Hello there!
I have two Theory Sabers lightsabers that both have proffieboards and are two buttons. The first one I got in used the “proffieboard_v2_config.h” and then for the prop used the “saber_fett263_buttons.h”. I converted this one easily to ProffieOS7 from 5.9 and then made changes to file as need be to accommodate this OS change. My second saber has come in and seems to use some different criteria such as “proffieboard_config.h” and “saber_sa22c_buttons.h” for the prop.
I guess my first question is what is the difference between sa22c and fett263? My second question would be can I convert this one over to fett263 buttons and proffieboard_v2 config just like my other one? Trying to keep this as close as possible between the two to be more seamless when I want to make config changes. Thanks for any help you can provide!
sa22c’s prop hasn’t been updated since OS5 so there’s a lot of features missing from OS6 & 7. There’s probably too many differences to list at this point.
For information as well as set up requirements for my prop refer to this page:
You can upload any prop you want, just set it up in your config. You will need to update defines, etc. as sa22c’s prop has different defines for it. But you can change the prop and defines and upload whenever you want.
I do have a Config Helper Tool which will do all of the heavy lifting to set up your config for my prop (as well as allow you to easily customize). Just watch the videos at the top and read through the instructions and selections. Make sure you set up the SD per the Set Up Instructions, especially the required “common” folder with Voice Prompts (see above page).
