I ordered a mual saber from Saber Theory and was looking through Fett263 (Of course ) and was just wondering if it’s absolutely a requirement to have the config.h file to update/ do anything pertaining to the prop button from Fett263? I’m VERY new to the saber community so please bare with me
Could you explain your question more clearly?
What are you looking to do?
Generally speaking, yes, you need to upload a config file that contains all the things you want your saber to have as far as sound and blade animations.
I am wanting to add styles, fonts, etc. to my proffieboard but this is my dilemma—
While reading step 1 of Fett263’s how to proffieboard update, it states “If you received your saber from an installer they should have a copy of your config on the SD card (if not you will want to request)”
What if I’m unable to get my config from the installer but I still would like to update/ add Fett263 prop button to my proffieboard? What’s the best way to go about this?
If you’re able to determine how your saber is wired you can create a new config.h. but I would check you SD card or attempt to get from your installer. If you’re unable to get I would ask in the FB groups to see if anyone is familiar with your particular saber. The config has a lot of information specific to how your saber is wired to run and without that information it is hard to create a config.
