Hi all
So I made a soundfont and recorded my voice for the quotes but the sound is low. I followed the recommendations from @NoSloppy but the volume if the hum over powers the quotes.
If that’s not showing can I share it via Google Drive?
Hi all
Isn’t the obvious solution to increase the volume of the quotes?
@Afrojedi send me one. I’ll evaluate my opinion / suggest fix.
^That. @NoSloppy’s input has been amazing w what I did w my custom pack and personalized voice-over.
I think I already have sent it to you but it might be modded
So the problem was he used a headset mic where sibilance and popping made the dynamic range extreme, as well as lack of full range frequencies, as well as a too-loud hum.
Cleaning up with some compression, EQ, and manual edits made them work better, however, you can only make things so good with lacking source material.
A better mic with quiet environment and a pop filter has been suggested.
