#define VOLUME 1800
#define CLASH_THRESHOLD_G 3.0
#define FETT263_THRUST_ON
#define FETT263_SWING_ON
#define FETT263_SWING_ON_SPEED 450
#define FETT263_TWIST_ON
#define IDLE_OFF_TIME 5 * 60 * 1000
#define FETT263_MAX_CLASH 16
{ "Ezra;common", "Ezra/tracks/ezra.wav",
/* copyright Fett263 Ezra Bridger (Primary Blade) OS7 Style
https://fett263library.com/early-access/#Ezra Bridger
OS7.11 v2.1
Base Style: Ezra Bridger
Base Color: BaseColorArg (0)
Ignition Effect Options: Default (0): SparkTip Ignition, 1: Standard Ignition [Color: IgnitionColorArg]
Lockup Effect:
[Color: LockupColorArg]
Lightning Block Effect:
[Color: LBColorArg]
Drag Effect:
[Color: DragColorArg]
Melt Effect:
[Color: StabColorArg]
Stab Effect: AudioFlicker Stab [Color: StabColorArg]
Interactive Blast: Single Blast - Default Level (Uses Style Option 2 for Editing): 1000 ms
Interactive Blast requires blast.wav files in font. When Blast is triggered blast.wav will play, to deflect blast (blst.wav and visual effect) swing within 1000ms of blaster sound ending.
Blast Effect (Randomly Selected): Blast Wave (Sound Based), Full Blade Blast Fade [Color: BlastColorArg]
Special Ability 3: Toggle Rain Mode Uses trloop00.wav or trloop/000/000.wav (rain sounds looped)
Special Ability 7: Play Sound - Ignite Uses quote01.wav or quote/001/000.wav
StylePtr<Layers<AudioFlicker<Stripes<23000,-1300,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<11284>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,ColorSelect<EffectIncrementF<EFFECT_USER3,Int<2>>,TrFade<100>,AlphaL<White,Int<0>>,AlphaL<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,SparkleF<300,800>>>,TransitionEffectL<TrDoEffect<TrInstant,EFFECT_SOUND_LOOP,0>,EFFECT_USER3>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrRandom<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,199,119>>,Scale<WavLen<>,Int<100>,Int<400>>,Int<100>,Scale<WavLen<>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<BLAST_COLOR_ARG,Rgb<255,199,119>>,TrFade<300>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,199,119>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,199,119>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<191,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<191,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<191,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<191,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,TransitionEffectL<TrConcat<TrDelayX<Mult<WavLen<EFFECT_INTERACTIVE_BLAST>,Int<24576>>>,AlphaL<White,Int<0>>,TrDoEffect<TrInstant,EFFECT_GAME_CHOICE>>,EFFECT_INTERACTIVE_BLAST>,TransitionEffectL<TrConcat<TrExtendX<IntArg<STYLE_OPTION2_ARG,1000>,TrInstant>,TransitionPulseL<TrDoEffect<TrInstant,EFFECT_BLAST>,ThresholdPulseF<SwingSpeed<300>,Int<16000>>>,TrInstant>,EFFECT_GAME_CHOICE>,InOutTrL<TrSelect<IntArg<IGNITION_OPTION_ARG,0>,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrDelayX<Int<1000>>,AlphaL<White,Int<0>>,TrConcat<TrInstant,AudioFlickerL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,TrFade<1200>>>,EFFECT_USER7>,TransitionEffectL<TrConcat<TrDelayX<Int<1000>>,Black,TrWipeX<Int<300>>>,EFFECT_USER7>,TransitionEffectL<TrConcat<TrDoEffectAlwaysX<TrDelayX<Int<1000>>,EFFECT_QUOTE,Int<1>,Int<-1>>,AlphaL<White,Int<0>>,TrDoEffectAlwaysX<TrInstant,EFFECT_FAST_ON,Int<-1>,Int<-1>>>,EFFECT_USER7>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>>>(),
{ "Spectre;common", "Spectre/tracks/sabine6.wav",
/* copyright Fett263 Sabine Wren (Primary Blade) OS7 Style
https://fett263library.com/early-access/#Sabine Wren
OS7.11 v2.1
Base Style: Sabine Wren
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
StylePtr<Layers<AudioFlicker<Stripes<23000,-1300,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<11565>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,ColorSelect<EffectIncrementF<EFFECT_USER3,Int<2>>,TrFade<100>,AlphaL<White,Int<0>>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<180,180,255>>,SparkleF<300,800>>>,TransitionEffectL<TrDoEffect<TrInstant,EFFECT_SOUND_LOOP,0>,EFFECT_USER3>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrRandom<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<191,255,255>>,Scale<WavLen<>,Int<100>,Int<400>>,Int<100>,Scale<WavLen<>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<BLAST_COLOR_ARG,Rgb<191,255,255>>,TrFade<300>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<191,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<191,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<180,180,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<180,180,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<180,180,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<180,180,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,TransitionEffectL<TrConcat<TrDelayX<Mult<WavLen<EFFECT_INTERACTIVE_BLAST>,Int<24576>>>,AlphaL<White,Int<0>>,TrDoEffect<TrInstant,EFFECT_GAME_CHOICE>>,EFFECT_INTERACTIVE_BLAST>,TransitionEffectL<TrConcat<TrExtendX<IntArg<STYLE_OPTION2_ARG,1000>,TrInstant>,TransitionPulseL<TrDoEffect<TrInstant,EFFECT_BLAST>,ThresholdPulseF<SwingSpeed<300>,Int<16000>>>,TrInstant>,EFFECT_GAME_CHOICE>,InOutTrL<TrSelect<IncrementWithReset<ThresholdPulseF<EffectPulseF<EFFECT_USER7>,Int<30000>>,EffectPulseF<EFFECT_RETRACTION>,Int<1>,Int<1>>,TrSelect<IntArg<IGNITION_OPTION_ARG,0>,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>>,TrInstant>,TrWipeInX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrDelayX<Int<1000>>,AlphaL<White,Int<0>>,TrConcat<TrInstant,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,200>,RandomPerLEDFlicker<Mix<Int<16384>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>>,TrFade<1200>>>,EFFECT_USER7>,TransitionEffectL<TrConcat<TrDelayX<Int<1000>>,Black,TrWipeX<Int<300>>>,EFFECT_USER7>,TransitionEffectL<TrConcat<TrDoEffectAlwaysX<TrDelayX<Int<1000>>,EFFECT_QUOTE,Int<-1>,Int<-1>>,AlphaL<White,Int<0>>,TrDoEffectAlwaysX<TrInstant,EFFECT_FAST_ON,Int<-1>,Int<-1>>>,EFFECT_USER7>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>>>(),
{ 0, WS281XBladePtr<136, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), CONFIGARRAY(presets) },
this is the whole config
