Error: Cannot convert 'const char*' to "StyleFactory*' in initialization
I’m new to all of this. I have been following your video tutorials for updating Proffieboard and am trying to add a new preset. I got this error message:
Cannot convert ‘const char*’ to ‘Stylefactory*’ in initialization. Exit status 1. Error compiling for board Proffieboard V3.
Here is my complete Config with my added preset at the top of preset list.
https://pastebin.com/K11TZjhk
Thank you for any help!
The pastebin link 403’s, (note that most of the time you can paste your config directly on the forum by using triple backticks surrounding the config contents) however that error most commonly means that there aren’t enough bladestyles in your newly-added preset.
Check what your NUM_BLADES is set to at the top. You need that many bladestyles in your preset (one for each blade).
So if you had 2 blades, you’d need a preset like:
{ "fontdirectory", "cooltrack.wav",
    StylePtr< /* ...Style Contents... */ >(),
    "presetname"
So, my NUM_BLADES is set at 2. It looks like I have only one of those Style preset commands. What do I use for the 2nd if I have just one main blade? If you can’t tell, Im so, sooo new at this. Here is my config.
#define NUM_BLADES 2
#define VOLUME 1800
const unsigned int maxLedsPerStrip = 128;
#define CLASH_THRESHOLD_G 4.5
#define ENABLE_SERIAL
#define FETT263_MULTI_PHASE
#define FETT263_TWIST_ON
#define FETT263_STAB_ON_NO_BM
#define FETT263_SWING_OFF
#define FETT263_THRUST_ON
#define FETT263_THRUST_OFF
// #define ENABLE_SSD1306
// // Max 20 characters
// #define BLE_PASSWORD "your password"
// // Max 32 characters.
// #define BLE_NAME "Your Saber Name"
// // Max 9 characters
// #define BLE_SHORTNAME "Saber"
#define MOTION_TIMEOUT 60 * 3 * 800
    { "Seismic Blade;common", "tracks/march.wav",
/* copyright Fett263 WaterBlade (Primary Blade) OS6 Style
https://fett263.com/fett263-proffieOS6-style-library.html#WaterBlade
OS6.7 v4.021
Base Style: Interactive Water Blade
Base Color: Rgb<0,135,255> (0)
Interactive Water Blade Interactive Control: Water flows based on blade angle, hard swing upward can temporarily change direction of flow.
Preon Effect: Seismic Charge (PreOn Color)
Ignition Effect: Center Out
PowerUp Effect: Power Flash
Retraction Effect: Center In
Melt Effect: Intensity Melt
Clash Effect: Real Clash V1
StylePtr<Layers<StripesX<Scale<IsLessThan<BladeAngle<>,Int<16384>>,Scale<BladeAngle<>,Int<20000>,Int<10000>>,Scale<BladeAngle<>,Int<10000>,Int<20000>>>,Scale<BladeAngle<>,Int<-1000>,Scale<IsGreaterThan<HoldPeakF<SwingAcceleration<>,Scale<HoldPeakF<SwingAcceleration<>,Int<200>,Int<4000>>,Int<100>,Int<600>>,Scale<BladeAngle<>,Int<3000>,Int<6000>>>,Int<16384>>,Int<1000>,Int<-1000>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<25700>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<300>>,TrInstant>,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,EFFECT_IGNITION>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrCenterWipeX<IgnitionTime<300>,Int<16384>>,TrCenterWipeInX<RetractionTime<0>,Int<16384>>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<PulsingL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,Int<400>>,Bump<Scale<Trigger<EFFECT_PREON,Int<800>,Int<2000>,Int<500>>,Int<0>,Int<16384>>,Int<8000>>>,TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<18432>>>,Mix<Bump<Int<16384>,Int<8000>>,Black,RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>>,TrCenterWipeX<Mult<WavLen<EFFECT_PREON>,Int<4096>>,Int<16384>>,Mix<Bump<Int<16384>,Int<8000>>,Black,PulsingL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,Int<300>>>,TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<10240>>>>,EFFECT_PREON>>>(),
"preset 1",
   { "AhsokaTM;common", "tracks/mars.wav",
    StylePtr<InOutHelper<EasyBlade<OnSpark<BrownNoiseFlicker<Snow,Blue,50>>,White>,300,800>>(),
    StylePtr<InOutHelper<EasyBlade<OnSpark<BrownNoiseFlicker<Snow,Blue,50>>,White>,300,800>>(), "Ahsoka"},
   { "Ben;common", "tracks/mars.wav",
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<DeepSkyBlue,White>,AudioFlicker<DeepSkyBlue,White>>,White>,300,800>>(),
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<DeepSkyBlue,White>,AudioFlicker<DeepSkyBlue,White>>,White>,300,800>>(), "Ben"},
   { "Dooku;common", "tracks/mars.wav",
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Red,White>,AudioFlicker<Red,White>>,White>,400,800>>(),
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Red,White>,AudioFlicker<Red,White>>,White>,400,800>>(), "Dooku"},
   { "DV3;common", "tracks/mars.wav",
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Red,White>,AudioFlicker<Red,White>>,White>,400,800>>(), "DV3"},
   { "Emperor;common", "tracks/mars.wav",
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Red,White>,AudioFlicker<Red,White>>,White>,400,800>>(), "Emperor"},
   { "Fire;common", "tracks/mars.wav",
    StylePtr<StyleFire<Red,Yellow>>(),
    StylePtr<StyleFire<Red,Yellow>>(), "Fire"},
   { "Graflex;common", "tracks/venus.wav",
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Blue,White>,AudioFlicker<Blue,White>>,White>,300,800>>(),
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Blue,White>,AudioFlicker<Blue,White>>,White>,300,800>>(), "chunblue"},
   { "Luke;common", "tracks/venus.wav",
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Green,White>,AudioFlicker<Green,White>>,White>,400,800>>(),
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Green,White>,AudioFlicker<Green,White>>,White>,400,800>>(), "Luke"},
   { "luke4;common", "tracks/mars.wav",
    StylePtr<InOutHelper<EasyBlade<OnSpark<Gradient<Blue,AudioFlicker<White,Blue>,Red,RandomFlicker<Yellow,Blue>>>,White>,300,800>>(),
    StylePtr<InOutHelper<EasyBlade<OnSpark<Gradient<Blue,AudioFlicker<White,Blue>,Red,RandomFlicker<Yellow,Blue>>>,White>,300,800>>(), "KK"},
   { "luke5;common", "tracks/venus.wav",
    StylePtr<InOutHelper<RandomPerLEDFlicker<Pulsing<Blue,InOutHelper<White,300,800>,800>,Blue>,300,800>>(),
    StylePtr<InOutHelper<RandomPerLEDFlicker<Pulsing<Blue,InOutHelper<White,300,800>,800>,Blue>,300,800>>(), "BLUEFLASH"},
   { "QGJ;common", "tracks/venus.wav",
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Green,White>,AudioFlicker<Green,White>>,White>,300,800>>(),
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Green,White>,AudioFlicker<Green,White>>,White>,300,800>>(), "chungreen"},
   { "Rey;common", "tracks/mars.wav",
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Blue,White>,AudioFlicker<Blue,White>>,White>,300,800>>(), "sparkstar"},
   { "reygold;common", "tracks/mars.wav",
    StylePtr<InOutHelper<EasyBlade<Sparkle<Orange>,White>,300,800>>(),
    StylePtr<InOutHelper<EasyBlade<Sparkle<Orange>,White>,300,800>>(), "sparkstar"},
   { "RgueCmdr;common", "tracks/venus.wav",
    StylePtr<InOutHelper<EasyBlade<OnSpark<TransitionLoop<Red,TrConcat<TrFade<1000>,GreenYellow,TrFade<200>>>>,White>,300,800>>(),
    StylePtr<InOutHelper<EasyBlade<OnSpark<TransitionLoop<Red,TrConcat<TrFade<1000>,GreenYellow,TrFade<200>>>>,White>,300,800>>(), "CC"},
   { "SmthFuzz;common", "tracks/uranus.wav",
    StylePtr<InOutHelper<EasyBlade<OnSpark<Gradient<Cylon<Red,5,20,Red,30,20,1>,GhostWhite,Cylon<Red,5,20,Red,5,20,1>>>,White>,300,800>>(),
    StylePtr<InOutHelper<EasyBlade<OnSpark<Gradient<Cylon<Red,5,20,Red,30,20,1>,GhostWhite,Cylon<Red,5,20,Red,5,20,1>>>,White>,300,800>>(), "Cylonwhite"},
   { "SmthGrey;common", "tracks/mercury.wav",
    StylePtr<InOutHelper<EasyBlade<OnSpark<GhostWhite,Black>,White>,300,800>>(),
    StylePtr<InOutHelper<EasyBlade<OnSpark<GhostWhite,Black>,White>,300,800>>(),"white1"},
   { "SmthJedi;common", "tracks/venus.wav",
    StylePtr<InOutHelper<EasyBlade<OnSpark<InOutTr<Azure,TrColorCycle<3000>,TrFade<500>,Green>>,White>,300,800>>(),
    StylePtr<InOutHelper<EasyBlade<OnSpark<InOutTr<Azure,TrColorCycle<3000>,TrFade<500>,Green>>,White>,300,800>>(), "greenflash"},
   { "Spectral;common", "tracks/venus.wav",
    StylePtr<InOutHelper<EasyBlade<OnSpark<InOutTr<Azure,TrColorCycle<3000>,TrFade<500>,Green>>,White>,300,800>>(), "Spectral"},
   { "TeensySF;common", "tracks/mars.wav",
    StylePtr<InOutHelper<EasyBlade<Stripes<1000,1000,Cyan,Magenta,Yellow,Blue>,White>,300,800>>(),
    StylePtr<InOutHelper<EasyBlade<Stripes<1000,1000,Cyan,Magenta,Yellow,Blue>,White>,300,800>>(), "rainbow"},
   { "TeenysSF;common", "tracks/mars.wav",
    StylePtr<InOutHelper<EasyBlade<OnSpark<HumpFlicker<Green,Magenta,50>>,White>,300,800>>(),
    StylePtr<InOutHelper<EasyBlade<OnSpark<HumpFlicker<Green,Magenta,50>>,White>,300,800>>(), "EE"},
   { "TthCrstl;common", "tracks/venus.wav",
    StylePtr<InOutHelper<EasyBlade<OnSpark<Sparkle<HotPink,Yellow>>,GreenYellow>,300,800>>(),
    StylePtr<InOutHelper<EasyBlade<OnSpark<Sparkle<HotPink,Yellow>>,GreenYellow>,300,800>>(), "PINK"},
   { "Vader;common", "tracks/mars.wav",
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Red,White>,AudioFlicker<Red,White>>,White>,400,800>>(), "chunRed"},
   { "Windu;common", "tracks/uranus.wav",
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Magenta,White>,AudioFlicker<Blue,White>>,White>,300,800>>(),
    StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Magenta,White>,AudioFlicker<Blue,White>>,White>,300,800>>(), "chunzise"},
   { "Vortex;common", "tracks/uranus.wav",
    StylePtr<Layers<StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<255,0,0>>,Black,20>,RotateColorsX<Variation,Rgb<4,0,8>>,
    BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<115,15,220>>,70>,RotateColorsX<Variation,Rgb<42,0,105>>>,RotateColorsX<Variation,Rgb<30,0,66>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,
    FireConfig<2,3000,0>,FireConfig<2,3000,0>>,AlphaL<Stripes<2500,-3000,Red,Rgb<60,0,0>,Pulsing<Rgb<30,0,0>,Black,800>>,SwingSpeed<600>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,
    Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,
    Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrJoinR<TrWipe<100>,TrWipeIn<100>>,White,TrJoinR<TrWipe<100>,TrWipeIn<100>>>,
    SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,
    HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,SparkleL<White,100,400>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,
    ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
    TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<White>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<White,40>,TrFade<1000>>,
    EFFECT_RETRACTION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,
    SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrConcat<TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<400>,Int<300>,Int<400>,Int<32768>>,
    Mix<SmoothStep<Int<5500>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<350>,Int<300>,Int<350>,Int<32768>>,Mix<SmoothStep<Int<11000>,Int<-2000>>,
    Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<300>,Int<300>,Int<300>,Int<32768>>,Mix<SmoothStep<Int<16500>,Int<-2000>>,
    Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<250>,Int<300>,Int<250>,Int<32768>>,Mix<SmoothStep<Int<22000>,Int<-2000>>,
    Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<200>,Int<300>,Int<200>,Int<32768>>,Mix<SmoothStep<Int<27500>,Int<-2000>>,
    Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWipeIn<200>,Mix<SmoothStep<Int<33000>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrFade<300>>,
    TrConcat<TrWipe<200>,Mix<SmoothStep<Int<27500>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<200>,Int<300>,Int<200>,Int<0>>,
    Mix<SmoothStep<Int<22000>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<250>,Int<300>,Int<250>,Int<0>>,
    Mix<SmoothStep<Int<16500>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<300>,Int<300>,Int<300>,Int<0>>,
    Mix<SmoothStep<Int<11000>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<350>,Int<300>,Int<350>,Int<0>>,
    Mix<SmoothStep<Int<5500>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<255,0,0>>>,TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<400>,Int<300>,Int<400>,Int<0>>,Black,
    TrWaveX<RotateColorsX<Variation,Rgb<255,0,0>>,Int<400>,Int<300>,Int<400>,Int<0>>,Black,TrInstant>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<White,Bump<Int<0>,Int<10000>>>,TrFade<3000>,
    AlphaL<Orange,Bump<Int<0>,Int<8000>>>,TrFade<3000>,AlphaL<Red,Bump<Int<0>,Int<6000>>>,TrFade<2000>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrFade<2000>,
    AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<255,0,0>>,10>,Bump<Int<0>,Int<4000>>>,TrFade<2950>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<255,0,0>>,15>,Bump<Int<0>,Int<5000>>>,TrFade<3000>,
    AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<255,0,0>>,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,3>>,EFFECT_PREON>>>(),
    AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<255,0,0>>,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,3>>,EFFECT_PREON>>>(),"tsb"},
 { 0, WS281XBladePtr<128, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
    WS281XBladePtr<30, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4, bladePowerPin5> >()
  , CONFIGARRAY(presets) },
Thanks for the response.
You can use the same bladestyle for the second blade as the first. Once you get more of a feel for things and more comfortable you can always go back and create a more specialized style specifically for the accent.
I failed to mention earlier: Anything that lights up and is controlled by the proffieboard is lumped into the category of “blade.” In your case, it looks like maybe you have some accent pixels on your chassis or something like that?
I’m new to the saber as well, 89saber Obi Wan 3.5. Only one main blade, and no accent lights that I can tell. To be clear, should I then just copy those style lines for the 2nd blade commands?
That would work, yeah.
It’s possible the config has two blades configured and you don’t actually have anything wired up to that second pad.
If you wanted to experiment, you could remove the second blade and presets and see if you notice anything different…
If that’s something you’re interested in, you’d need to change NUM_BLADES to 1, remove the second WS281XBladePtr<...>() from the BladeConfig, and remove all the second styles from each preset.
Fwiw, since that’s a relatively involved process, and especially if you’re new to it all, that kind of operation would probably be made a lot easier by ProffieConfig. It’s a tool I wrote to handle editing proffieboard configs as well as upload them to the proffieboard/saber. I only mention it because it works to keep everything synchronized with operations like that (there’s other reasons to use it to, but that’s the relevant one here).
Your config needs to be valid to be able to import it (so either removing that new preset and/or fixing it prior would be necessary), but from there you’re home free.
Thanks so much!!
For simplicity sake, I will try copying for the second blade style and let you know how it goes.
Definitely interested in your utility though, and will check it out once im don’t with this….
I copied the second blade style as we discussed, then verified through Arduino - no errors, 43% storage used. Do I need to set up the preset any further? When I tried running through presets on my saber there was no new preset.
Did you just verify or did you do a proper upload? If you didn’t upload then no changes will have been made to the actual saber.
If you did upload and they’re not showing up, try deleting the .ini files from the SD card.
Also, see here for info about ensuring the upload is successful:
I had the same error as OP and after copying the blade styles twice it checks out in Arduino. I haven’t uploaded it to the saber because the config file the provider sent me (89saber as well) seems to be for a Kylo Ren style three bladed saber, and mine is Vader’s. If I upload it as it is will it work with my saber?
Chances are your main blade will work fine. The board would just be trying to also light up two blades that don’t exist. It’s pretty easy to remove that stuff from the config phone and make it correct. If you don’t, nothing would really break, you just wasting a lot of memory on null blades.
