I created my config using 2 blades (pixel emitter on LED2 and LED3 & Edison Filament on LED4), uploaded it and am not getting the Edison Filament to light up at all.
I wired the filament to LED4 pad, then resistor, filament, then a spare (+) pad on a removable chassis PCB. I did this because I originally wired it wrong, then moved the positive to the PCB because a splice was too difficult. I did a multimeter diode test from LED4 pad to the positive lead and the filament lit up, so I know it’s not broken. Anything come to mind as to what I’ve done wrong? My blade config is consistent with examples I’ve seen, so I wonder if it’s a config problem or how I’ve decided to wire it? Linking to my config here:
Thanks
Try shorting LED4 to BATT- with a wire, or a paperclip or something.
If the filament lights up, then it should be wired more or less correctly.
I don’t see anything obviously wrong with the config file.
FACEPALM… User error. I was testing when it was connected via USB and the kill switch was off. As soon as I turned on the kill switch, the filament lit up. Thanks for the the response. Now, should I delete this post or leave it for others amusement? haha
Please leave the post so that others can maybe learn from your mistake.
Been there, done that. No facepalm needed. Awesome how walking away from something for 5 minutes minimum helps you go “The hell is wrong with me?” huh?
The greatest teacher, failure is.
Then a genius, I should be
