So in my quest to develop multi_prop, I tested detonator.h as a single prop.
I got this compile error:
In file included from C:\Users\Olivier\Desktop\LightSabers\ProffieOS_7.14\config\olicomplex1.5.007_test_multi_prop.h:152,
from C:\Users\Olivier\Desktop\LightSabers\ProffieOS_7.14\ProffieOS_7.14.ino:522:
C:\Users\Olivier\Desktop\LightSabers\ProffieOS_7.14\props\detonator.h:17:3: error: non-static data member 'powered_' declared 'constexpr'
17 | constexpr bool powered_ = true;
Using library Wire at version 1.0 in folder: C:\Users\Olivier\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\3.6\libraries\Wire
ChatPGT told me to change from this (line 17):
to this:
static constexpr bool powered_ = true;
With the new line 17, it compiles but is it a âmeâ problem or does anyone of you get the same ?
Should I create a pull request for it or not ?
I think the better solution is to just remove âconstexprâ.
If that compiles with static constexpr, thus meaning the variable is only ever read from⌠Whatâs the point of the variable? It doesnât make much sense to me given the name of âpoweredâ
EDIT: I see, itâs for conditional compilation. Is there a reason in that case not to make it static?
Maybe not.
It just seems less troublesome to male both sides of the #else behave more or less the same.
So which one is best for the detonator:
was
#ifdef DELAYED_OFF
bool powered_ = false;
void SetPower(bool on) { powered_ = on; }
#else
constexpr bool powered_ = true; //This line causes problem while compiling
void SetPower(bool on) {}
And the options to change are:
#ifdef DELAYED_OFF
#else
static constexpr bool powered_ = true; // modded line
or
#ifdef DELAYED_OFF
#else
They both compile but I donât know which is best ?
