Error downloading from https://profezzorn.github.io
Hi everyone!
It’s been a while since I haven’t been here. My sabers, proffieboards, arduino and proffie OS have been working great for a long time. Today, I got a problem, unfortunately.
“Error downloading https://profezzorn.github.io/arduino-proffieboard/package_proffieboard_index.json
I get it right after launching Arduino. Is the site under maintenance or something like that?
Even the Proffieboard can’t be found in Arduino Boards Manager. Right now, I can only select non Proffieboards.
I have old versions:
Arduino 1.8.3
ProffieOS 7.14
And, I use Linux Mint 20.3 as my laptop’s OS.
As I said, everything was working fine until now. Actually, I compiled a file last weekend without any issues. Any tip or recommendation is welcome.
Cheers.
The index downloads fine. Was that the exact error Arduino gave? Was there more error info in the log output (black box w/ red or white text, usually)
Arduino tries to check the index file for updates every time you start arduino.
If you alredy have the arduino-proffieboard plugin installed, it should still work, regardless of whether the update check succeeds or not.
I suspect this is just a network weather sort of things and things will be back to normal soon, but if not, please let me know.
Hi guys,
Thanks for commenting. I will answer your questions and comments.
The exact error I get from Arduino is:
That’s in the black box. The font color is orange.
I also want to suspect it’s just a network error, but I just tried it again, and I get the same error. Plus, If I ping the website “profezzorn.github.io”, I get a proper response:
PING profezzorn.github.io (185.199.111.153) 56(84) bytes of data.
64 bytes from cdn-185-199-111-153.github.com (185.199.111.153): icmp_seq=1 ttl=56 time=12.1 ms
64 bytes from cdn-185-199-111-153.github.com (185.199.111.153): icmp_seq=2 ttl=56 time=12.3 ms
64 bytes from cdn-185-199-111-153.github.com (185.199.111.153): icmp_seq=3 ttl=56 time=105 ms
Right now, Arduino is missing the Proffieboards. I’ve tried to search for the Proffieboards in Boards Manager to no avail. The “Error downloading” I get is posted every time I launch the Board Manager to try to search for the Proffieboards.
The only updates I got from Linux in the last week were for Google Chrome. Hence, I don’t know what it can be happening.
And, I checked that the link has not disappeared from the “Additional Board Manager URLs” in File>Preferences. It’s there.
This file downloads just fine for me, at least in a browser. (Haven’t tried it in arduino.)
Have you tried this in a browser?
If it downloads in a browser, but not in Arduino, maybe you should try a newer version of Arduino?
(1.8.3 is ancient.)
Hi profezzorn,
I tried it in a browser, and I get to see the JSON/Raw Data/Header tabs. There’s no file download for me.
I can try installing a new Arduino version. Which one do you recommend?
Cheers.
If you can see it, it already downloaded it.
Generally speaking, the latest one.
For linux, I would go with the AppImage
Ok. I will do that. I’ll have a hectic next couple of weeks, though. I’ll report when I have a chance.
I really appreciate the fact you commented on my post despite me not being a regular here.
Hi!
I downloaded the latest Arduino IDE: version 2.3.8. It was the AppImage as you suggested. I configured it, I didn’t have any link problem, and I successfully programmed one of my Proffie V3 boards :slight_smile:
Thanks for support and suggestion :pray:
