Hey,
so i’m trying to compile for the first time a config / script for a Proffieboard 3.9.
This is my config:
// ProffieOS7 Config File
#define VOLUME 1800
#define CLASH_THRESHOLD_G 3.0
#define SAVE_VOLUME
#define SAVE_COLOR_CHANGE
#define SAVE_PRESET
#define FETT263_TWIST_ON
{ "ANI3;common", "ANI3/tracks/track1.wav",
/* copyright Fett263 Simple (Primary Blade) OS7 Style
https://www.fett263.com/fett263-proffieOS7-style-library.html#Simple
OS7.14 v3.01p
Multi Phase (Original - Color Change) Transition: Fade, Time: 1000
Default: Hyper Responsive Rotoscope (Original Trilogy) [BaseColorArg]
1: Unstable Rage [AltColorArg]
Base Color: BaseColorArg (0)
Lockup Effect:
[Color: LockupColorArg]
Lightning Block Effect:
[Color: LBColorArg]
Drag Effect:
[Color: DragColorArg]
Melt Effect:
[Color: StabColorArg]
Stab Effect: AudioFlicker Stab [Color: StabColorArg]
Blast Effect: Blast Fade (Random) [Color: BlastColorArg]
Swing Effect: Force Rage Unstable [Color: SwingColorArg]
StylePtr<Layers<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,10,245>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,10,245>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelay<3000>,TrFade<300>>,StripesX<Int<3500>,Scale<SlowNoise<Int<3000>>,Int<-2500>,Int<-3500>>,RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>>,RandomPerLEDFlicker<Mix<Int<2570>,Black,RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<300>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<MELT_SIZE_ARG,31084>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrConcat<TrInstant,AlphaMixL<Bump<EffectPosition<EFFECT_BLAST>,Scale<EffectPosition<EFFECT_BLAST>,Int<9000>,Int<12000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<300>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,31084>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,31084>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<200>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<300>>,EFFECT_BATTERY_LEVEL>>>(),
"AudioFlickerBlue"
{ "DV3;common", "DV3/tracks/track1.wav",
OS7.14 v3.01p
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
StylePtr<Layers<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelay<3000>,TrFade<300>>,StripesX<Int<3500>,Scale<SlowNoise<Int<3000>>,Int<-2500>,Int<-3500>>,RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>>,RandomPerLEDFlicker<Mix<Int<2570>,Black,RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<300>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<MELT_SIZE_ARG,31084>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrConcat<TrInstant,AlphaMixL<Bump<EffectPosition<EFFECT_BLAST>,Scale<EffectPosition<EFFECT_BLAST>,Int<9000>,Int<12000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<300>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,31084>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,31084>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<200>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<300>>,EFFECT_BATTERY_LEVEL>>>(),
"AudioFlickerRed"
{ "Battle1;common", "Battle1/tracks/track1.wav",
OS7.14 v3.01p
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
StylePtr<Layers<RandomFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelay<3000>,TrFade<300>>,StripesX<Int<3500>,Scale<SlowNoise<Int<3000>>,Int<-2500>,Int<-3500>>,RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>>,RandomPerLEDFlicker<Mix<Int<2570>,Black,RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<300>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<MELT_SIZE_ARG,31084>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrConcat<TrInstant,AlphaMixL<Bump<EffectPosition<EFFECT_BLAST>,Scale<EffectPosition<EFFECT_BLAST>,Int<9000>,Int<12000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<300>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,22140>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,31084>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,31084>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<200>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<300>>,EFFECT_BATTERY_LEVEL>>>(),
"AudioFlickerGreen"
{ "ANI3;common", "ANI3/tracks/track2.wav",
OS7.14 v3.01p
Style Option
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
StylePtr<Layers<RandomFlicker<Stripes<24000,-1400,RgbArg<BASE_COLOR_ARG,Rgb<0,10,245>>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,245>>,Mix<Int<11565>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,10,245>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,245>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,10,245>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,245>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
"RotoscopeBlue"
CONFIGARRAY(presets) },
And this is the error i’m getting:
Arduino: 1.8.19 (Windows 10), Board: "Proffieboard V3, Serial + Mass Storage + WebUSB, SDCARD (SDIO High Speed), 80 MHz, Smallest Code"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\sh1mo\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\sh1mo\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\sh1mo\Documents\Arduino\libraries -fqbn=proffieboard:stm32l4:ProffieboardV3-L452RE:usb=cdc_msc_webusb,dosfs=sdmmc1,speed=80,opt=os -vid-pid=1209_6668 -ide-version=10819 -build-path C:\Users\sh1mo\AppData\Local\Temp\arduino_build_564302 -warnings=none -build-cache C:\Users\sh1mo\AppData\Local\Temp\arduino_cache_272942 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\sh1mo\AppData\Local\Arduino15\packages\proffieboard\tools\arm-none-eabi-gcc\9-2020-q2-update -prefs=runtime.tools.arm-none-eabi-gcc-9-2020-q2-update.path=C:\Users\sh1mo\AppData\Local\Arduino15\packages\proffieboard\tools\arm-none-eabi-gcc\9-2020-q2-update -verbose C:\Users\sh1mo\Desktop\ProffieOS\ProffieOS.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\sh1mo\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\sh1mo\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\sh1mo\Documents\Arduino\libraries -fqbn=proffieboard:stm32l4:ProffieboardV3-L452RE:usb=cdc_msc_webusb,dosfs=sdmmc1,speed=80,opt=os -vid-pid=1209_6668 -ide-version=10819 -build-path C:\Users\sh1mo\AppData\Local\Temp\arduino_build_564302 -warnings=none -build-cache C:\Users\sh1mo\AppData\Local\Temp\arduino_cache_272942 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\sh1mo\AppData\Local\Arduino15\packages\proffieboard\tools\arm-none-eabi-gcc\9-2020-q2-update -prefs=runtime.tools.arm-none-eabi-gcc-9-2020-q2-update.path=C:\Users\sh1mo\AppData\Local\Arduino15\packages\proffieboard\tools\arm-none-eabi-gcc\9-2020-q2-update -verbose C:\Users\sh1mo\Desktop\ProffieOS\ProffieOS.ino
Using board 'ProffieboardV3-L452RE' from platform in folder: C:\Users\sh1mo\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\4.6
Using core 'stm32l4' from platform in folder: C:\Users\sh1mo\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\4.6
Detecting libraries used...
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -flto -fdevirtualize-at-ltrans -w -x c++ -E -CC -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\sketch\\ProffieOS.ino.cpp" -o nul
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -flto -fdevirtualize-at-ltrans -w -x c++ -E -CC -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\libraries\\Wire\\src" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\sketch\\ProffieOS.ino.cpp" -o nul
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -flto -fdevirtualize-at-ltrans -w -x c++ -E -CC -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\libraries\\Wire\\src" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\libraries\\Wire\\src\\Wire.cpp" -o nul
Generating function prototypes...
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -flto -fdevirtualize-at-ltrans -w -x c++ -E -CC -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\libraries\\Wire\\src" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\sketch\\ProffieOS.ino.cpp" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -MMD -flto -fdevirtualize-at-ltrans -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\libraries\\Wire\\src" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\sketch\\ProffieOS.ino.cpp" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\sketch\\ProffieOS.ino.cpp.o"
Compiling libraries...
Compiling library "Wire"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -MMD -flto -fdevirtualize-at-ltrans -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\libraries\\Wire\\src" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\libraries\\Wire\\src\\Wire.cpp" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\libraries\\Wire\\Wire.cpp.o"
Compiling core...
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -MMD -flto -fdevirtualize-at-ltrans -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3\\variant.cpp" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\variant.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib -MMD -flto -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\stm32l4_wiring_interrupts.c" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\stm32l4_wiring_interrupts.c.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib -MMD -flto -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\stm32l4_wiring_analog.c" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\stm32l4_wiring_analog.c.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib -MMD -flto -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\itoa.c" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\itoa.c.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib -MMD -flto -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\hooks.c" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\hooks.c.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib -MMD -flto -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\stm32l4_wiring.c" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\stm32l4_wiring.c.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib -MMD -flto -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\stm32l4_wiring_shift.c" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\stm32l4_wiring_shift.c.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib -MMD -flto -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\stm32l4_wiring_digital.c" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\stm32l4_wiring_digital.c.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib -MMD -flto -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\stm32l4_wiring_pulse.c" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\stm32l4_wiring_pulse.c.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib -MMD -flto -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\stm32l4_wiring_tone.c" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\stm32l4_wiring_tone.c.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib -MMD -flto -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\avr\\dtostrf.c" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\avr\\dtostrf.c.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib -MMD -flto -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\avr\\eeprom.c" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\avr\\eeprom.c.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib -MMD -flto -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\avr\\fdevopen.c" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\avr\\fdevopen.c.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -MMD -flto -fdevirtualize-at-ltrans -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\FS.cpp" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\FS.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -MMD -flto -fdevirtualize-at-ltrans -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\CDC.cpp" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\CDC.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -MMD -flto -fdevirtualize-at-ltrans -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\IPAddress.cpp" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\IPAddress.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -MMD -flto -fdevirtualize-at-ltrans -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\HID.cpp" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\HID.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -MMD -flto -fdevirtualize-at-ltrans -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\Print.cpp" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\Print.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -MMD -flto -fdevirtualize-at-ltrans -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\Stream.cpp" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\Stream.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -MMD -flto -fdevirtualize-at-ltrans -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\STM32.cpp" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\STM32.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -MMD -flto -fdevirtualize-at-ltrans -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\RingBuffer.cpp" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\RingBuffer.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -MMD -flto -fdevirtualize-at-ltrans -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\USBCore.cpp" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\USBCore.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -MMD -flto -fdevirtualize-at-ltrans -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\Uart.cpp" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\Uart.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -MMD -flto -fdevirtualize-at-ltrans -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\abi.cpp" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\abi.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -MMD -flto -fdevirtualize-at-ltrans -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\WString.cpp" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\WString.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -MMD -flto -fdevirtualize-at-ltrans -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\WMath.cpp" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\WMath.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -MMD -flto -fdevirtualize-at-ltrans -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\main.cpp" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\main.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib -fno-rtti -fno-exceptions -MMD -flto -fdevirtualize-at-ltrans -D_SYSTEM_CORE_CLOCK_=80000000L -D_SYSTEM_PCLK_DIVIDER_=2 -DARDUINO=10819 -DARDUINO_PROFFIEBOARD_V3 -DARDUINO_ARCH_STM32L4 -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Device/ST/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Include" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4" "-IC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3" "C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\cores\\stm32l4\\new.cpp" -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\new.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\avr\\dtostrf.c.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\avr\\eeprom.c.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\avr\\fdevopen.c.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\hooks.c.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\itoa.c.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\stm32l4_wiring.c.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\stm32l4_wiring_analog.c.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\stm32l4_wiring_digital.c.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\stm32l4_wiring_interrupts.c.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\stm32l4_wiring_pulse.c.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\stm32l4_wiring_shift.c.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\stm32l4_wiring_tone.c.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\CDC.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\FS.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\HID.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\IPAddress.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\Print.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\RingBuffer.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\STM32.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\Stream.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\USBCore.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\Uart.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\WMath.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\WString.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\abi.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\main.cpp.o"
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\core.a" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\new.cpp.o"
Archiving built core (caching) in: C:\Users\sh1mo\AppData\Local\Temp\arduino_cache_272942\core\core_4f9c89caa6e46752373eb9e8b7440efe.a
Linking everything together...
"C:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\tools\\arm-none-eabi-gcc\\9-2020-q2-update/bin/arm-none-eabi-gcc" "-LC:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302" -g -Os -Wl,--gc-sections -DSTM32L452xx -DPROFFIEBOARD_VERSION=3 -D__FPU_PRESENT=1 -march=armv7e-m -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -mslow-flash-data -fsingle-precision-constant -felide-constructors -ffast-math -DUSB_VID=0x1209 -DUSB_PID=0x6668 -DUSB_DID=0xffff "-DUSB_MANUFACTURER=\"hubbe.net\"" "-DUSB_PRODUCT=\"Proffieboard\"" -DUSB_TYPE=USB_TYPE_CDC_MSC_WEBUSB -DDOSFS_SDCARD=3 -DDOSFS_SFLASH=0 "-TC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6\\variants\\STM32L452RE-ProffieboardV3/linker_scripts/STM32L452RE_FLASH.ld" "-Wl,-Map,C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302/ProffieOS.ino.map" --specs=nano.specs -mcpu=cortex-m4 -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -flto -fuse-linker-plugin -fdevirtualize-at-ltrans -o "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302/ProffieOS.ino.elf" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\sketch\\ProffieOS.ino.cpp.o" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302\\core\\variant.cpp.o" -Wl,--start-group "C:\\Users\\sh1mo\\AppData\\Local\\Temp\\arduino_build_564302/core\\core.a" -Wl,--end-group "-LC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/STM32L4xx/Lib" "-LC:\\Users\\sh1mo\\AppData\\Local\\Arduino15\\packages\\proffieboard\\hardware\\stm32l4\\4.6/system/CMSIS/Lib" -lstm32l452 -larm_cortexM4lf_math -lc -lm
c:/users/sh1mo/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe:C:\Users\sh1mo\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\4.6\variants\STM32L452RE-ProffieboardV3/linker_scripts/STM32L452RE_FLASH.ld:224: warning: memory region `SRAM2' not declared
lto1.exe: internal compiler error: compressed stream: data error
Please submit a full bug report,
with preprocessed source if appropriate.
See <https://gcc.gnu.org/bugs/> for instructions.
lto-wrapper.exe: fatal error: C:\Users\sh1mo\AppData\Local\Arduino15\packages\proffieboard\tools\arm-none-eabi-gcc\9-2020-q2-update/bin/arm-none-eabi-gcc returned 1 exit status
compilation terminated.
c:/users/sh1mo/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe: error: lto-wrapper failed
Using library Wire at version 1.0 in folder: C:\Users\sh1mo\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\4.6\libraries\Wire
Seems like a driver issue maybe? Do you have any hints/tips for me ^^;
Thank you!
