Data line issue?
Are you sure that’s the config you’ve uploaded? I’m only asking because it defines some regular LEDs, not pixels, after the main blade.
it works! Thank you! while it does work its only one LED that is responding. Is this just the config? I’m new to configing in general.
Good job!
Is the led that’s not responding the one that connected to the other led and not directly connected to the proffie?
I expected the two crystal pixels to light up match each other.
You could change the blade2pin to this and try.
WS281XBladePtr<2, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4> >(),
Unfortunately it seems to be behaving as expected where trying to daisy chain one to the other is causing problems. I can only suggest to try to resolder and make the connections better or to use independent wires for each crystal pixel.
I tried to do a quick config for a preset and include the crystal pixels both of the pixels lit up. Its just all the LEDs working but no sound but I just knew it was me trying to play around with the fonts
No sound at all, or no sound fonts?
(No sound at all usually indicates a connection problem to the speaker.)
Most of the time it will beep or say something if there is a problem with the fonts.
Font issue most likely or bad config file. I uploaded a working one and it was working fine and was responding to everything. Style trying to find my way into getting a custom blade style config to work but that’s just programing on my end most likely
