The details you requested:
Win10
Arduino 1.8.13
plugin 3.6.0
OS6.7 from github master branch
Proffieboard V2.2 form the original TRA run
default_proffieboard_config.h, altered blade def, volume reduced
// This is a sample configuration file.
// This saber has:
//   o Proffieboard V1 hardware.
//   o Two buttons
//   o An XP-E2 RGB LED star on LED 4-5-6
//   o A neopixel blade on LED 1-2-3 and neopixel data 1.
// If you have a saber similar to this one, make a copy and use the copy.
// This is also the default configuration file. Pre-programmed boards will
// use this configuration file.
#define NUM_BLADES 2
#define VOLUME 200
#define CLASH_THRESHOLD_G 1.0
#define SAVE_STATE
    StyleFirePtr<RED, YELLOW, 1>(), "fire"},
    StyleNormalPtr<RED, WHITE, 300, 800>(),
    StyleFirePtr<BLUE, CYAN, 0>(),
    StyleFirePtr<BLUE, CYAN, 1>(), "blue fire"},
    StylePtr<InOutHelper<EASYBLADE(OnSpark<GREEN>, WHITE), 300, 800> >(),
    StyleNormalPtr<WHITE, RED, 300, 800, RED>(),
    StyleNormalPtr<AudioFlicker<YELLOW, WHITE>, BLUE, 300, 800>(),
  { "SmthGrey", "tracks/venus.wav",
    StylePtr<InOutSparkTip<EASYBLADE(MAGENTA, WHITE), 300, 800> >(),
  { "SmthFuzz", "tracks/mars.wav",
    StyleNormalPtr<Gradient<RED, BLUE>, Gradient<CYAN, YELLOW>, 300, 800>(),
  { "RgueCmdr", "tracks/mercury.wav",
    StyleRainbowPtr<300, 800>(),
  { "TthCrstl", "tracks/uranus.wav",
    StyleStrobePtr<WHITE, Rainbow, 15, 300, 800>(),
    &style_pov,
    StyleNormalPtr<BLACK, BLACK, 300, 800>(), "POV"},
    &style_charging,
 { 0, WS2811BladePtr<128, WS2811_800kHz | WS2811_GRB, bladePin, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
     SimpleBladePtr<CreeXPE2WhiteTemplate<550>,
                    CreeXPE2BlueTemplate<240>,
                    CreeXPE2BlueTemplate<240>, NoLED, bladePowerPin4, bladePowerPin5, bladePowerPin6, -1>(),
     CONFIGARRAY(presets) },
Everything works as expected
Num buttons 1, 2 blades, I2S
// This saber has:
//   o Two buttons
#define NUM_BUTTONS 1
#define VOLUME 200
#define SAVE_STATE
#define ENABLE_I2S_OUT //for I2S to PA/external amplifier
	"cyan"},
	"blue"},
	"fire"},
	"red"},
	"blue fire"},
	"green"},
	"white"},
	"yellow"},
	"magenta"},
	"gradient"},
	"rainbow"},
	"strobe"},
//  { "TeensySF", "tracks/venus.wav",
//    &style_pov,
//    //StyleNormalPtr<BLACK, BLACK, 300, 800>(), "POV"},
    &style_charging,
	"Battery\nLevel"}
bootsound OK
reacts to all serial commands
Sound via speaker
I2S output OK on fs, sck, and sd
No data on BladePin, blade does not ignite
commenting out I2S → everything works fine again
Num buttons 1, num blades 1, I2S
// This saber has:
//   o Two buttons
#define VOLUME 200
#define SAVE_STATE
	"cyan"},
	"blue"},
	"fire"},
	"red"},
	"blue fire"},
	"green"},
	"white"},
	"yellow"},
	"magenta"},
	"gradient"},
	"rainbow"},
	"strobe"},
//    &style_pov,
    &style_charging,
	"Battery\nLevel"}
No bootsound, very short fs and sck on I2S, no sd on I2S
Serial monitor show correct data, but does not react to any command
on → Whut?
n → Whut
dir → Whut
play /teensysf/hum01.wav   → Whut? :play
help → Whut?
Using the button, blade ignites, data on BladePin, very short fs and sck in I2S, no data, no sound via speaker
Serial monitor output;
Ignition.
unit = 0 vol = 0.00, Playing hum01.wav
File hum01.wav not found.
unit = 1 vol = 0.50, Playing out04.wav
File out04.wav not found.
When clash is triggered, blade reacts, very short fs and sck in I2S, no data, no sound via speaker
Serial monitor shows clash and wav files that -should- be playing
EVENT: Clash ON millis=317987
unit = 3 vol = 0.50, Playing clsh04.wav
File clsh04.wav not found.
Amplifier off.
Num buttons 1, num blades 2, neopixels, I2S
// This saber has:
//   o Two buttons
#define VOLUME 200
#define SAVE_STATE
//#define ENABLE_I2S_OUT //for I2S to PA/external amplifier
	"cyan"},
	"blue"},
	"fire"},
	"red"},
	"blue fire"},
	"green"},
	"white"},
	"yellow"},
	"magenta"},
	"gradient"},
	"rainbow"},
	"strobe"},
//    &style_pov,
    &style_charging,
	"Battery\nLevel"}
      WS2811BladePtr<128, WS2811_800kHz | WS2811_GRB, blade2Pin, PowerPINS<bladePowerPin4, bladePowerPin5> >(),
Initial bootsound, on speaker and on I2S
on → Whut?
n → Whut
dir → Whut
help → Whut?
After ignition using the button, → 501Hz squee-of-death
Note: Tried most of these config on 2 different V2.2 boards, with the same result
