I’ve got a Force unleashed saber with what looks like a single led crystal chamber
I don’t have the original config and after flashing, updating it, its stopped working
The saber has a removable chassis. Inside there’s 3 wires going up into the hilt, positive and negative power and just one data line coming from data 1, so the main blade and CC are sharing the same data line?
I’ve put code for the CC into my config mostly from Fett’s Library. I’m using the V3.9 proffie board.
The main blade ignites normally.
Any advice to get it working? Thanks very much
#define NUM_BLADES 2
#define VOLUME 2500
#define SHARED_POWER_PINS
#define CLASH_THRESHOLD_G 3.0
#define MOTION_TIMEOUT 60 * 5 * 1000 // keeps motion chip active for 10 minutes while blade is Off
#define FETT263_THRUST_ON // enables Thrust On Ignition
#define FETT263_SWING_ON // enables Swing On Ignition
#define FETT263_TWIST_ON // enables Twist On Ignition
#define FETT263_TWIST_OFF // enables Twist Off Retraction
#define SAVE_STATE
#include"../props/saber_fett263_buttons.h"
{ "Kenobi", "Kenobi/tracks/Kenobi.wav",
OS7.14 v3.24p
Merge Styles
Default: Hyper Responsive Rotoscope (Prequels) [BaseColorArg]
1: Cal Kestis Survivor Blue [AltColorArg]
Retraction Effect Options: Default (0): Standard Retraction, 1: SparkTip Retraction [Color: RetractionColorArg]
Lockup Effect:
0: mainLockMulti0Shape - Begin: Real Clash - Style: Intensity AudioFlicker - End: Dissipate Up
[Color: Rgb<255,97,0> (Bright Pulse = Shift: 10086, Speed: 200)
Lightning Block Effect:
0: mainLBMulti0Shape - Begin: Responsive Impact - Style: Strobing Flash - End: Localized Absorb
[Color: AltColorArg]
Drag Effect:
[Color: Rgb<191,255,255>]
Melt Effect:
[Color: StabColorArg]
Stab Effect: Sparking Stab [Color: StabColorArg]
Blast Effect: Blast Fade (Medium) [Color: AltColorArg]
Clash Effect: Random Clash with Ripple [Color: AltColorArg (Bright Pulse = Shift: 7573, Speed: 241)
Special Ability 1: Toggle Rain Mode Uses trloop00.wav or trloop/000/000.wav (rain sounds looped)
Special Ability 2: Toggle Lightning Mode Uses tr00.wav or or tr/000/000.wav (thunder or lightning strike)
Special Ability 5: Play Sound - Ignite Uses quote19.wav or quote/019/000.wav
StylePtr<Layers<
Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<24000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-1400>,Int<-100>>,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<8000>,Int<3000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<-2600>,Int<-3600>>,RgbArg<BASE_COLOR_ARG,Blue>,Mix<Int<12000>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,Pulsing<RgbArg<BASE_COLOR_ARG,Blue>,Mix<Int<8000>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,1400>>,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<8000>,Int<3000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<-2600>,Int<-3600>>,RgbArg<BASE_COLOR_ARG,Blue>,Mix<Int<12000>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,Pulsing<RgbArg<BASE_COLOR_ARG,Blue>,Mix<Int<8000>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,1400>>,Mix<Int<7710>,Black,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<8000>,Int<3000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<-2600>,Int<-3600>>,RgbArg<BASE_COLOR_ARG,Blue>,Mix<Int<12000>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,Pulsing<RgbArg<BASE_COLOR_ARG,Blue>,Mix<Int<8000>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,1400>>>,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<8000>,Int<3000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<-2600>,Int<-3600>>,RgbArg<BASE_COLOR_ARG,Blue>,Mix<Int<12000>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,Pulsing<RgbArg<BASE_COLOR_ARG,Blue>,Mix<Int<8000>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,1400>>,Mix<Int<19276>,Black,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<8000>,Int<3000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<-2600>,Int<-3600>>,RgbArg<BASE_COLOR_ARG,Blue>,Mix<Int<12000>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,Pulsing<RgbArg<BASE_COLOR_ARG,Blue>,Mix<Int<8000>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,1400>>>>,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<8000>,Int<3000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<-2600>,Int<-3600>>,RgbArg<BASE_COLOR_ARG,Blue>,Mix<Int<12000>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,Pulsing<RgbArg<BASE_COLOR_ARG,Blue>,Mix<Int<8000>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,1400>>>,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<8000>,Int<3000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<-2600>,Int<-3600>>,RgbArg<BASE_COLOR_ARG,Blue>,Mix<Int<12000>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,Pulsing<RgbArg<BASE_COLOR_ARG,Blue>,Mix<Int<8000>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,1400>>>,
ColorSelect<EffectIncrementF<EFFECT_USER1,Int<2>>,TrFade<100>,AlphaL<White,Int<0>>,AlphaL<RgbArg<ALT_COLOR3_ARG,LemonChiffon>,SparkleF<600,800>>>,
TransitionEffectL<TrDoEffect<TrInstant,EFFECT_SOUND_LOOP,0>,EFFECT_USER1>,
TransitionEffectL<TrDoEffect<TrInstant,EFFECT_SOUND_LOOP,1>,EFFECT_USER2>,
TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RandomPerLEDFlickerL<RgbArg<STAB_COLOR_ARG,DarkOrange>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,
TransitionEffectL<TrConcat<TrInstant,AlphaMixL<Bump<EffectPosition<EFFECT_BLAST>,Int<10000>>,RgbArg<ALT_COLOR_ARG,Rgb<180,130,0>>,Mix<Int<16384>,Black,RgbArg<ALT_COLOR_ARG,Rgb<180,130,0>>>>,TrFade<300>>,EFFECT_BLAST>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<Pulsing<RgbArg<ALT_COLOR_ARG,Rgb<180,130,0>>,Mix<Int<7573>,RgbArg<ALT_COLOR_ARG,Rgb<180,130,0>>,White>,24100>,Bump<Scale<EffectPosition<EFFECT_CLASH>,Int<6000>,Int<26000>>,Int<6000>>>,TrCenterWipeX<Int<100>,Scale<EffectPosition<EFFECT_CLASH>,Int<6000>,Int<26000>>>,AlphaL<Remap<CenterDistF<Scale<EffectPosition<EFFECT_CLASH>,Int<6000>,Int<26000>>>,Stripes<1400,-2000,Pulsing<RgbArg<ALT_COLOR_ARG,Rgb<180,130,0>>,Mix<Int<7573>,RgbArg<ALT_COLOR_ARG,Rgb<180,130,0>>,White>,24100>,Mix<Int<2096>,Black,Pulsing<RgbArg<ALT_COLOR_ARG,Rgb<180,130,0>>,Mix<Int<7573>,RgbArg<ALT_COLOR_ARG,Rgb<180,130,0>>,White>,24100>>>>,Bump<Scale<EffectPosition<EFFECT_CLASH>,Int<6000>,Int<26000>>,Int<38000>>>,TrJoin<TrSmoothFade<50>,TrCenterWipeX<Int<100>,Scale<EffectPosition<EFFECT_CLASH>,Int<6000>,Int<26000>>>>>,EFFECT_CLASH>,
LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<17000>,Int<25000>>>,AudioFlicker<Pulsing<Orange,Mix<Int<10086>,Orange,White>,20000>,Mix<Int<12000>,Black,Pulsing<Orange,Mix<Int<10086>,Orange,White>,20000>>>,BrownNoiseFlicker<Pulsing<Orange,Mix<Int<10086>,Orange,White>,20000>,Mix<Int<12000>,Black,Pulsing<Orange,Mix<Int<10086>,Orange,White>,20000>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<17000>,Int<25000>>>>,AlphaL<AudioFlicker<Pulsing<Orange,Mix<Int<10086>,Orange,White>,20000>,Mix<Int<20000>,Black,Pulsing<Orange,Mix<Int<10086>,Orange,White>,20000>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<17000>,Int<21000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,Pulsing<Orange,Mix<Int<10086>,Orange,White>,20000>,AlphaL<Pulsing<Orange,Mix<Int<10086>,Orange,White>,20000>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaL<Pulsing<Orange,Mix<Int<10086>,Orange,White>,20000>,Int<0>>,TrWaveX<Pulsing<Orange,Mix<Int<10086>,Orange,White>,20000>,Int<300>,Int<100>,Int<400>,Int<0>>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveLightningBlockL<Strobe<RgbArg<ALT_COLOR_ARG,Rgb<180,130,0>>,AlphaL<RgbArg<ALT_COLOR_ARG,Rgb<180,130,0>>,Int<8000>>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<ALT_COLOR_ARG,Rgb<180,130,0>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,AlphaL<RgbArg<ALT_COLOR_ARG,Rgb<180,130,0>>,Bump<Int<18000>,Int<13000>>>,TrFade<400>>>,
LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<LightCyan>,BrownNoiseFlickerL<LightCyan,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG>,
LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
InOutTrL<TrWipe<1421>,TrWipeIn<584>>,
TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<300>>,EFFECT_BATTERY_LEVEL>>>(),
/* copyright Fett263 Simple (Quillion / Secondary Blade) OS7 Style
https://www.fett263.com/fett263-proffieOS7-style-library.html#Simple
OS7.14 v3.25p
Base Style: Static
Base Color: BaseColorArg (0)
0: sideDragMulti0Shape - Begin: Wipe In - Style: Intensity Sparking Drag - End: Wipe Out
[Color: DragColorArg]
Melt Effect: None */
StylePtr<Layers<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,InOutTrL<TrInstant,TrInstant,Black>>>(), "Kenobi"},
{"Stardust;common", "Stardust/tracks/eternal.wav",
StylePtr<Layers<
Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,Yellow,Yellow,Mix<Int<7710>,Black,Yellow>,Yellow,Mix<Int<19276>,Black,Yellow>>,Yellow>,Yellow>,
LockupTrL<Layers<
AlphaL<AudioFlickerL<Blue>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
AlphaL<DeepSkyBlue,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,Blue,TrFade<4000>>,TrConcat<TrInstant,DeepSkyBlue,TrFade<4000>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveLightningBlockL<Strobe<Cyan,AudioFlicker<DeepSkyBlue,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,
AlphaL<White,Bump<Int<0>,Int<8000>>>,
ResponsiveStabL<Blue>,
ResponsiveBlastL<Blue,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
ResponsiveClashL<Cyan,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
TransitionEffectL<TrConcat<TrFade<400>,Mix<SwingSpeed<400>,AudioFlickerL<Green>,DeepSkyBlue>,TrDelay<5000>,Mix<SwingSpeed<400>,AudioFlickerL<DeepSkyBlue>,SpringGreen>,TrFade<800>>,EFFECT_FORCE>,
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Cyan>,40>,TrFade<1200>>,EFFECT_IGNITION>,
LockupTrL<AlphaL<Mix<TwistAngle<>,DeepSkyBlue,Blue>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,
InOutTrL<TrWipeSparkTip<White,500>,TrWipeInSparkTip<White,1231>>,
TransitionEffectL<TrConcat<TrSmoothFade<6000>,AlphaMixL<SparkleF<900>,Yellow,DeepSkyBlue,DeepSkyBlue>,TrFade<1000>>,EFFECT_POSTOFF>,
TransitionEffectL<TrConcat<TrDelay<5>,AlphaL<HumpFlickerL<Rgb<100,100,150>,30>,Bump<Int<0>,Int<3000>>>,TrFade<250>,AlphaL<HumpFlickerL<Rgb<100,100,150>,30>,Bump<Int<0>,Int<4000>>>,TrFade<250>,AlphaL<HumpFlickerL<Rgb<100,100,150>,30>,Bump<Int<0>,Int<5000>>>,TrBoing<1000,7>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrInstant,TransitionLoopL<TrWaveX<Cyan,Int<500>,Int<10>,Int<1000>,Int<10>>>,TrDelay<350>,TransitionLoopL<TrWaveX<DeepSkyBlue,Int<300>,Int<300>,Int<300>,Int<10>>>,TrDelay<0>,TransitionLoopL<TrWaveX<Rgb<100,100,150>,Int<100>,Int<400>,Int<100>,Int<10>>>,TrDelay<350>,AlphaL<Rgb<100,100,150>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,5>>,EFFECT_PREON>>>(),
//Crystal Chamber
/* copyright Fett263 Simple (Crystal Chamber) OS7 Style
OS7.14 v3.23p
Default: Static [BaseColorArg]
1: Static [Rgb<255,255,0>]
Off Behavior: Off [Color: OffColorArg]
Lockup Effect: NoneLightning Block Effect: NoneDrag Effect: NoneMelt Effect: None */
StylePtr<Layers<RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>,InOutTrL<TrInstant,TrInstant,Black>>>(), "Stardust"},
{"KRadience;common", "KRadience/tracks/KRadience.wav",
StylePtr<Layers<
Stripes<2000,-2500,RotateColorsX<Variation,Red>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<60,0,0>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<30,0,0>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<80,0,0>>,RotateColorsX<Variation,Rgb<30,0,0>>>>,
TransitionLoopL<TrConcat<TrWaveX<RandomFlicker<RotateColorsX<Variation,Red>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<80,0,0>>,Black,300>>,Int<400>,Int<100>,Int<200>,Int<0>>,AlphaL<Red,Int<0>>,TrDelayX<Scale<SlowNoise<Int<1500>>,Int<200>,Int<1200>>>>>,
TransitionEffectL<TrConcat<TrFade<400>,Mix<SwingSpeed<400>,AudioFlickerL<Rgb<150,0,0>>,Red>,TrDelay<10000>,Mix<SwingSpeed<400>,AudioFlickerL<Rgb<150,0,0>>,Red>,TrFade<800>>,EFFECT_FORCE>,
AlphaL<Stripes<10000,-2000,HumpFlicker<Rgb<0,0,40>,Rgb<20,30,0>,50>,HumpFlicker<Blue,NavajoWhite,50>,HumpFlicker<Rgb<0,0,80>,Ivory,50>>,SwingSpeed<600>>,
LockupTrL<Layers<
AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<1000>>,Stripes<1500,2000,White,Red>,Stripes<1500,-2500,White,Red>>,Int<18000>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveStabL<Orange>,
ResponsiveBlastWaveL<White,Int<300>,Int<100>,Int<300>,Int<28000>,Int<8000>,EFFECT_CLASH>,
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<White,40>,TrFade<800>>,EFFECT_IGNITION>,
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<White,40>,TrFade<1000>>,EFFECT_RETRACTION>,
InOutTrL<TrWipeSparkTip<White,300>,TrWipeInSparkTip<White,1000>>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<BlinkingL<Blue,Int<300>,Int<500>>,Bump<Int<0>,Int<4000>>>,TrBoing<200,3>,AlphaL<BlinkingL<DodgerBlue,Int<200>,Int<500>>,Bump<Int<0>,Int<4000>>>,TrBoing<100,3>,AlphaL<BlinkingL<DeepSkyBlue,Int<100>,Int<500>>,Bump<Int<0>,Int<10000>>>,TrDelay<100>>,EFFECT_PREON>>>(),
//Crystal Chamber
StylePtr<Layers<
InOutTrL<TrInstant,TrInstant,Black>>>(), "KRadience"},
{ 0, WS281XBladePtr<129, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
WS281XBladePtr<1, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
CONFIGARRAY(presets) },
