Double styles in the config
I purchased my saber (89sabers ANH Graflex) used and have been basing my configs off of the one included. It has every style listed twice, once for the main blade, and I think the second set is for the lights on the chassis.
Can I just remove the second set? I think it’s slowing down the effects. My outs and jerky and the clashes feel delayed.
#define NUM_BLADES 2
#define VOLUME 1100
const unsigned int maxLedsPerStrip = 128;
#define CLASH_THRESHOLD_G 3.5
#define ENABLE_SERIAL
#define FETT263_TWIST_ON
  { "CalKestis", "tracks/CalKestis.wav",
     StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,Blue>,Pulsing<RotateColorsX<Variation,Rgb<0,0,90>>,RotateColorsX<Variation,Blue>,800>,RotateColorsX<Variation,Blue>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,160>>>,TrDelay<30000>,RotateColorsX<Variation,Blue>,TrFade<800>>,EFFECT_FORCE>,AlphaL<StrobeL<Black,Int<20>,Int<1>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(),
     StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,Blue>,Pulsing<RotateColorsX<Variation,Rgb<0,0,90>>,RotateColorsX<Variation,Blue>,800>,RotateColorsX<Variation,Blue>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,160>>>,TrDelay<30000>,RotateColorsX<Variation,Blue>,TrFade<800>>,EFFECT_FORCE>,AlphaL<StrobeL<Black,Int<20>,Int<1>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(), "0"},
  { "Graflex3", "tracks/Graflex3.wav",
StylePtr<Layers<AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<8192>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,AlphaL<TransitionEffect<RgbArg<EMITTER_COLOR_ARG,Rgb<0,0,0>>,AlphaL<RgbArg<EMITTER_COLOR_ARG,Rgb<0,0,0>>,Int<0>>,TrInstant,TrConcat<TrFade<1000>,Red,TrFade<1000>,Orange,TrFade<1000>>,EFFECT_IGNITION>,SmoothStep<IntArg<EMITTER_SIZE_ARG,-93>,Int<-6000>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,97,0>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,26332>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,26332>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,26332>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<White,SmoothStep<IntArg<EMITTER_SIZE_ARG,-93>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Orange,SmoothStep<IntArg<EMITTER_SIZE_ARG,-93>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Red,SmoothStep<IntArg<EMITTER_SIZE_ARG,-93>,Int<-2000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>>,EFFECT_POSTOFF>>>(),
StylePtr<Layers<AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<8192>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,AlphaL<TransitionEffect<RgbArg<EMITTER_COLOR_ARG,Rgb<0,0,0>>,AlphaL<RgbArg<EMITTER_COLOR_ARG,Rgb<0,0,0>>,Int<0>>,TrInstant,TrConcat<TrFade<1000>,Red,TrFade<1000>,Orange,TrFade<1000>>,EFFECT_IGNITION>,SmoothStep<IntArg<EMITTER_SIZE_ARG,-93>,Int<-6000>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,97,0>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,26332>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,26332>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,26332>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<White,SmoothStep<IntArg<EMITTER_SIZE_ARG,-93>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Orange,SmoothStep<IntArg<EMITTER_SIZE_ARG,-93>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Red,SmoothStep<IntArg<EMITTER_SIZE_ARG,-93>,Int<-2000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>>,EFFECT_POSTOFF>>>(), "0"},
	{ "Graflex4", "tracks/Graflex4.wav",
StylePtr<Layers<Stripes<16000,-1000,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Pulsing<Mix<Int<11565>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,800>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<1000>>,Int<300>,Int<3000>>>,AlphaL<RgbArg<EMITTER_COLOR_ARG,Rgb<84,82,255>>,Int<0>>,TrSparkX<RgbArg<EMITTER_COLOR_ARG,Rgb<84,82,255>>,Scale<NoisySoundLevel,Int<200>,Int<600>>,Int<250>,Int<0>>>>,AlphaL<AudioFlickerL<RgbArg<SWING_COLOR_ARG,Rgb<0,0,0>>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,68,0>>,Bump<Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>,Int<6000>>>,TrCenterWipeX<Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>>,AlphaL<Remap<CenterDistF<Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>>,Stripes<1600,-2000,RgbArg<BLAST_COLOR_ARG,Rgb<255,68,0>>,Mix<Int<2096>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,68,0>>>>>,Bump<Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>,Int<32000>>>,TrJoin<TrSmoothFade<50>,TrCenterWipeX<Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>>>>,EFFECT_BLAST>,AlphaL<TransitionEffectL<TrSelect<Scale<ClashImpactF<>,Int<0>,Int<4>>,TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<8000>,Int<12000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>>,Stripes<1500,-3000,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>>>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<300>,Int<500>>>>>,EFFECT_CLASH>,Scale<ClashImpactF<>,Int<24000>,Int<32768>>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,23777>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,23777>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,23777>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,23777>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,23777>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<300>>,TrJoin<TrWipeInX<RetractionTime<0>>,TrSmoothFadeX<RetractionTime<0>>>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<White,SmoothStep<IntArg<EMITTER_SIZE_ARG,-260>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Orange,SmoothStep<IntArg<EMITTER_SIZE_ARG,-260>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Red,SmoothStep<IntArg<EMITTER_SIZE_ARG,-260>,Int<-2000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>>,EFFECT_POSTOFF>>>(),
StylePtr<Layers<Stripes<16000,-1000,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Pulsing<Mix<Int<11565>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,800>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<1000>>,Int<300>,Int<3000>>>,AlphaL<RgbArg<EMITTER_COLOR_ARG,Rgb<84,82,255>>,Int<0>>,TrSparkX<RgbArg<EMITTER_COLOR_ARG,Rgb<84,82,255>>,Scale<NoisySoundLevel,Int<200>,Int<600>>,Int<250>,Int<0>>>>,AlphaL<AudioFlickerL<RgbArg<SWING_COLOR_ARG,Rgb<0,0,0>>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,68,0>>,Bump<Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>,Int<6000>>>,TrCenterWipeX<Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>>,AlphaL<Remap<CenterDistF<Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>>,Stripes<1600,-2000,RgbArg<BLAST_COLOR_ARG,Rgb<255,68,0>>,Mix<Int<2096>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,68,0>>>>>,Bump<Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>,Int<32000>>>,TrJoin<TrSmoothFade<50>,TrCenterWipeX<Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>>>>,EFFECT_BLAST>,AlphaL<TransitionEffectL<TrSelect<Scale<ClashImpactF<>,Int<0>,Int<4>>,TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<8000>,Int<12000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>>,Stripes<1500,-3000,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>>>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<300>,Int<500>>>>>,EFFECT_CLASH>,Scale<ClashImpactF<>,Int<24000>,Int<32768>>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,23777>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,23777>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,23777>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,23777>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,23777>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<300>>,TrJoin<TrWipeInX<RetractionTime<0>>,TrSmoothFadeX<RetractionTime<0>>>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<White,SmoothStep<IntArg<EMITTER_SIZE_ARG,-260>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Orange,SmoothStep<IntArg<EMITTER_SIZE_ARG,-260>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Red,SmoothStep<IntArg<EMITTER_SIZE_ARG,-260>,Int<-2000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>>,EFFECT_POSTOFF>>>(), "0"},
    { "Graflex8", "tracks/Graflex8.wav",
StylePtr<Layers<Stripes<16000,-1000,RgbArg<BASE_COLOR_ARG,Rgb<10,10,255>>,Pulsing<Mix<Int<11565>,Black,RgbArg<BASE_COLOR_ARG,Rgb<10,10,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<10,10,255>>,800>,RgbArg<BASE_COLOR_ARG,Rgb<10,10,255>>>,AlphaL<AudioFlickerL<RgbArg<SWING_COLOR_ARG,Rgb<0,0,0>>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,68,0>>,Bump<Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>,Int<6000>>>,TrCenterWipeX<Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>>,AlphaL<Remap<CenterDistF<Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>>,Stripes<1600,-2000,RgbArg<BLAST_COLOR_ARG,Rgb<255,68,0>>,Mix<Int<2096>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,68,0>>>>>,Bump<Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>,Int<32000>>>,TrJoin<TrSmoothFade<50>,TrCenterWipeX<Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>>>>,EFFECT_BLAST>,AlphaL<TransitionEffectL<TrSelect<Scale<ClashImpactF<>,Int<0>,Int<4>>,TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<8000>,Int<12000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>>,Stripes<1500,-3000,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>>>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<300>,Int<500>>>>>,EFFECT_CLASH>,Scale<ClashImpactF<>,Int<24000>,Int<32768>>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26608>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26608>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,25900>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,25900>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,25900>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<300>>,TrJoin<TrWipeInX<RetractionTime<0>>,TrSmoothFadeX<RetractionTime<0>>>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<White,SmoothStep<IntArg<EMITTER_SIZE_ARG,-260>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Orange,SmoothStep<IntArg<EMITTER_SIZE_ARG,-260>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Red,SmoothStep<IntArg<EMITTER_SIZE_ARG,-260>,Int<-2000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>>,EFFECT_POSTOFF>>>(),
StylePtr<Layers<Stripes<16000,-1000,RgbArg<BASE_COLOR_ARG,Rgb<10,10,255>>,Pulsing<Mix<Int<11565>,Black,RgbArg<BASE_COLOR_ARG,Rgb<10,10,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<10,10,255>>,800>,RgbArg<BASE_COLOR_ARG,Rgb<10,10,255>>>,AlphaL<AudioFlickerL<RgbArg<SWING_COLOR_ARG,Rgb<0,0,0>>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,68,0>>,Bump<Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>,Int<6000>>>,TrCenterWipeX<Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>>,AlphaL<Remap<CenterDistF<Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>>,Stripes<1600,-2000,RgbArg<BLAST_COLOR_ARG,Rgb<255,68,0>>,Mix<Int<2096>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,68,0>>>>>,Bump<Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>,Int<32000>>>,TrJoin<TrSmoothFade<50>,TrCenterWipeX<Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>>>>,EFFECT_BLAST>,AlphaL<TransitionEffectL<TrSelect<Scale<ClashImpactF<>,Int<0>,Int<4>>,TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<8000>,Int<12000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>>,Stripes<1500,-3000,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>>>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<300>,Int<500>>>>>,EFFECT_CLASH>,Scale<ClashImpactF<>,Int<24000>,Int<32768>>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26608>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26608>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,25900>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,25900>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,25900>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<300>>,TrJoin<TrWipeInX<RetractionTime<0>>,TrSmoothFadeX<RetractionTime<0>>>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<White,SmoothStep<IntArg<EMITTER_SIZE_ARG,-260>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Orange,SmoothStep<IntArg<EMITTER_SIZE_ARG,-260>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Red,SmoothStep<IntArg<EMITTER_SIZE_ARG,-260>,Int<-2000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>>,EFFECT_POSTOFF>>>(),"0"},
 { "Shiny", "tracks/Shiny.wav",     StylePtr<Layers<StripesX<Sin<Int<12>,Int<3000>,Int<7000>>,Scale<SwingSpeed<100>,Int<75>,Int<125>>,StripesX<Sin<Int<10>,Int<1000>,Int<3000>>,Scale<SwingSpeed<100>,Int<75>,Int<100>>,
Pulsing<RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<5,0,30>>,1200>,Mix<SwingSpeed<200>,RotateColorsX<Variation,Rgb<50,0,90>>,Black>>,RotateColorsX<Variation,Rgb<20,0,50>>,
Pulsing<RotateColorsX<Variation,Rgb<18,0,60>>,StripesX<Sin<Int<10>,Int<2000>,Int<3000>>,Sin<Int<10>,Int<75>,Int<100>>,RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<30,0,70>>>,2000>,
Pulsing<RotateColorsX<Variation,Rgb<60,0,95>>,RotateColorsX<Variation,Rgb<2,0,5>>,3000>>,AlphaL<StyleFire<RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<1,0,2>>,0,1,FireConfig<10,2000,2>,
FireConfig<10,2000,2>,FireConfig<10,2000,2>,FireConfig<0,0,25>>,Int<10000>>,TransitionEffectL<TrConcat<TrFade<400>,
StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Red>,Black,20>,
AudioFlicker<RotateColorsX<Variation,Rgb<60,0,0>>,RotateColorsX<Variation,Rgb<10,0,0>>>,
BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<255,25,25>>,70>,RotateColorsX<Variation,Rgb<128,0,0>>>,Rgb<80,0,0>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,
FireConfig<2,3000,0>>,TrDelay<30000>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Red>,Black,20>,AudioFlicker<RotateColorsX<Variation,Rgb<60,0,0>>,
RotateColorsX<Variation,Rgb<10,0,0>>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<255,25,25>>,70>,RotateColorsX<Variation,Rgb<128,0,0>>>,Rgb<80,0,0>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,
FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrFade<800>>,EFFECT_FORCE>,AlphaL<Stripes<2500,-3000,Red,Rgb<60,0,0>,Pulsing<Rgb<30,0,0>,Black,800>>,SwingSpeed<600>>,
LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,150,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
AlphaL<Moccasin,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<200>,
EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,
ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,
SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<450>,TrWipeIn<1050>,Black>>>(),
SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<450>,TrWipeIn<1050>,Black>>>(),"0"},
{ "Power", "tracks/Power.wav",
    &style_charging,
    &style_charging, "strobe"},
 { 0, WS281XBladePtr<128, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
    WS281XBladePtr<128, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4, bladePowerPin5> >(), CONFIGARRAY(presets) },
I don’t think the secondary blade is what is making it slow.
However, I doubt your chassis has 128 LEDs, you speed things up a bit by changing the second blade from 128 LEDs to the actual number of accent LEDs.
Laggy effects are almost always due to SD card preformance. You want your SD card to be 1200kbps read speed with 12 simulatenous audio streams. Subpar or poor performing SD cards will cause the saber to lag or freeze.
If you experience lag or slow response you need to run ‘sdtest’ in Serial Monitor. Even if SD is labeled as high performance you should run sdtest to be sure.
  • First, remove DISABLE_DIAGNOSTIC_COMMANDS define from your config.
  • Upload new config (you may temporatily need to remove some presets if exceeding FLASH memory)
  • With saber connected go to Arduino > Tools > Serial Monitor
  • Type ‘sdtest’
  • If you do not have 1200kbps read speed and 12 simulatenous audio streams you will want to replace your SD with a better performing card.
You can also improve SD performance via formatting and file structure, also be sure to ALWAYS ‘Eject’ the SD card anytime it’s mounted to your computer to prevent file corruption.
I replaced the SD card and that fixed the annoying lag.
Must have been corrupt before I got it. The board had issues the first time I turned it on, but it got worse over time until it was almost unusable.
