hey guys its me again…
so when i upload my new blades/fonts/styles the originals work but i cant seem to get any of fetts or jaydalorians darth maul ones to work and idk why…do i have to put them in the new proffieOS folder or what?
thanks
Fett263 is probably right, try removing KEEP_SAVEFILES_WHEN_PROGRAMMING.
If that’s not the problem, you’re going to have to explain what you mean by “work”.
Does it fail to compile?
Does it compile fine, but not upload?
Do you get an error message?
Does it compile and upload fine, but nothing seem to change?
i dont remember if it was you fett or sloppy but someone said to try to get a new cable cuz mine had troulbe uploading. like it’d keep stopping in the middle even tho nothing was wrong. so i went out and bout a hub and a new cable. i seen on one of fetts videos he said he had a hub and now every time i upload it goes right through so i figured i’d let you guys know just incase there was another padawan who had the same problem and needed help! and also i’ll let you know in a minute what happens. thanks
fett was right! thanks guys and fett i forgot about the patron thing i’ll be doing that now
