Hi people. I’m building a custom saber for a friend and he’s asked if I could remove the font boot sounds and any music tracks. If possible what’s the best way to do this without causing errors? I was thinking blank .wav files or is it just a case of deleting the folders. Cheers
Just delete the files/folders.
Thanks do I need to change anything in the configs
No, you do not.
If you delete a sound font directory, which is called from the config, won’t it throw a “font directory not found” error?
If you delete the whole font, yes.
This thread is about deleting a single sound from a font.
Got it. I’ve been removing the preset from the config and thought I was doing it wrong. Cheers.
