Hi folks,
I have a N-Pixel SK Rogue Apprentice V2 saber coming and wanted to designate the always-showing crystal as a power level indicator. Green-Yellow-Red
I hope to get the configurator details from Randy at Korbanth and was interested in how I would go about doing this.
Presumably I’m going to need edit the blade configuration and set the crystal LEDs to be &style_charging in every definition?
&style_charging won’t really work on a crystal. You can use my Accent Style builder in the library and just choose “Battery Level (Green > Yellow > Red)” for both ON and OFF behavior or mix and match as you want.
Why wouldn’t &style_charge work on a crystal?
The drawback is that if it doesn’t look good, you can’t adjust it, so a style library style might be better, but it should work.
