Can someone please look at the code for my multiphase blade?
I’ve spent hours and need help
I used the library to get code for a jedi survivor type blade with 9 different alt fonts
I also used the library to get the crystal chamber to mimic the main blade when on.
It compiles in Arduino, no error in font directory and the saber works fine.
But something is wrong with the coding it compiles without a closing } bracket at the end.
I’m probably pushing the limits with 9 alt fonts, is it a bug maybe? Too many Alt fonts?
#define NUM_BLADES 2
#define VOLUME 2250
#define CLASH_THRESHOLD_G 3.0
#define MOTION_TIMEOUT 60 * 10 * 1000 // keeps motion chip active for 10 minutes while blade is Off
#define FETT263_THRUST_ON // enables Thrust On Ignition
#define FETT263_SWING_ON // enables Swing On Ignition
#define FETT263_TWIST_ON // enables Twist On Ignition
#define FETT263_TWIST_OFF // enables Twist Off Retraction
#define SAVE_STATE
#include"../props/saber_fett263_buttons.h"
Preset presets[] =
{"Cal1;common", "Cal1/tracks/track.wav",
OS7.14 v3.23p
Multi Phase (Original - Color Change) Transition: Instant, Time: 200
Default: Cal Kestis Survivor Blue [BaseColorArg]
1: Cal Kestis Survivor Cyan [Rgb<0,255,255>]
2: Cal Kestis Survivor Green [Rgb<0,255,0>]
3: Cal Kestis Survivor Magenta [Rgb<255,0,255>]
4: Cal Kestis Survivor Orange [Rgb<255,97,0>]
5: Cal Kestis Survivor Purple [Rgb<115,15,240>]
6: Cal Kestis Survivor Silver [Rgb<100,100,150>]
7: Cal Kestis Survivor Yellow [Rgb<255,255,0>]
8: Cal Kestis Survivor Red [Rgb<255,0,255>]
Multi Phase Control: use Color Change with COLOR_CHANGE_DIRECT define (to enable click-to-change).
Lockup Effect:
0: mainLockMulti0Shape - Begin: Real Clash - Style: Intensity AudioFlicker - End: Ripple
[Color: LockupColorArg]
Lightning Block Effect:
[Color: LBColorArg]
Drag Effect:
[Color: DragColorArg]
Melt Effect:
[Color: StabColorArg]
Stab Effect: Normal Stab [Color: StabColorArg]
Blast Effect (Randomly Selected): Responsive Blast Wave (Random), Blast Ripple Fade, Responsive Blast Fade (Random), Responsive Blast Wave (Large) [Color: BlastColorArg]
Clash Effect: Real Clash V2 [Color: ClashColorArg]
StylePtr<Layers<
ColorChange<TrInstant,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<8000>,Int<3000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<-2600>,Int<-3600>>,RgbArg<BASE_COLOR_ARG,Blue>,Mix<Int<12000>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,Pulsing<RgbArg<BASE_COLOR_ARG,Blue>,Mix<Int<8000>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,1400>>,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<10000>,Int<5000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<-2000>,Int<-3000>>,Cyan,Mix<Int<12000>,Black,Cyan>,Pulsing<Cyan,Mix<Int<8000>,Black,Cyan>,1400>>,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<4000>,Int<1800>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<2000>,Int<4000>>,Int<-2800>,Int<-4000>>,Mix<Int<16000>,Black,Green>,Mix<Sin<Int<20>,Int<22000>,Int<32768>>,Black,Green>,Mix<Int<8000>,Black,Green>>,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<9000>,Int<4000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<-2000>,Int<-3000>>,Magenta,Mix<Int<12000>,Black,Magenta>,Pulsing<Magenta,Mix<Int<8000>,Black,Magenta>,800>>,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<4000>,Int<1800>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<2000>,Int<4000>>,Int<-2800>,Int<-4000>>,Mix<Int<16000>,Black,Orange>,Mix<Sin<Int<20>,Int<20000>,Int<32768>>,Black,Orange>,Mix<Int<10000>,Black,Orange>>,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Sin<Int<20>,Int<10000>,Int<7000>>,Int<3000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<2000>,Int<4000>>,Int<-2300>,Int<-4000>>,Rgb<115,15,240>,Mix<Int<12000>,Black,Rgb<115,15,240>>,Pulsing<Rgb<115,15,240>,Mix<Int<20000>,Black,Rgb<115,15,240>>,2000>>,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<4000>,Int<1800>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<2000>,Int<4000>>,Int<-3000>,Int<-4500>>,Mix<Int<16000>,Black,Rgb<100,100,150>>,Mix<Sin<Int<20>,Int<22000>,Int<32768>>,Black,Rgb<100,100,150>>,Mix<Int<8000>,Black,Rgb<100,100,150>>>,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<3600>,Int<1600>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<2000>,Int<4000>>,Int<-2700>,Int<-4100>>,Mix<Int<16000>,Black,Yellow>,Mix<Sin<Int<20>,Int<22000>,Int<32768>>,Black,Yellow>,Mix<Int<8000>,Black,Yellow>>,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<2000>>,Int<6000>,Int<2000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<4000>>,Int<-2600>,Int<-3600>>,Red,Mix<Int<12000>,Black,Red>,Pulsing<Red,Mix<Int<8000>,Black,Red>,1000>>>,
SyncAltToVarianceL,
TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,DarkOrange>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,
TransitionEffectL<TrRandom<TrWaveX<RgbArg<BLAST_COLOR_ARG,White>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>,TrConcat<TrInstant,AlphaL<RgbArg<BLAST_COLOR_ARG,White>,Bump<Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>,Int<6000>>>,TrCenterWipeX<Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>>,AlphaL<Remap<CenterDistF<Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>>,Stripes<1600,-2000,RgbArg<BLAST_COLOR_ARG,White>,Mix<Int<2096>,Black,RgbArg<BLAST_COLOR_ARG,White>>>>,Bump<Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>,Int<32000>>>,TrJoin<TrSmoothFade<50>,TrCenterWipeX<Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<3000>,Int<29000>>>>>,TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Scale<EffectPosition<EFFECT_BLAST>,Int<9000>,Int<13000>>>,RgbArg<BLAST_COLOR_ARG,White>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,White>>>,TrFade<300>>,TrWaveX<RgbArg<BLAST_COLOR_ARG,White>,Int<200>,Int<100>,Int<400>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>>,EFFECT_BLAST>,
TransitionEffectL<TrSelect<Scale<ClashImpactF<>,Int<0>,Int<4>>,TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<8000>,Int<12000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,TrWaveX<RgbArg<CLASH_COLOR_ARG,White>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1500,-3000,RgbArg<CLASH_COLOR_ARG,White>,Mix<Int<16384>,Black,RgbArg<CLASH_COLOR_ARG,White>>>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,White>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,White>,TrFadeX<Scale<ClashImpactF<>,Int<300>,Int<500>>>>>,EFFECT_CLASH>,
LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,White>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1200,-3600,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>,RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>>,Int<30>,Scale<Sum<ClashImpactF<>,SwingSpeed<600>>,Int<50>,Int<200>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,White>,AudioFlicker<RgbArg<LB_COLOR_ARG,White>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,White>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,White>,TrFade<400>>>,
LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,White>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,White>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG>,
LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<-88>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>>,
TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<300>>,EFFECT_BATTERY_LEVEL>>>(),
/* copyright Fett263 CustomBlade (Crystal Chamber) OS7 Style
OS7.14 v3.23p
Off Behavior: Solid Color [Color: BaseColorArg]
Lockup Effect: NoneLightning Block Effect: NoneDrag Effect: NoneMelt Effect: None */
StylePtr<Layers<ColorChange<TrInstant,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<8000>,Int<3000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<-2600>,Int<-3600>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<12000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Pulsing<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<8000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,1400>>,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<10000>,Int<5000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<-2000>,Int<-3000>>,Rgb<0,255,255>,Mix<Int<12000>,Black,Rgb<0,255,255>>,Pulsing<Rgb<0,255,255>,Mix<Int<8000>,Black,Rgb<0,255,255>>,1400>>,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<4000>,Int<1800>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<2000>,Int<4000>>,Int<-2800>,Int<-4000>>,Mix<Int<16000>,Black,Rgb<0,255,0>>,Mix<Sin<Int<20>,Int<22000>,Int<32768>>,Black,Rgb<0,255,0>>,Mix<Int<8000>,Black,Rgb<0,255,0>>>,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<9000>,Int<4000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<-2000>,Int<-3000>>,Rgb<255,0,255>,Mix<Int<12000>,Black,Rgb<255,0,255>>,Pulsing<Rgb<255,0,255>,Mix<Int<8000>,Black,Rgb<255,0,255>>,800>>,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<4000>,Int<1800>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<2000>,Int<4000>>,Int<-2800>,Int<-4000>>,Mix<Int<16000>,Black,Rgb<255,97,0>>,Mix<Sin<Int<20>,Int<20000>,Int<32768>>,Black,Rgb<255,97,0>>,Mix<Int<10000>,Black,Rgb<255,97,0>>>,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Sin<Int<20>,Int<10000>,Int<7000>>,Int<3000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<2000>,Int<4000>>,Int<-2300>,Int<-4000>>,Rgb<115,15,240>,Mix<Int<12000>,Black,Rgb<115,15,240>>,Pulsing<Rgb<115,15,240>,Mix<Int<20000>,Black,Rgb<115,15,240>>,2000>>,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<4000>,Int<1800>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<2000>,Int<4000>>,Int<-3000>,Int<-4500>>,Mix<Int<16000>,Black,Rgb<100,100,150>>,Mix<Sin<Int<20>,Int<22000>,Int<32768>>,Black,Rgb<100,100,150>>,Mix<Int<8000>,Black,Rgb<100,100,150>>>,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<3600>,Int<1600>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<2000>,Int<4000>>,Int<-2700>,Int<-4100>>,Mix<Int<16000>,Black,Rgb<255,255,0>>,Mix<Sin<Int<20>,Int<22000>,Int<32768>>,Black,Rgb<255,255,0>>,Mix<Int<8000>,Black,Rgb<255,255,0>>>,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<2000>>,Int<6000>,Int<2000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<4000>>,Int<-2600>,Int<-3600>>,Rgb<255,0,0>,Mix<Int<12000>,Black,Rgb<255,0,0>>,Pulsing<Rgb<255,0,0>,Mix<Int<8000>,Black,Rgb<255,0,0>>,1000>>>,InOutTrL<TrInstant,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>>(),
WS281XBladePtr<3, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin6> >()
, CONFIGARRAY(presets) },
Thanks
