Hello, I seem to have a problem with my lightsaber. Until recently, there was no problem, but since sometime, even when using the same soundfont, there is a more crackling sound. When I googled it, I thought it might be a charging problem. Even after fully charging the battery, the problem persists.
I tried cleaning the speaker side and changing the volume, but the problem is the same. Is it a problem with the speaker itself? So should I replace the speakers?
How can I fix this
here is part of my top section
#define NUM_BLADES 2
#define VOLUME 1300
#define CLASH_THRESHOLD_G 1.2
#define FILTER_ORDER 8
