Edit Mode Delete Preset behaviour
hi Fernando,
the edit mode delete preset is that intended to delete just one preset e.g. if you accidentally copy preset by pressing the pow button 4 clicks?
I’m using the 7.14 and the fett263 prop files
// ProffieOS7 Config File
#define NUM_BUTTONS 1
#define VOLUME 1550
#define CLASH_THRESHOLD_G 3
#define AUDIO_CLASH_SUPPRESSION_LEVEL 10
#define PROFFIEOS_ACCELEROMETER_RANGE 16
#define PROFFIEOS_MOTION_FREQUENCY 1600
#define ACCEL_MEASUREMENTS_PER_SECOND 800
#define KILL_OLD_PLAYERS
#define FILTER_ORDER 8
#define SAVE_PRESET
#define FETT263_MAX_CLASH 16
#define FETT263_SPIN_MODE
#define FETT263_QUICK_SELECT_ON_BOOT
#define FETT263_BM_DISABLE_OFF_BUTTON
#define FETT263_THRUST_ON
#define FETT263_STAB_ON_PREON
#define FETT263_STAB_ON_NO_BM
#define FETT263_FORCE_PUSH_LENGTH 3
Yes, it deletes current preset.
I did that and it deleted both the copied preset and the original preset. I’m not sure how to show this though what is the best method. P.s. no usb so no serial.
Is there a way of removing the copy preset function outside of the edit mode? Or at least replace It with some other feature.
In OS7 you can use
Would that disable the copy preset in the edit mode?
No, see Defines and what they do here:
Much obliged my good man.
