Excuse my very bad English! I am using the Fett263 OS7.14 Style Editor and have revised my CONFIG_TOP. Now it works great with the Multiphase Styles and Sounds. I can change a color style and also the corresponding altNNN tones with simple gestures (SUPER COOL). Problem number 1 “When I use the color wheel, the color is saved on the SD card. I can’t turn this off and go back to the original colors.” Because I use a custom color for some styles: “255,160,0”. Unless I delete the data (for color and more) on the SD card. If I write-protect the saving on the SD card, I can no longer change the colors. But I want to keep using the color wheel. Is there a way to turn off saving or restore the original color? Number 2 "I really like using the “Stab” function (not to be confused with Drag, Melt) for a finishing move. Unfortunately this function no longer works. It would be great if someone could help me.
We need to see your entire config, the features you’re asking about are controlled in the style code. I recommend using pastebin.com.
ColorChange is based on the style, if your styles are from my library using Color Arguments, then you can use the Color List with Color Zoom as described in the controls for my prop to get to any color.
Stab is a style (and sound) if you want Stab effects be sure to include in the style.
When the blade is on, I press the power button 4 x, then I can choose different colors when turning the sword. The color I then choose is saved. I can’t go back to my previous color. I’m always bad at translating, sorry.
I put “STAB” on the tip of the blade so that I can stab forward with momentum and the tip then “flickers”, not against the wall but with momentum forward. I wrote the styles with the new OS7.14. But as a non-programmer and a bad English speaker, I’m really having problems. Thanks for the answer.
As I noted, these features are controlled in your style, so post your full config (use pastebin.com) and point out which preset you’re asking about and we can have look.
If you save a color change, you can’t “go back” after it’s saved. You can “revert” while still in color change, this undoes the change BEFORE it saves. Once save a new color you would have to go in and select the color again. As noted above, refer to the controls for my prop under Color Change for how to do.
Thank you very much for your help, this answers one question and I just wanted to say that I am very happy, it is incredibly fun with the new functions.
I will post a complete configuration via this link. Thanks again
