Will this work for a 3 blade setup. The main blade, 5 pixle pcb, 1 pixle for crystal chamber? The 1 pixle for crystal chamber wouldnt light up this way.
Ya that’s what I got here. I have the pixel wired on the in side. Not sure how to test it I have the resistor on the data provided by the supplier. Thank you.
I used a multimeter set on a/c. Ground to the data nothing on my data 4 pad while on. That is hooked up to the crystal. Checked my other data 1 pad that runs the blade on runs 4 volts . So it’s probably the config file ?
