I have decided to go a different route to the chassis that I’m gonna use but I need the thickness of the proffieboard, what I found for the proffieboard v2.2 is that it’s L=33.9 W=17.9 and H=3 but I want to confirm.
Depends on where you measure since different components have different heights.
The PCB itself is 1.6mm.
Unfortunately my good calipers have gone missing, or I would take a few measurements.
is there a scad of the holes for the board on v2.2?
Nos sure.
Should be easy to do though. The holes are laid out on a 0.1" grid, and the diameter is big enough to fit a 1x1mm pin.
Kicad can also export 3d models, it’s tricky to get it to do the components property, but the PCB itself should be easy I think…
which file is the pcb file?
I’m going to assume you asked “where do I find the kicad file(s)?”
Proffieboard 2.2 page → click on a Proffieboard V2.2
link near the top.
I installed kicad and got the measurements, is the teensysaberv2.kicad_pcb the one that is current??
Should be.
Ignore the filename.
