Converting a bladestyle to OS7
Wondering if there’s a way I can easily determine what effects are used in the Defect bladestyle from Greyscale, I’ve gone through what I could but I’m stuck on a few things like the preon and a few of the ignitions.
   { "Defect;common", "common/tracks/mercury.wav",
    StylePtr<Layers<
  //Fett263 HumpFlicker with Erratic Swing
  Mix<SwingSpeed<400>,HumpFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>,50>,HumpFlicker<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<128,0,0>>,30>>,
  //Ripple swing effect using Fett263's scaled responsive swing
  AlphaL<AlphaL<Stripes<2000,-2250,RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<60,30,0>>,Pulsing<RotateColorsX<Variation,Rgb<30,15,0>>,Black,800>>,HoldPeakF<Scale<IsLessThan<SwingSpeed<850>,Int<13600>>,Scale<SwingSpeed<850>,Int<-19300>,Int<32768>>,Int<0>>,Int<550>,Scale<SwingAcceleration<100>,Int<20000>,Int<10000>>>>,SmoothStep<Scale<Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>,Int<15000>,Int<5000>>,Int<-16000>>>,
  //Fett263 Unstable Ignition
  TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-1550,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFadeX<Percentage<WavLen<EFFECT_IGNITION>,15>>>,EFFECT_IGNITION>,
  //HumpFlicker Bright Retraction
  TransitionEffectL<TrConcat<TrFadeX<WavLen<EFFECT_RETRACTION>>,HumpFlicker<RotateColorsX<Variation,Rgb16<65535,42753,42753>>,RotateColorsX<Variation,White>,50>,TrInstant>,EFFECT_RETRACTION>,
  //Fett263 Responsive Intensity Lockup with Unstable End
  TrConcat<TrInstant,White,TrFade<650>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb16<65535,11439,0>>,Black,300>,TrFade<1000>,AudioFlickerL<BrownNoiseFlicker<RotateColorsX<Variation,Red>,Black,300>>,TrFade<1200>>,SaberBase::LOCKUP_NORMAL>,
  //Fett263 Responsive flame emitter effect, point the blade up to speed up the flame
  AlphaL<Mix<Scale<BladeAngle<19000>,Int<32768>,Int<0>>,StyleFire<Gradient<RotateColorsX<Variation,White>,RotateColorsX<Variation,Rgb16<65535,42753,42753>>,RotateColorsX<Variation,Rgb16<65535,42753,42753>>,RotateColorsX<Variation,Rgb16<65535,42753,42753>>>,RotateColorsX<Variation,Rgb<30,30,30>>,0,2,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>>,StyleFire<Gradient<RotateColorsX<Variation,Rgb16<65535,42753,42753>>,RotateColorsX<Variation,White>,RotateColorsX<Variation,White>,RotateColorsX<Variation,White>>,RotateColorsX<Variation,Rgb<30,30,30>>,0,1,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>>>,SmoothStep<Scale<SlowNoise<Int<3000>>,Int<1750>,Int<4125>>,Int<-3500>>>,
  //Responsive Stab
  //Fett263 Real Clash
  //Fett263 Intensity Drag
  //Fett263 Spark Tip Ignition and Retraction
  InOutTrL<TrJoin<TrWipeX<Percentage<WavLen<EFFECT_IGNITION>,5>>,TrSparkX<White,Int<400>,Percentage<WavLen<EFFECT_IGNITION>,5>,Int<0>>>,TrJoin<TrWipeInX<WavLen<EFFECT_RETRACTION>>,TrSparkX<White,Int<400>,WavLen<EFFECT_RETRACTION>,Int<32768>>>>,
  //Noise Responsive Sparky Hilt Postoff
  TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb16<65535,42753,42753>>,150>,SmoothStep<Scale<NoisySoundLevel,Int<-1000>,Int<9500>>,Int<-7000>>>,TrFadeX<WavLen<EFFECT_POSTOFF>>>,EFFECT_POSTOFF>,
  //Ripple Out Preon
  TransitionEffectL<TrConcat<TrFadeX<Percentage<WavLen<EFFECT_PREON>,10>>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb16<65535,42753,42753>>,Int<125>,Int<350>,Int<315>,Int<0>>>,TrDelayX<Percentage<WavLen<EFFECT_PREON>,90>>>,EFFECT_PREON>,
  //Noise Responsive Charge Up Preon
  TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb16<65535,42753,42753>>,150>,SmoothStep<Scale<NoisySoundLevel,Int<-1500>,Trigger<EFFECT_PREON,WavLen<EFFECT_PREON>,Int<0>,Int<0>>>,Int<-8000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,EFFECT_PREON>
  >>(), "defect"},
Did you look at it in the Style editor?
Copy from Layers< until the end …>>,EFFECT_PREON>> (don’t forget that last bracket > )
and paste it here:
Click the Submit button, then you can isolate the parts by clicking on them in the right hand column and see what makes it tick.
