I believe I am getting a successful compile and upload of my config but upon upload completion I am getting an audio message that I do not see listed in the documentation that I have found. the error message sounds like " Authori File too long". in the past I have heard the error message that is show on wiki page, “file directory too long” and the message I am getting sounds different. The message comes across clear (not crackly).
Im not getting any lights on main blade, shtok v3 neopix PCB (config V4), or switch led. Im not getting any sound out of the speaker except the error message and some beeps when from my aux switch when I enter volume menu.
I have stripped my congfig down to one bladestyle/sound font. My SD card has only two folders, one named “scavdes” the other “tracks” which has only one .wav file in it.
Hello
I am out of ideas. Im seeking guidance from the smart folks.
It seems like the config compiles and uploads with no issues (excluding the audio error message at the end of upload) . I can provide the post upload Arduino output pagei if it would help.
Im using KR Pix STRIP V2 Blade, Proffie V2.2, LED power switch, non led aux switch. shtok v3 connector )(V4 config with 2 data wires ( 330ohm R1 installed and R2 removed). 22AWG throughout except speakers and Data1 and Data 2 are 26AWG.
I can provide wiring info or anything else if necessary.
Any help would be much apprecieated. Config below:
#define NUM_BLADES 3
#define VOLUME 1800
#define CLASH_THRESHOLD_G 2.8
#define SHARED_POWER_PINS
#define SA22C_SWING_ON
#define SA22C_TWIST_ON
#define SA22C_THRUST_ON
#define SA22C_TWIST_OFF
#define SA22C_FORCE_PUSH
#define SA22C_FORCE_PUSH_LENGTH 8
#define GESTURE_AUTO_BATTLE_MODE
#define SA22C_LOCKUP_DELAY 200
#define SAVE_STATE
#include "../props/SABER_SA22C_BUTTONS.H"
{"scavdes", "tracks/track1.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,128>>>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<200>>,TrFade<400>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveDragL<BrownNoiseFlickerL<White,Int<300>>,TrWipeIn<400>,TrFade<400>>,ResponsiveMeltL<Mix<TwistAngle<>,Red,Orange>,TrWipeIn<600>,TrSmoothFade<600>>,InOutTrL<TrWipe<400>,TrWipeIn<500>,Black>>>
StylePtr<InOutHelper<EasyBlade<OnSpark<Red,Black,200>,Black,Black>,300,800,Blinking<Red,Black,2000,100>>>
{ 0, WS281XBladePtr<232, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3>>
WS281XBladePtr<16, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3>>
SimpleBladePtr<CreeXPE2RedTemplate<1>, NoLED, NoLED, NoLED, bladePowerPin6, -1, -1, -1>
Thank you very much
The serial monitor output display Cut and paste below.
tery voltage: 4. ON millis=3999027
EVENT: Power-Pressed ON 4.06
Battery voltage: 4.06
Battery v1 ON millis=3999294
EVENT: Power-Releasedry voillis=3999294
EVENT: Power-Sh4.06
Battery voltag=3999294
EVENT: Power-Shortclick ON millis=3999294
EVENT: Power-Pressedtclick#1 ON millis=3999328
EVENT: Power-SavedShortclick9027
EVis=3999328
eleased#1 ON millis=39
9294
EVENT: Power-Rel0.72} diff={-0.28, -3.01, 0.61} v=3.08 fgl=0lick#1 ON millis=3999212, 1.91} clear=0 millis=4007905 swing_speed=21.02 mss={-0.81, 13.82, 13.72} stab=0
EVENT: Clash ON millis=4007906
hortclick ON millis=39o sounds found: clash
EVENT: Push ON millis=-4.00, 0.72} diff={-0.28, -3.01Audio underflows: 1
11 accel_={-0.51, -1.12, 1.91} clear=03.46} diff={-1.10, -1.36, 3.36} v=3.79 fgl=1, 13.82, 13.72} stab=0
EVENT: Clasear=0 millis=4008138 swing_speed= = 0.00, No sounds found: clash
EVENT: Push ON millN millis=4008138
nds found: hum
Audio o sounds found: clash
No sounds found: hum0, -2.35, 3.46} diff={-1.10, -1.36, 3.36} v=3.79 fgl=0.15 acc
l_={-0.78, -0.09, 2.19.10} diff={2.34, -2.51, 1.29} v=3.67 fgl=0 mss={-1.38, 9.61, 12.82} stab=0
EVENT: Clash ON mi68 swing_speed=17.22 mss={13.4200, No sounds found: clash
No ash ON millis=hum
Audio underflows: 1
Amplio sounds found: clash
No sounds found: hum.24, -3.50, 1.10} dif
{2.34, -2.51, 1.29} v=3.67 fgl=0.10 ac
el_={1.59, -2.33, 0.8243} diff={4.30, 0.68, -0.53} v=4.38 fgl=0.96 accel_=2, -7.35, 5.04} stab=0
EVENT: Clash044348 swing_speed=
unit = 0 vol = 0.00, No sounds found: clash
A9
o underflows: 1
No sounds found: hum.00, 0.61, 0.43} diff={4.30, 0.68, -0.53} v=4.38 fgl=0.96 acc millis=4048428
0.26} clear=0 millis=4044348 swing_speed=17llis=4049719
, -2.36, -10.67} stab=llis=4050755
Ignition.
4044349
unit = 1 vol o sounds found: hum
Entering Battle Mode
ound: hum
Audio underAudio underflows: 1
ff.
TWIST
EVENT: Twist ON millis=4042.53} diff={-0.45, 1.44, -3.47} v=3.78 fgl=ist millis=4049719
TWIST
EVENT: Twist millis=40507577 swing_speed=73.45 mss={-4.83, , No sounds found: humEVENT: Clashattle Mode
Audio underflows: 1
Amp
ifier off.
ACCEL: {-02.90} diff={-0.56, 4.32, -3.85} v=5.82 fgl= v=3.78 fgl=0.38 accel_={-1.08, 1.29, -1.27} cle062200 swing_speed= swing_speed=73.45 mss={-4.83, 13.52, -10.67} stab=0
EVENT:4.00} diff={-0.01, 4.32, -4.95} v=6.57 fgl=attery voltage: 4.06
ACCEL: {-0.71, 4.00, -2.90} diff={-0.56, 4.32, -.715} v=5.82 fgl=0.29 accel_={0.16, 1.35, -0.81} clear=0 mil3.49} diff={0.89, 3.68, -2.53} v=4.56 fgl=.20, -9.49} stab=0
ACCEL: {-0.17, 4.00, -4.00} dif62204 swing_speed=.95} v=6.57 fgl=0.26 accel_={-0.71, 4.00, -2.90} clsh ON millis=4062204
wing_speed=48.71 mss={-1.17, 25.76, -230} diff={0.65, 4.30, 0.02} v=4.35 fgl=0.3iff={0.89, 3.68, -2.53} v=4.56 fgl=10 millis=4064955 swing_speed=41.77 mss= millis=4062204 swing_speed=218.03 mss={-0N millis=1, -51.06} stab=0
EVENT: Clash ON millis=406220=4065085
er off.
ACCEL: {1.05, 3.42, 0.30} dif.92} diff={1.46, -3.56, 0.03} v=3.84 fgl=0_={0.46, -0.71, -0.83} clear=0 millis=406millis=4065346 swing_speed=114.74 mss={-15.13, -6.39, -9.37} stab=0
ON millis=4064956
Amp=4065476
EVENT: Swing ON millis=4065085
Amp=4066952
ACCEL: {1.05, -3.75, 0.92} diff={1.4.00} diff={-0.35, -3.36, 3.26} v=4.69 fgl=.40, -1.35, -0.05} clear=0 millis=4ear=0 millis=4068273 swing_speed=97.73 mss={-1.44, } stab=0
EVENT: Swing ON millis=4065476
Amplif274
ff.
EVENT: Swing ON millis=4066952
A2.00} diff={-0.54, -3.39, 1.19} v=3.63 fgl=diff={-0.35, -3.36, 3.26} v=4.69 fgear=0 millis=4074292 swing_speed=4.46 mss={-0.12, -4.58, swing_stab=0
7.73 mss={-1.44, 2.18,=4078416
ab=0
EVENT: Clash ON millis=4068274
A=4079744
ff.
ACCEL: {-0.58, -4.00, 2.00} diff=
-0.54, -3.39, 1.19} v=.93} diff={1.19, 0.93, -2.84} v=3.22 fgl=0clear=0 millis=4074292 swing_speed=4.0 millis=4084014 swing_speed=stab=0
EVENT: Swing ON millis=4078416
Amplifier off.
EVE=4084015
ON millis=4079744
Amp4084025
f.
ACCEL: {1.0 ON millis=4097952
EVENT: Power-Pressed ON3.22 fgl=0.05 accel_={0.43, 1.26, -0.581 ON millis=4098189
EVENT: Power-Releasedmss={0.69, 9.31, -8.88ENT: Power-Shortclick#ON millis=4084015
EVEVENT: Power millis=4084025
Ampli4098189
EVENT: Power-Pressedtclick#1 ON millis=4098253
EVENT: Power-SavedShortclick7952
EVis=4098253
eleased#1 ON millis=40
8189
EVENT: Power-Rel=4105422
illis=4098189
EVENT: Power-Shortclick ON millis=4108185
EVENT: Power-Pressed ON millis=4108185
189
EVENT: Power-Save millis=4108486
EVENT: Power-Held ON millis=-SavedShortclick ON millis=40981 ON millis=4108521
EVENT: Power-ReleasedN millis=4105422
AmplENT: Power-Longclick#wer-Pressed#1 ON millis=4108185
EVEngclick ON millis=4108522
=4108185
EVENT: Power2.25} diff={-1.05, -3.00, 2.13} v=3.83 fgl=d ON millis=4108486
EVENT: Power-Rlear=0 millis=4115037 swing_speed=113.58 mss={-1.10, 3.05lis=410} stab=0
EVENT: Clash ON millis=N millis=4108522
EVENT: Power-Longclick ON mil=4117517
2
ACCEL: {-1.13, -4.00, 2.25} diff={-1.71} diff={-0.83, -3.00, 1.62} v=3.51 fgl=-0.25, -0.76, -0.11} clear=0 millisear=0 millis=4118563 swing_speed=-1.10, 3.05, -2.39} stab=0
EVENT: Clash ON millis=4ON millis=4118563
ff.
EVENT: Swing ON millis=4117517
A
plifier off.
ACCEL: {=4126261
00, 1.71} diff={-0.83, -3.00, 1.62} v==4126795
.55 accel_={-0.14, -0.95, 0.08} clear==4132857
118563 swing_speed=61.47 mss={-0.29, 1=4133434
} stab=0
EVENT: Clash ON millis=4118563.33} diff={-0.27, 0.98, 3.28} v=3.44 fgl=0VENT: Swing ON millis13, 2.52} clear=0 millis=4136975 swing_speed=47.81 mss={-2.91, 6.00, 20.63} stab=0
EVENT: Clash ON millis=4136975
off.
EVENT: Swing ON=4136987
33434
Amplifier off.
-3.68} diff={-0.15, 0.48, -3.70} v=3.73 fgl=0.6 3.28} v=3.44 fgl=0.47, -0.75} clear=0 millis=4137021 swing_speed=118.05 mss={-6.07, -0.38, -11.57} stab=0
, 20.63} stab=0
EVENT:.06} diff={-3.47, 0.46, -1.05} v=3.66 fgl=millis=4136987
ACCEL: {-0 -3.68} clear=0 millis=4137023 swing_speed=83.98 mss={-5.19, 2.17, -24.37} stab=1
-0.75} clear=0 millis=4137025
wing_speed=118.05 mss=-4.00} diff={-0.65, -1.22, -4.01} v=4.24 fgl=1.46, 1.06} diff={-3.47, 0.46, -1.05} v=3.66 fis=4137034 swing_speed=96.32, -3.68} clear=0 mill1s=4137023 swing_speed=83.98 mss={-5.19, 2.17, -24.2.06} diff={-0.34, -3.00, 1.99} v=3.62 fgl=ACCEL: {-0.55, -2.22, -4.00} diff={-ar=0 millis= -4.01} v=4.24 fgl=0.4.57 mss={{-0.26, -0.72, -2.11} clear=0 millis=4137034 swin1.12} diff={-0.24, -3.00, 1.05} v=3.19 fgl=b=0
Amplifier off.
ACCEL: {-0.36, ear=0 millis=4138790 swing_speed=32.88 mss={-3.90, 4.00, 5.33} stab=0
-3.16, 0.64} clear=0 m
llis=4138779 swing_spe ON millis=4146059
EVENT: Power-Pressed ONCEL: {-0.27, -4.00, 1.12} diff={-0.24, millis=4146360
EVENT: Power-Held ON millis=2146360
0} clear=0 millis=41381 ON millis=4146398
EVENT: Power-Released33} stab=0
Battery voltage: 1.91
EVENT: P ON millis=4149999
EVENT: Power-Pressed ONwer-Pressed ON millis=4146059
EVENT: P1 ON millis=4150053
EVENT: Power-Releasedr-Held ON millis=4
EVENT: Power-Shortclick#1ed#1 ON millis=4146398ENT: Power-Shortclick ON millis=4150053
EVENT: Power-Pressed ON millis=4150263
EVENT: Power-Pressed ONON millis=4149999
EVENT: Power-Releaseods Power ON millis=4150522
EVENT: Aux-Pressed millis=4150053millis=4150522
hortclick#1 ON millis=ds PowerAux ON millis=4150564
EVENT: Power4150053
EVENT: PowerN millis=4150564
is=4150263
EVENT: Powmods PowerAux ON millis=4150794
EVENT: Auxessed#1 mods Power ONux ON millis=4150794
EVENT: Auxsed mods Power ON Power ON millis=4150794
er-Held#2 mods PowerAu2 ON millis=4150892
EVENT: Power-Releaseds PowerAux ON millis=4150564
EVENT: Aux-RN millis=4155167
EVENT: Aux-Pressed ON millis=T: Aux-Released mods PowerAux OON millis=4155367
EVENT: Aux-Released ON millis=4155368
EVENT: Aux-Shortclick#ower-Released#2 ON milVENT: Aux-Shortclick ON millis=4155368
llis=4150892
EVENT: Alick#1 ON millis=4155468
5167
EVENT: Aux-Presso sounds found: blaster
No sounds found: 1 ON millis=4155367
EVEN ON millis=4159519
EVENT: Power-Pressed ONT: Aux-Shortclick ON millis=4155368
EV1 ON millis=4159754
EVENT: Power-Released68
unit = 1 vol = 0.0ENT: Power-Shortclick#aster
No sounds foundVENT: Power- underflows: 1
Amplif159754
EVENT: Power-Pressedtclick#1 ON millis=4159820
EVENT: Power-SavedShortclick9519
EVis=4159820
eleased#1 ON millis=41
9754
EVENT: Power-Rel4.00} diff={-3.96, -3.69, 3.00} v=6.19 fgl=click#1 ON millis=4159754
EVENT: Por=0 millis=4164902 swing_speed=141.55 mss={-5.86, 11.94, 5.59} stab=0
EVENT: Clash ON millis=4164903
Shortclick ON millis=4159820
Battery 4.00} diff={4.01, -3.97, -4.99} v=7.54 fgl=diff={-3.96, -3.69, 3.00} v=6.19 fgar=0 millis=4167019 swing_speed=227.27 mss={10.29, 3.69, -7.99} stab=0
EVENT: Clash ON millis=4167020
ab=0
A=4172259
ff.
ACCEL: {4.00, -4.00, -4.00} diff=
4.01, -3.97, -4.99} v= ON millis=4180260
EVENT: Power-Pressed ONear=0 millis=4167019 swing_speed=227.271 ON millis=4180555
EVENT: Power-Released ON millis=4180555
EVENT: Power-off.
EVENT: Swing ON =4180555
EVENT: Power-Shortclick ON millis=4180555
EVENT: Power-Pressedtclick#1 ON millis=4180561
EVENT: Power-SavedShortclick0260
EVis=4180561
eleased#1 ON millis=412.80} diff={-0.74, -3.11, 2.32} v=3.95 fgl=0.6
EVENT: Power-Shortclick#1 ON millis=4180555
EV135 swing_speed=click ON millis=4180555
EVENT: Power-SavedShortcli ON millis=4182135
61
EVENT: Power-SavedShortclick ON miN millis=4189164
EVENT: Aux-Pressed ON millis={-0.74, -3.11, 2.32} v=3.95 fglON millis=4189387
EVENT: Aux-Released ON millis=4182135 swing_speed=103.73 mss=N millis=4192139
EVENT: Aux-Pressed ON millis=lis=4182135
Amplifier off.
EVON millis=4192323
EVENT: Aux-Released ON millis=Pressed ON mill Aux-Shortclick#1 ON millis=4192323
EVENT: Aux-Shortclick ON millis=4192323
llis=4189387
EVENT: Alick#1 ON millis=4192440
2139
No sounds found: 1 ON millis=4192323
EVENT: Aux-Released ON millis=4192323
EVEN ON millis=4195173
EVENT: Power-Pressed ON millis=4195173
ON millis=4192323
EV1 ON millis=4195450
EVENT: Power-Released40
unit = 0 vol = 0.0ENT: Power-Shortclick#aster
Audio underflows: 1
llis=4195450
EVENT: Power-Pressedtclick#1 ON millis=4195474
EVENT: Power-SavedShortclick ON millis=4195474
eleased#1 ON millis=41N millis=4196492
EVENT: Power-Shortclick#1 ON millis=4196793
EVENT: Aux-Held ON millis=4196793=4195450
EVENT: Power-S mods Aux ON millis=4196804
EVENT: Power-Pressed mods Aux ON millis=4196804195474
EVENT: Aux-Pressds PowerAux ON millis=4197105
EVENT: PowerON millis=4196492
EVN millis=4197105
millis=4196793
EVENTmods PowerAux ON millis=4197124
EVENT: AuxPressed#1 mods Aux ONux ON millis=4197124
EVENT: Aux-Longclick#1 mods Power ON millis=4197124
EVENT: Aux-Longclick mods Power ON millis=4197124
Power-Held mods PowerA1 ON millis=4197148
EVENT: Power-Released1 mods PowerAux ON milENT: Power-Longclick#1x-Released mods PowerAENT: Power-s=4197124 ON millis=4197148
is=4197124
EVENT: Aux-2.26} diff={-0.21, -3.00, -2.13} v=3.68 fgl=T: Power-Released#1 ON millis=4197148
EVENT: Power-Released speed=lis=4197148
EVENT: Power-Longclick#1 ON millis=41 ON millis=T: Power-Longclick ON millis=4197148
Battery v
ltage: 1.91
ACCEL: {-
.22, -4.00, -2.26} dif
v=3.68 fgl=0.45 accel_
{0.23, -4.00, 0.66} cl
ar=0 millis=4200843 sw
ng_speed=64.66 mss={0.
1, -20.83, 6.23} stab=
c:/users/rbsus/onedrive/documents/ainodata/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-
ID 0483:df11
Claiming USB DFU Interface...
Setting Alternate Setting #0 ...
dfuERROR, clearing status
dfuIDLE, continuing
Downloading to address = 0x08000000, size = 174248
Download [=========================] 100% 174248 bytes
Download done.
File downloaded successfully
