS7 Config File
#define NUM_BLADES 3
#define VOLUME 2550
#define CLASH_THRESHOLD_G 4.5
#define AUDIO_CLASH_SUPPRESSION_LEVEL 5
#define KILL_OLD_PLAYERS
#define FILTER_ORDER 8
#define BLADE_DETECT_PIN 17
#define SAVE_PRESET
#define FETT263_ENABLE_SPIN_MODE
#define FETT263_BM_CLASH_DETECT 8
#define FETT263_FORCE_PUSH
#define FETT263_TWIST_ON
//#define KEEP_SAVEFILES_WHEN_PROGRAMMING
#define FETT263_DISABLE_MULTI_BLAST
#define FETT263_DISABLE_MULTI_BLAST_TOGGLE
//#include "../props/saber_sabertrio_buttons.h"
Preset blade[] = {
{ "1-SABERTRIO;common", "tracks/track_1.wav",
/* copyright Fett263 Simple (Primary Blade) OS6 Style
https://fett263.com/fett263-proffieOS6-style-library.html#Simple
OS6.7 v4.021
Base Style: HumpFlicker Small (Single Color (80%)), DodgerBlue, Animated(Moccasin)
Base Color: Rgb<2,72,255> (0)
Melt Effect: Responsive Melt
Blast Effect: Responsive Blast Fade (Large)
Clash Effect: Flash on Clash (Full Blade)
StylePtr<Layers<
HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>,Mix<Int<26214>,Black,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>>,60>,
TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,
TransitionEffectL<TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Int<14000>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,199,119>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,199,119>>>>,TrFade<300>>,EFFECT_BLAST>,
TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<CLASH_COLOR_ARG,Rgb<255,199,119>>,TrFade<300>>,EFFECT_CLASH>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>,TrFade<400>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<191,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<191,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<191,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<191,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,
LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,30000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,30000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
LockupTrL<AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<4000>>>,TrFade<300>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>,
TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrExtend<2000,TrWipe<0>>,AlphaL<Mix<VolumeLevel,Red,Green>,SmoothStep<VolumeLevel,Int<-10>>>,TrSmoothFade<300>>,EFFECT_VOLUME_LEVEL>>>(),
/* copyright Fett263 Simple (Accent LED / PCB) OS6 Style
OS6.7 v4.021
Base Style: HumpFlicker Large (Single Color (50%))
Off Behavior: Fast Pulse Off-On
Retraction Effect: Instant
StylePtr<Layers<HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>>,120>,InOutTrL<TrWipeX<IgnitionTime<0>>,TrInstant,Pulsing<Black,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>,2000>>>>(),
/* copyright Fett263 Simple (Quillion / Secondary Blade) OS6 Style
OS6.6 v3.01
Base Style: RandomFlicker (Single Color (50%)), DodgerBlue, Animated(Moccasin)
LightningBlock Effect: Responsive Lighting Block (LightCyan)
StylePtr<Layers<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>>>,ResponsiveLightningBlockL<LightCyan>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>>>(),
"Sabertrio"
{ "2-DARK_EDITION;common", "tracks/track_2.wav",
OS6.7 v4.021
Base Style: HumpFlicker Large (Single Color (80%)), Red, Animated (Moccasin)
Base Color: Rgb<255,0,0> (0)
StylePtr<Layers<
HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<26214>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,120>,
TransitionEffectL<TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Int<14000>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<300>>,EFFECT_BLAST>,
LockupTrL<AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<4000>>>,TrFade<300>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>,
OS6.7 v4.021
StylePtr<Layers<HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,120>,InOutTrL<TrWipeX<IgnitionTime<0>>,TrInstant,Pulsing<Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,2000>>>>(),
OS6.6 v3.01
Base Style: RandomFlicker (Single Color (50%)), Red, Animated (Moccasin)
StylePtr<Layers<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,ResponsiveLightningBlockL<LightCyan>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>>>(),
"Dark Edition"
{ "3-THE_LIGHT;common","tracks/track_3.wav",
OS6.7 v4.021
Base Style: HumpFlicker Small (Single Color (80%)), DeepSkyBlue, Original (LemonChiffon)
Base Color: Rgb<0,135,255> (0)
StylePtr<Layers<
HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<26214>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,60>,
TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,244,157>>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,
TransitionEffectL<TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Int<14000>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>>>,TrFade<300>>,EFFECT_BLAST>,
TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<CLASH_COLOR_ARG,Rgb<255,244,157>>,TrFade<300>>,EFFECT_CLASH>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,244,157>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,30000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,244,157>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,30000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
OS6.7 v4.021
StylePtr<Layers<HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,120>,InOutTrL<TrWipeX<IgnitionTime<0>>,TrInstant,Pulsing<Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,2000>>>>(),
OS6.6 v3.01
Base Style: RandomFlicker (Single Color (50%), DeepSkyBlue, Original (LemonChiffon)
StylePtr<Layers<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,ResponsiveLightningBlockL<LightCyan>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>>>(),
"The Light"
{ "4-THE_BALANCE;common","tracks/track_4.wav",
OS6.7 v4.021
Base Style: HumpFlicker Small (Single Color (80%)), Green, Prequel (NavajoWhite)
Base Color: Rgb<0,255,0> (0)
StylePtr<Layers<
HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<26214>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,60>,
TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,187,108>>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,
TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<CLASH_COLOR_ARG,Rgb<255,187,108>>,TrFade<300>>,EFFECT_CLASH>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,187,108>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,30000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,187,108>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,30000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
OS6.7 v4.021
StylePtr<Layers<HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,120>,InOutTrL<TrWipeX<IgnitionTime<0>>,TrInstant,Pulsing<Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,2000>>>>(),
OS6.6 v3.01
Base Style: RandomFlicker (Single Color (50%)), Green, Prequel(NavajoWhite)
StylePtr<Layers<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,ResponsiveLightningBlockL<LightCyan>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>>>(),
"The Balance"
{ "5-THE_DARK;common","tracks/track_5.wav",
OS6.7 v4.021
Base Style: HumpFlicker Small (Single Color (80%)), Red, Orignal (LemonChiffon)
StylePtr<Layers<
HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<26214>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,60>,
TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<191,255,255>>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,
TransitionEffectL<TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Int<14000>>,RgbArg<BLAST_COLOR_ARG,Rgb<191,255,255>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<191,255,255>>>>,TrFade<300>>,EFFECT_BLAST>,
TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<CLASH_COLOR_ARG,Rgb<191,255,255>>,TrFade<300>>,EFFECT_CLASH>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<191,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,30000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<191,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,30000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
OS6.7 v4.021
OS6.6 v3.01
Base Style: RandomFlicker (Single Color (50%)), Red, Orignal (LemonChiffon)
"The Dark"
{ "6-VENGEANCE;common","tracks/track_6.wav",
OS6.7 v4.021
Base Style: HumpFlicker Small (Single Color (80%)), Red, Animated (Moccasin)
StylePtr<Layers<
TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<CLASH_COLOR_ARG,Rgb<255,187,108>>,TrFade<300>>,EFFECT_CLASH>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,TrFade<400>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
OS6.7 v4.021
OS6.6 v3.01
"Vengence"
{ "7-KROSSGUARD;common", "tracks/track_7.wav",
/* copyright Fett263 KyloRen (Primary Blade) OS6 Style
https://fett263.com/fett263-proffieOS6-style-library.html#KyloRen
OS6.6 v3.01
Base Style: Kylo Ren Unstable (Film Based), Red, Sequel (LightCyan)
Lockup Effect: Responsive Lockup (Absorb)
Melt Effect: Intensity Melt
Blast Effect (Randomly Selected): Responsive Blast Fade (Medium), Responsive Blast Fade (Sound Based)
StylePtr<Layers<
StaticFire<BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RandomPerLEDFlicker<Mix<Int<3213>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,300>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,0,6,10,1000,2>,
TransitionEffectL<TrConcat<TrExtendX<WavLen<>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<191,255,255>>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,MultiTransitionEffectL<TrRandom<TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Int<10000>>,RgbArg<BLAST_COLOR_ARG,Rgb<191,255,255>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<191,255,255>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<000>>,Scale<WavLen<>,Int<9000>,Int<13000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<191,255,255>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<191,255,255>>>>,TrFade<300>>>,EFFECT_BLAST>,
TransitionEffectL<TrConcat<TrExtend<30,TrInstant>,RgbArg<CLASH_COLOR_ARG,Rgb<191,255,255>>,TrFade<300>>,EFFECT_CLASH>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>,TrFade<400>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<191,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,30000>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<191,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,30000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<4000>>>,TrExtend<4000,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
InOutTrL<TrWipeX<IgnitionTime<250>>,TrWipeInX<RetractionTime<0>>,Black>,
/* copyright Fett263 KyloRen (Accent LED / PCB) OS6 Style
OS6.7 v4.021
StylePtr<Layers<StaticFire<BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RandomPerLEDFlicker<Mix<Int<3213>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,300>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,0,6,10,1000,2>,InOutTrL<TrWipeX<IgnitionTime<0>>,TrInstant,Pulsing<Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,2000>>>>(),
/* copyright Fett263 KyloRen (Quillion / Secondary Blade) OS6 Style
OS6.6 v3.01
Ignition Delay: Standard Delay
StylePtr<IgnitionDelayX<Int<370>,Layers<StaticFire<BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RandomPerLEDFlicker<Mix<Int<3213>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<7710>,
Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,300>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,0,6,10,1000,2>,ResponsiveLightningBlockL<LightCyan>,InOutTrL<TrWipeX<IgnitionTime<150>>,TrWipeInX<RetractionTime<800>>,Black>>>>(),
"Krossguard"
{ "8-SNIPPETS;common", "tracks/track_8.wav",
OS6.7 v4.021
Base Style: HumpFlicker Small (Single Color (80%)), Silver, Animated (Moccasin)
Base Color: Rgb<100,100,150> (0)
StylePtr<Layers<
HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,Mix<Int<26214>,Black,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>,60>,
TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,199,119>>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,
LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,199,119>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,30000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,199,119>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,30000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
LockupTrL<AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<4000>>>,TrFade<300>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>,
OS6.7 v4.021
StylePtr<Layers<HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>,120>,InOutTrL<TrWipeX<IgnitionTime<0>>,TrInstant,Pulsing<Black,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,2000>>>>(),
OS6.6 v3.01
Base Style: AudioFlicker (Single Color (50%)), Silver, Animated (Moccasin)
LightningBlock Effect: Full Blade Lightning
StylePtr<Layers<AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>,ResponsiveLightningBlockL<LightCyan>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>>>(),
"Snippets"
{ "9-MENACE;common", "tracks/track_9.wav",
OS6.7 v4.021
Base Style: HumpFlicker Small (Single Color (80%)), Red, Prequel (NavajoWhite)
StylePtr<Layers<
OS6.7 v4.021
OS6.6 v3.01
Base Style: RandomFlicker (Single Color (50%)), Red, Prequel (NavajoWhite)
"Menace"
{ "10-TEMPLE_GUARDIAN;common", "tracks/track_10.wav",
OS6.7 v4.021
Base Style: HumpFlicker Small (Single Color (80%)), Gold, Animated (Moccasin)
Base Color: Rgb<180,130,0> (0)
StylePtr<Layers<
HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>,Mix<Int<26214>,Black,RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>>,60>,
OS6.7 v4.021
StylePtr<Layers<HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>>,120>,InOutTrL<TrWipeX<IgnitionTime<0>>,TrInstant,Pulsing<Black,RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>,2000>>>>(),
OS6.6 v3.01
Base Style: RandomFlicker (Single Color (50%)), Gold, Animated (Moccasin)
StylePtr<Layers<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>>>,ResponsiveLightningBlockL<LightCyan>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>>>(),
"Temple Guardian"
{ "11-SHOCK_BATON;common", "tracks/track_11.wav",
/* copyright Fett263 EnergyWeapon (Primary Blade) OS6 Style
https://fett263.com/fett263-proffieOS6-style-library.html#EnergyWeapon
OS6.6 v3.01
Base Style: Shock Baton (DodgerBlue, White)
Preon Effect: Polar Spark (PreOn Color)
Ignition Effect: Center In
PowerUp Effect: Power Surge (Unstable V2)
Retraction Effect: Center In
Blast Effect (Randomly Selected): Responsive Blast Wave (Random), Responsive Blast Wave (Medium)
Ignition Time: 200
StylePtr<Layers<
BrownNoiseFlicker<BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>,Black,300>,Stripes<3000,-4000,Rgb<50,50,75>,Rgb<100,100,150>,Rgb<10,10,15>,Rgb<150,150,225>>,200>,
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,40>,TrFade<1200>>,EFFECT_IGNITION>,
MultiTransitionEffectL<TrRandom<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>,TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Int<200>,Int<200>,Int<400>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>>,EFFECT_BLAST>,
TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFade<300>>,EFFECT_CLASH>,
LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
InOutTrL<TrCenterWipeInX<IgnitionTime<200>,Int<16384>>,TrCenterWipeInX<RetractionTime<0>,Int<16384>>,Black>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlicker<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,Rgb<100,100,150>,300>,LayerFunctions<SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>,SmoothStep<Int<30768>,Int<4000>>>>,TrDelayX<WavLen<>>>,EFFECT_PREON>,
/* copyright Fett263 EnergyWeapon (Accent LED / PCB) OS6 Style
OS6.7 v4.021
StylePtr<Layers<BrownNoiseFlicker<BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>,Black,300>,Stripes<3000,-4000,Rgb<50,50,75>,Rgb<100,100,150>,Rgb<10,10,15>,Rgb<150,150,225>>,200>,InOutTrL<TrWipeX<IgnitionTime<0>>,TrInstant,Pulsing<Black,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>,2000>>>>(),
/* copyright Fett263 EnergyWeapon (Quillion / Secondary Blade) OS6 Style
OS6.6 v3.021
StylePtr<Layers<BrownNoiseFlicker<BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,DodgerBlue>,Black,300>,Stripes<3000,-4000,Rgb<50,50,75>,Rgb<100,100,150>,Rgb<10,10,15>,Rgb<150,150,225>>,200>,
InOutTrL<TrCenterWipeInX<IgnitionTime<>>,TrCenterWipeInX<RetractionTime<>>>,ResponsiveLightningBlockL<LightCyan>,TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlicker<RgbArg<PREON_COLOR_ARG,White>,
Rgb<100,100,150>,300>,LayerFunctions<SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>,SmoothStep<Int<30768>,Int<4000>>>>,TrDelayX<WavLen<>>>,EFFECT_PREON>>>(),
"Shock Baton"
{ "12-THE_TRAGEDY;common", "tracks/track_12.wav",
OS6.6 v3.01
Base Style: AudioFlicker (Single Color (75%)), Red, Prequel (NavajoWhite)
PowerUp Effect: Power Surge (Unstable V1)
CoolDown Effect: Unstable Cool Down Forward
StylePtr<Layers<
AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<24576>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,200>,RandomPerLEDFlicker<Mix<Int<16384>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>>,TrFade<1200>>,EFFECT_IGNITION>,
TransitionEffectL<TrConcat<TrExtendX<RetractionTime<0>,TrInstant>,Stripes<3000,-3500,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,0,0>>>,Black>,BrownNoiseFlicker<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,0,0>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,0,0>>>>>,TrFade<800>>,EFFECT_RETRACTION>,
TransitionEffectL<TrConcat<TrExtendX<WavLen<>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,187,108>>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,
MultiTransitionEffectL<TrRandom<TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Int<10000>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<000>>,Scale<WavLen<>,Int<9000>,Int<13000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>>>,TrFade<300>>>,EFFECT_BLAST>,
TransitionEffectL<TrConcat<TrExtend<30,TrInstant>,RgbArg<CLASH_COLOR_ARG,Rgb<255,187,108>>,TrFade<300>>,EFFECT_CLASH>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,TrFade<400>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,187,108>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,30000>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,187,108>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,30000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
TransitionEffectL<TrConcat<TrExtend<2000,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>,
OS6.7 v4.021
OS6.6 v3.01
StylePtr<Layers<AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<24576>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,
RandomPerLEDFlicker<Mix<Int<16384>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>>,TrFade<1200>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrExtendX<RetractionTime<0>,TrInstant>,
"The Tragedy"
{ "13-TEENSY_SF;common", "tracks/track_13.wav",
OS6.7 v4.021
Base Style: HumpFlicker Small (Single Color (80%)), Cyan, Prequel (NavajoWhite)
Base Color: Rgb<0,255,255> (0)
StylePtr<Layers<
HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,255,255>>,Mix<Int<26214>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,255>>>,60>,
TransitionEffectL<TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Int<14000>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,244,157>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,244,157>>>>,TrFade<300>>,EFFECT_BLAST>,
TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<CLASH_COLOR_ARG,Rgb<255,244,157>>,TrFade<300>>,EFFECT_CLASH>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>,TrFade<400>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
OS6.7 v4.021
StylePtr<Layers<HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,255,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,255>>>,120>,InOutTrL<TrWipeX<IgnitionTime<0>>,TrInstant,Pulsing<Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,255>>,2000>>>>(),
OS6.6 v3.01
Base Style: RandomFlicker (Single Color (50%)), Cyan, Prequel (NavajoWhite)
StylePtr<Layers<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,255,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,255>>>>,ResponsiveLightningBlockL<LightCyan>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>>>(),
"TeensySF"
{ "14-SMOOTH_JEDI;common", "tracks/track_14.wav",
OS6.7 v4.021
Base Style: HumpFlicker Small (Single Color (80%)), Blue, Original (LemonChiffon)
Base Color: Rgb<0,0,255> (0)
StylePtr<Layers<
HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<26214>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,60>,
OS6.7 v4.021
StylePtr<Layers<HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,120>,InOutTrL<TrWipeX<IgnitionTime<0>>,TrInstant,Pulsing<Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,2000>>>>(),
OS6.6 v3.01
Base Style: RandomFlicker (Single Color (50%)), Blue, Original (LemonChiffon)
StylePtr<Layers<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,ResponsiveLightningBlockL<LightCyan>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>>>(),
"Smooth Jedi"
{ "15-SMOOTH_GREY;common", "tracks/track_15.wav",
OS6.6 v3.01
Base Style: AudioFlicker (Single Color (75%)), Gold, Sequel (LightCyan)
StylePtr<Layers<
AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>,Mix<Int<24576>,Black,RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>>>,
OS6.7 v4.021
OS6.6 v3.01
StylePtr<Layers<AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>,Mix<Int<24576>,Black,RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>>>,ResponsiveLightningBlockL<LightCyan>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>>>(),
"Smooth Grey"
{ "16-SMOOTH_FUZZ;common", "tracks/track_16.wav",
OS6.7 v4.021
Base Style: HumpFlicker Small (Single Color (80%)),Purple, Prequel(NavajoWhite)
Base Color: Rgb<115,15,240> (0)
StylePtr<Layers<
HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>,Mix<Int<26214>,Black,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>>,60>,
InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<300>>,TrWipeInX<RetractionTime<800>>,Black>,
OS6.7 v4.021
StylePtr<Layers<HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>>,120>,InOutTrL<TrWipeX<IgnitionTime<0>>,TrInstant,Pulsing<Black,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>,2000>>>>(),
OS6.6 v3.01
Base Style: RandomFlicker (Single Color (50%)), Purple, Prequel(NavajoWhite)
StylePtr<Layers<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>>>,ResponsiveLightningBlockL<LightCyan>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<800>>,Black>>>(),
"Smooth Fuzz"
{ "17-ROGUE_COMMANDER;common", "tracks/track_17.wav",
OS6.6 v3.01
Base Style: Fallen Order Ninth Sister, Red, Orignal (LemonChiffon)
Blast Effect (Randomly Selected): Responsive Blast Fade (Random), Responsive Blast Fade (Large)
RetractionTime : 800
StylePtr<Layers<
Stripes<18000,-1600,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,
Stripes<9000,-900,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>>>,
TransitionEffectL<TrConcat<TrExtendX<WavLen<>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,244,157>>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,
MultiTransitionEffectL<TrRandom<TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<9000>,Int<13000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,244,157>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,244,157>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Int<14000>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,244,157>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,244,157>>>>,TrFade<300>>>,EFFECT_BLAST>,
TransitionEffectL<TrConcat<TrExtend<30,TrInstant>,RgbArg<CLASH_COLOR_ARG,Rgb<255,244,157>>,TrFade<300>>,EFFECT_CLASH>,
LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,244,157>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,30000>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,244,157>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,30000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<4000>>>,TrExtend<4000,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<800>>,Black>,
OS6.7 v4.021
/* copyright Fett263 FallenOrder (Quillion / Secondary Blade) OS6 Style
OS6.6 v3.01
StylePtr<Layers<Stripes<18000,-1600,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,
Stripes<9000,-900,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>>>,ResponsiveLightningBlockL<LightCyan>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<800>>,Black>>>(),
"Rogue Commander"
{ "18-TYTHONIAN_CRYSTAL;common", "tracks/track_18.wav",
OS6.7 v4.021
Base Style: HumpFlicker Small (Single Color (80%)), Green, Original (LemonChiffon)
StylePtr<Layers<
OS6.7 v4.021
OS6.6 v3.01
Base Style: RandomFlicker (Single Color (50%)), Green, Original (LemonChiffon)
StylePtr<Layers<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,ResponsiveLightningBlockL<LightCyan>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<800>>,Black>>>(),
"Tythonian Crystal"
{ 0,
WS281XBladePtr<133, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
SubBlade(0, 0, WS281XBladePtr<20, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin4,bladePowerPin5, bladePowerPin1> >()),
SubBlade(1,19, NULL),
CONFIGARRAY(blade)
