I’m a first timer using a Proffieboard to replace the board in a Xenopixel I purchased from SaberForge. So far, the wiring job seems to be successful. Blade, illuminated button (just 1 for now), speaker, SD card, all seem fine. The problem I’m experiencing is that whenever I try to go into the edit menu (double press and hold power) I hear it say “Error in font directory”. I’ve looked through the forum posts and followed the instructions to the best of my ability but haven’t been able to find a solution yet.
I’m currently just starting with the basic free fonts provided at hubbe.net to get things going and tested.
I’m running ProffieOS v7.14 on a Proffieboard v3.9.
I’ve copied the voice files from English voice pack C (also tried A) into a folder named “common” in the SD card’s root directory.
My config file currently reads as follows:
// ProffieOS7 Config File
#define NUM_BUTTONS 1
#define EXTRA_COLOR_BUFFER_SPACE 75
#define VOLUME 1500
#define CLASH_THRESHOLD_G 3.0
#define AUDIO_CLASH_SUPPRESSION_LEVEL 10
#define PROFFIEOS_ACCELEROMETER_RANGE 16
#define PROFFIEOS_MOTION_FREQUENCY 1600
#define KILL_OLD_PLAYERS
#define PROFFIEOS_LOG_LEVEL 1000
#define SAVE_PRESET
#define FETT263_MAX_CLASH 16
#define FETT263_MULTI_PHASE
#define FETT263_USE_BC_MELT_STAB
#define FETT263_SWING_ON_PREON
#define FETT263_THRUST_ON_PREON
#define FETT263_STAB_ON_PREON
#define FETT263_STAB_ON_NO_BM
StyleFirePtr<RED, YELLOW>(), "fire"},
StyleFirePtr<BLUE, CYAN>(), "blue fire"},
{ "SmthGrey", "tracks/venus.wav",
{ "SmthFuzz", "tracks/mars.wav",
{ "RgueCmdr", "tracks/mercury.wav",
{ "TthCrstl", "tracks/uranus.wav",
&style_pov, "POV"},
/* Generated with Fett263 Config Helper v3.10 */
The result of the serial command “effects” is as follows:
Found swingh files: 1-8 using 2 digits in TeensySF
Found swingl files: 1-8 using 2 digits in TeensySF
Found swng files: 1-16 using 2 digits in TeensySF
Found lock files: 1-1 using 2 digits in TeensySF
Found out files: 1-5 using 2 digits in TeensySF
Found in files: 1-2 using 2 digits in TeensySF
Found clsh files: 1-16 using 2 digits in TeensySF
Found blst files: 1-4 using 2 digits in TeensySF
Found font files: one unnumbered file in TeensySF
Found force files: 1-1 using 2 digits in TeensySF
Found hum files: 1-1 using 2 digits in TeensySF
Found boot files: one unnumbered file in TeensySF
Done listing effects.
The serial monitor says “Edit Mode prompts missing” whenever I double click and hold the power button.
Any help would be deeply appreciated. Very eager to get this saber working properly!
