Why is it I could upload a 10 blade style config 5 months ago using OS 6
and the exact same config now has to many blade styles as to get the 15 packages error?
Now I can only use 6 of the 10 blade styles ![]()
Obviously there is some difference.
Compiling the exact same files with the same version of the arduino-proffieboard should use up exactly the same number of bytes each time.
Are you using the latest version of the arduinio-proffieboard plugin?
What is āthe 15 packages error?ā
When you have too many blade styles in the config and Arduino canāt compile and gives an error 15 packages
Yes using the exact same config on the exact same
Computer with the exact same Proffieboard plugin ![]()
Then you would also get the same result.
Something must have changed.
Please post your config file.
Not sure what ā15 packages errorā means though. Maybe you are misinterpreting what the compiler is saying? Please also post the compiler output.
#define VOLUME 2800
#define CLASH_THRESHOLD_G 2.5
#define FETT263_SWING_ON
#define FETT263_SWING_ON_SPEED 365
#define FETT263_LOCKUP_DELAY 300
#define IDLE_OFF_TIME 60 * 3 * 1000
#define FETT263_MULTI_PHASE
#define FETT263_BM_DISABLE_OFF_BUTTON
#define FETT263_DUEL_MODE_SOUND
#define FETT263_MAX_CLASH 16
#define FETT263_SAY_BATTERY
#define COLORWHEEL_ZOOM
#define PROFFIEOS_MOTION_FREQUENCY 1600
#define PROFFIEOS_ACCELEROMETER_RANGE 16
{ "Enforcer;common", "common/tracks/Halotrak.wav",
StylePtr<Layers<Mix<SmoothStep<Scale<BladeAngle<>,Int<6000>,Int<24000>>,Int<10000>>,BrownNoiseFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,60>>,300>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,SteelBlue>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<0,42,128>>,RotateColorsX<Variation,Rgb<0,26,60>>>,300>,RotateColorsX<Variation,Rgb<0,13,30>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>>
,AlphaL<AlphaL<BrownNoiseFlicker<Cyan,Black,300>,SwingSpeed<400>>,SmoothStep<Int<16000>,Int<16000>>>,EffectSequence<EFFECT_POWERSAVE,AlphaL<Black,Int<3277>>,AlphaL<Black,Int<6554>>,AlphaL<Black,Int<9831>>,AlphaL<Black,Int<13108>>,AlphaL<Black,Int<16385>>,AlphaL<Black,Int<19662>>,AlphaL<Black,Int<22939>>,AlphaL<Black,Int<26216>>,AlphaL<Black,Int<29493>>,AlphaL<Black,Int<0>>>
,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Scale<BladeAngle<>,Int<32000>,Int<4000>>,Int<16000>>>,TrFade<400>>,TrFade<100>,Scale<BladeAngle<>,Int<32000>,Int<4000>>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,AlphaL<Rgb<128,0,0>,Bump<Int<0>,Int<6000>>>,ResponsiveStabL<Rgb<128,0,0>,TrWipeIn<800>,TrWipe<1000>>,EffectSequence<EFFECT_BLAST,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,LocalizedClashL<White,80,30,EFFECT_BLAST>,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,BlastL<White,200,200>,ResponsiveBlastFadeL<White,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<White,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>
,ResponsiveClashL<White,TrInstant,TrFade<400>,Int<32000>,Int<4000>>,TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<800>>,EFFECT_IGNITION>
,LockupTrL<AlphaL<BrownNoiseFlickerL<Yellow,Int<300>>,SmoothStep<Int<24000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>
,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<22000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>
,InOutTrL<TrWipeSparkTip<Cyan,500>,TrWipeInSparkTip<Magenta,1500>,Black>
,TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<4000>>>,TrFade<3000>>,EFFECT_BOOT>
,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<4000>>>,TrFade<3000>>,EFFECT_NEWFONT>
,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Int<4000>,Int<-4000>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Int<4000>,Int<4000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>>>(),
"BlueNoiseFlikrCyanUnstableAndCuttingEdgeSwing"},
{ "Metamorphose;common", "common/tracks/last.wav",
StylePtr<Layers<Mix<SmoothStep<Scale<BladeAngle<>,Int<6000>,Int<24000>>,Int<10000>>,BrownNoiseFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,60>>,300>,BrownNoiseFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,60>>,300>>,AlphaL<AlphaL<BrownNoiseFlicker<OrangeRed,Black,300>,SwingSpeed<600>>,SmoothStep<Int<16000>,Int<16000>>>,EffectSequence<EFFECT_POWERSAVE,AlphaL<Black,Int<3277>>,AlphaL<Black,Int<6554>>,AlphaL<Black,Int<9831>>,AlphaL<Black,Int<13108>>,AlphaL<Black,Int<16385>>,AlphaL<Black,Int<19662>>,AlphaL<Black,Int<22939>>,AlphaL<Black,Int<26216>>,AlphaL<Black,Int<29493>>,AlphaL<Black,Int<0>>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,DarkOrange>,Stripes<1500,-2500,White,DarkOrange>>,Int<16384>>,TrFade<800>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Blue,300>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Scale<BladeAngle<>,Int<32000>,Int<4000>>,Int<16000>>>,TrFade<400>>,TrFade<100>,Int<32000>,Int<4000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,AlphaL<Red,Bump<Int<0>,Int<6000>>>,ResponsiveStabL<Yellow,TrWipeIn<600>,TrWipe<600>>,EffectSequence<EFFECT_BLAST>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,LocalizedClashL<White,80,30,EFFECT_BLAST>,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,BlastL<White,200,200>,ResponsiveBlastFadeL<White,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<White,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,ResponsiveClashL<Magenta,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<32000>>,Int<4000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<Yellow,Int<300>>,SmoothStep<Int<26000>,Int<5000>>>,TrWipeIn<800>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<26000>,Int<5000>>>,TrWipeIn<800>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<Magenta,300>,TrWipeInSparkTip<Magenta,500>,Black>,TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<4000>>>,TrFade<3000>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<4000>>>,TrFade<3000>>,EFFECT_NEWFONT>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Int<4000>,Int<-4000>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Int<4000>,Int<4000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>>>(), "BRO"},
{ "Inquisatorius;common", "common/tracks/Halotrak.wav",
OS6.6 v4.0
This Style Contains 450 Unique Combinations
Base Style: Fallen Order Second Sister
Base Color: Rgb<255,0,0> (Gradient Color Up = Gradient: 1573)
Preon Effect Options: Default (0): Disable, 1: Emitter Heat Up, 2: Overload (Base Color)
Ignition Effect Options: Default (0): SparkTip Ignition, 1: Cycle Up, 2: Standard Ignition, 3: Lightning Strike, 4: Glitch On
PowerUp Effect Options: Default (0): Disable, 1: Unstable Power Up Forward, 2: Unstable Power Up Center Out, 3: Power Surge (Unstable V1), 4: Power Surge (Unstable V2)
Retraction Effect Options: Default (0): Standard Retraction, 1: Run Up
Melt Effect: Intensity Melt
Stab Effect: Sparking Stab
Blast Effect (Randomly Selected): Blast Wave (Random), Responsive Blast Fade (Medium), Responsive Blast Fade (Sound Based), Responsive Blast Ripple
Clash Effect: Real Clash V1
Swing Effect Options: Default (0): Pixelate Swing (Scaled Cutting Edge), 1: Unstable Swing (Scaled Cutting Edge), 2: Disable
Emitter Effect: Flickering Flare
Battery Level: Emitter Effect (Green to Red)
Battery Monitor: Passive Battery Monitor (Change Preset)
StylePtr<Layers<StripesX<Int<1500>,Scale<SlowNoise<Int<2500>>,Int<-3000>,Int<-5000>>,Gradient<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RotateColorsX<Int<1573>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,Mix<Int<10280>,Black,Gradient<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RotateColorsX<Int<1573>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>>,Gradient<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RotateColorsX<Int<1573>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,Mix<Int<2570>,Black,Gradient<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RotateColorsX<Int<1573>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>>,Gradient<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RotateColorsX<Int<1573>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>>,AlphaL<AudioFlickerL<RgbArg<EMITTER_COLOR_ARG,Rgb<0,0,255>>>,SmoothStep<IntArg<EMITTER_SIZE_ARG,4740>,Int<-6000>>>,ColorSelect<IntArg<SWING_OPTION_ARG,0>,TrInstant,AlphaL<AlphaL<RandomBlink<10000,RgbArg<SWING_COLOR_ARG,Rgb<255,0,0>>,Black>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,SmoothStep<Int<16000>,Int<16000>>>,AlphaL<AlphaL<Stripes<2000,-3000,RgbArg<SWING_COLOR_ARG,Rgb<255,0,0>>,RandomPerLEDFlicker<RgbArg<SWING_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<8192>,Black,RgbArg<SWING_COLOR_ARG,Rgb<255,0,0>>>>,RandomPerLEDFlicker<Mix<Int<3932>,Black,RgbArg<SWING_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<SWING_COLOR_ARG,Rgb<255,0,0>>>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,SmoothStep<Int<16000>,Int<16000>>>,AlphaL<Black,Int<0>>>,TransitionEffectL<TrSelect<IntArg<IGNITION_POWER_UP_ARG,0>,TrInstant,TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>>,TrFade<800>>,TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,Remap<CenterDistF<>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>>>,TrFade<800>>,TrConcat<TrInstant,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,200>,RandomPerLEDFlicker<Mix<Int<16384>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>>,TrFade<1200>>,TrConcat<TrInstant,HumpFlickerL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,40>,TrFade<1200>>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RandomPerLEDFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<MELT_SIZE_ARG,23604>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,MultiTransitionEffectL<TrRandom<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<28000>,Int<8000>>>,TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Int<10000>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<000>>,Scale<WavLen<>,Int<9000>,Int<13000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<3000>,Int<29000>>,Int<6000>>>,TrCenterWipeX<Int<100>,Scale<BladeAngle<>,Int<3000>,Int<29000>>>,Remap<CenterDistF<Scale<BladeAngle<>,Int<3000>,Int<29000>>>,Stripes<1600,-2000,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<2096>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>>,TrCenterWipeX<Int<100>,Scale<BladeAngle<>,Int<3000>,Int<29000>>>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,21523>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,21523>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,21523>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,21523>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,21523>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,21523>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,21523>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,21523>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,21523>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,21523>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,21523>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,21523>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,21523>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,21523>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,21523>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26719>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26719>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,23604>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,23604>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,23604>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrSelect<IntArg<IGNITION_OPTION_ARG,0>,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<0>>,TrColorCycleX<IgnitionTime<0>>,TrWipeX<IgnitionTime<0>>,TrConcat<TrWipeInX<Mult<IgnitionTime<0>,Int<6553>>>,RandomBlink<30000,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Black>,TrJoin<TrDelayX<Mult<IgnitionTime<0>,Int<19660>>>,TrWipeInX<Mult<IgnitionTime<230>,Int<6553>>>>,Mix<SmoothStep<Scale<SlowNoise<Int<30000>>,IntArg<EMITTER_SIZE_ARG,1000>,Sum<Int<5000>,IntArg<EMITTER_SIZE_ARG,1000>>>,Int<-3000>>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,TrWipeX<Mult<IgnitionTime<0>,Int<19660>>>>,TrConcat<TrJoin<TrDelayX<Mult<IgnitionTime<0>,Int<16384>>>,TrWipeX<Mult<IgnitionTime<0>,Int<16384>>>>,Mix<SmoothStep<NoisySoundLevel,Int<-1>>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,TrWipeX<Mult<IgnitionTime<0>,Int<16384>>>>>,TrSelect<IntArg<RETRACTION_OPTION_ARG,0>,TrWipeInX<RetractionTime<0>>,TrWipeX<RetractionTime<0>>>,Black>,TransitionEffectL<TrSelect<IntArg<PREON_OPTION_ARG,0>,TrInstant,TrConcat<TrFadeX<Mult<WavLen<EFFECT_PREON>,Int<8192>>>,AlphaL<HumpFlickerL<Red,10>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-2000>>>,TrFadeX<Mult<WavLen<EFFECT_PREON>,Int<8192>>>,AlphaL<HumpFlickerL<Orange,15>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-3000>>>,TrFadeX<Mult<WavLen<EFFECT_PREON>,Int<8192>>>,AlphaL<HumpFlickerL<White,20>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<WavLen<EFFECT_PREON>,Int<8192>>>>,TrConcat<TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<Gradient<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RotateColorsX<Int<1573>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,10>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<Gradient<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RotateColorsX<Int<1573>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,15>,SmoothStep<Sum<Int<2000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<Gradient<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RotateColorsX<Int<1573>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,20>,SmoothStep<Sum<Int<4000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrBoingX<Mult<Int<8192>,WavLen<EFFECT_PREON>>,3>>>,EFFECT_PREON>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<EMITTER_SIZE_ARG,4740>,Int<-4000>>>,TrFade<300>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<EMITTER_SIZE_ARG,4740>,Int<-4000>>>,TrFade<300>>,EFFECT_NEWFONT>>>(),"New"},
{ "Kylo;common", "common/tracks/revan.wav",
StylePtr<Layers<Stripes<2000,-2500,RotateColorsX<Variation,Red>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<60,0,0>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<30,0,0>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<80,0,0>>,RotateColorsX<Variation,Rgb<30,0,0>>>>,TransitionLoopL<TrConcat<TrWaveX<RandomFlicker<RotateColorsX<Variation,Red>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<80,0,0>>,Black,300>>,Int<400>,Int<100>,Int<200>,Int<0>>,AlphaL<Red,Int<0>>,TrDelayX<Scale<SlowNoise<Int<1500>>,Int<200>,Int<1200>>>>>,AlphaL<AlphaL<BrownNoiseFlicker<DarkOrange,Black,300>,SwingSpeed<600>>,SmoothStep<Int<16000>,Int<16000>>>,EffectSequence<EFFECT_POWERSAVE,AlphaL<Black,Int<3277>>,AlphaL<Black,Int<6554>>,AlphaL<Black,Int<9831>>,AlphaL<Black,Int<13108>>,AlphaL<Black,Int<16385>>,AlphaL<Black,Int<19662>>,AlphaL<Black,Int<22939>>,AlphaL<Black,Int<26216>>,AlphaL<Black,Int<29493>>,AlphaL<Black,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<32000>>,Int<4000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<32000>>,Int<4000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,AlphaL<OrangeRed,Bump<Int<0>,Int<6000>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,EffectSequence<EFFECT_BLAST,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,LocalizedClashL<White,80,30,EFFECT_BLAST>,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,BlastL<White,200,200>,ResponsiveBlastFadeL<White,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<White,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<32000>>,Int<4000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<Yellow,Int<300>>,SmoothStep<Int<24000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<22000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<Yellow,300>,TrWipeInSparkTip<Orange,700>,Black>,TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<4000>>>,TrFade<3000>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<4000>>>,TrFade<3000>>,EFFECT_NEWFONT>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Int<4000>,Int<-4000>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Int<4000>,Int<4000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>>>(), "Anger"},
{ "IGNITION;common", "common/tracks/Halotrak.wav",
StylePtr<Layers<ColorChange<TrColorCycle<1500>,StyleFire<BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<128,0,0>,Rgb<60,0,0>>,300>,Rgb<30,0,0>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,BrownNoiseFlicker<Blue,Rgb<0,0,60>,300>>,AlphaL<AlphaL<BrownNoiseFlicker<OrangeRed,Black,300>,SwingSpeed<600>>,SmoothStep<Int<16000>,Int<16000>>>,EffectSequence<EFFECT_POWERSAVE,AlphaL<Black,Int<3277>>,AlphaL<Black,Int<6554>>,AlphaL<Black,Int<9831>>,AlphaL<Black,Int<13108>>,AlphaL<Black,Int<16385>>,AlphaL<Black,Int<19662>>,AlphaL<Black,Int<22939>>,AlphaL<Black,Int<26216>>,AlphaL<Black,Int<29493>>,AlphaL<Black,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<32000>>,Int<4000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,AlphaL<Rgb<128,0,0>,Bump<Int<0>,Int<6000>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,EffectSequence<EFFECT_BLAST,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,LocalizedClashL<White,80,30,EFFECT_BLAST>,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,BlastL<White,200,200>,ResponsiveBlastFadeL<White,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<White,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<32000>>,Int<4000>,Int<20000>>,TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb<255,178,110>>>,TrFade<1200>>,EFFECT_IGNITION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<24000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<22000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<Red>,TrFade<800>>,EFFECT_IGNITION>,InOutTrL<TrWipeSparkTip<White,700>,TrWipeInSparkTip<White,1250>,Black>,TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<4000>>>,TrFade<3000>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<4000>>>,TrFade<3000>>,EFFECT_NEWFONT>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Int<4000>,Int<-4000>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Int<4000>,Int<4000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<White,40>,TrWipe<200>,HumpFlickerL<White,40>,TrBoing<600,3>>,EFFECT_PREON>>>(), "DuelPhaze"},
{ "Return;common", "common/tracks/last.wav",
StylePtr<Layers<Mix<SmoothStep<Scale<BladeAngle<>,Int<6000>,Int<24000>>,Int<10000>>,AudioFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>>,AudioFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>>>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,EffectSequence<EFFECT_POWERSAVE,AlphaL<Black,Int<3277>>,AlphaL<Black,Int<6554>>,AlphaL<Black,Int<9831>>,AlphaL<Black,Int<13108>>,AlphaL<Black,Int<16385>>,AlphaL<Black,Int<19662>>,AlphaL<Black,Int<22939>>,AlphaL<Black,Int<26216>>,AlphaL<Black,Int<29493>>,AlphaL<Black,Int<0>>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,DarkOrange>,Stripes<1500,-2500,White,DarkOrange>>,Int<16384>>,TrFade<800>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<OrangeRed,BrownNoiseFlicker<White,Blue,300>,50,1>,TrConcat<TrInstant,AlphaL<OrangeRed,Bump<Scale<BladeAngle<>,Int<32000>,Int<4000>>,Int<16000>>>,TrFade<400>>,TrFade<100>,Int<32000>,Int<4000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<OrangeRed,TrWipeIn<600>,TrWipe<600>>,EffectSequence<EFFECT_BLAST,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,LocalizedClashL<White,80,30,EFFECT_BLAST>,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,BlastL<White,200,200>,ResponsiveBlastFadeL<White,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<White,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,ResponsiveClashL<Red,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<32000>>,Int<6000>,Int<20000>>,TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<800>>,EFFECT_IGNITION>,LockupTrL<AlphaL<BrownNoiseFlickerL<OrangeRed,Int<300>>,SmoothStep<Int<24000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>
,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<22000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,300>,TrWipeInSparkTip<White,600>,Black>,TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<4000>>>,TrFade<3000>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<4000>>>,TrFade<3000>>,EFFECT_NEWFONT>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Int<4000>,Int<-4000>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Int<4000>,Int<4000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>>>(), "GreenAudioFlikr"},
{ "CyberAssassin;common", "common/tracks/revan.wav",
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>>,AlphaL<AlphaL<BrownNoiseFlicker<OrangeRed,Black,300>,SwingSpeed<600>>,SmoothStep<Int<16000>,Int<16000>>>,EffectSequence<EFFECT_POWERSAVE,AlphaL<Black,Int<3277>>,AlphaL<Black,Int<6554>>,AlphaL<Black,Int<9831>>,AlphaL<Black,Int<13108>>,AlphaL<Black,Int<16385>>,AlphaL<Black,Int<19662>>,AlphaL<Black,Int<22939>>,AlphaL<Black,Int<26216>>,AlphaL<Black,Int<29493>>,AlphaL<Black,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Int<32000>,Int<4000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Int<32000>,Int<4000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,AlphaL<DarkOrange,Bump<Int<0>,Int<6000>>>,ResponsiveStabL<Orange,TrWipeIn<800>,TrWipe<600>>,EffectSequence<EFFECT_BLAST,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,LocalizedClashL<White,80,30,EFFECT_BLAST>,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,BlastL<White,200,200>,ResponsiveBlastFadeL<White,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<White,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Int<32000>,Int<4000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<Yellow,Int<300>>,SmoothStep<Int<24000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<22000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<DarkOrange,500>,TrWipeInSparkTip<DarkOrange,1500>,Black>,TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<4000>>>,TrFade<3000>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<4000>>>,TrFade<3000>>,EFFECT_NEWFONT>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Int<4000>,Int<-4000>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Int<4000>,Int<4000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>>>(), "Red"},
{"Desimate;common", "common/tracks/HaloTrax.wav",
/* copyright Fett263 Build a Dual Phase / Split Blade (Primary Blade) OS6 Style
https://fett263.com/fett263-proffieOS6-style-library.html#Build a Dual Phase / Split Blade
OS6.6 v3.05
This Style Contains 36 Unique Combinations
Split Blade (50/50)
Default: Fallen Order Second Sister
1: Unstable Anger
Preon Effect Options: Default (0): Emitter Heat Up, 1: Disable, 2: Pulsing (PreOn Color)
Ignition Effect Options: Default (0): Glitch On, 1: SparkTip Ignition, 2: Cycle Up
PowerUp Effect Options: Default (0): Unstable Power Up Forward, 1: Power Flash
Retraction Effect Options: Default (0): Standard Retraction, 1: Fade Out
Lockup Effect: Responsive Lockup, Begin Effect: Full Blade Flash, End Effect: Full Blade Absorb
Drag Effect: Fire Drag
Blast Effect (Randomly Selected): Blast Wave (Random), Responsive Blast Wave (Random), Responsive Blast Ripple Fade
Clash Effect: Responsive Clash
Swing Effect: Pixelate Swing (Scaled Cutting Edge)
Emitter Effect: Unstable Flare
StylePtr<Layers<Mix<SmoothStep<Int<16384>,Int<45935>>,StripesX<Int<1500>,Scale<SlowNoise<Int<2500>>,Int<-3000>,Int<-5000>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<2570>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Layers<Stripes<2000,-2500,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,Black>,BrownNoiseFlicker<RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<3855>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,200>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<3855>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>>,TransitionLoopL<TrJoin<TrDelayX<Scale<SlowNoise<Int<1500>>,Int<200>,Int<1200>>>,TrWaveX<RandomFlicker<RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,BrownNoiseFlicker<Mix<Int<10280>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,Black,300>>,Int<400>,Int<100>,Int<200>,Int<0>>>>>>,AlphaL<RandomPerLEDFlickerL<RgbArg<EMITTER_COLOR_ARG,Rgb<0,0,255>>>,SmoothStep<Scale<NoisySoundLevel,IntArg<EMITTER_SIZE_ARG,979>,Sum<IntArg<EMITTER_SIZE_ARG,979>,Int<6000>>>,Int<-6000>>>,AlphaL<AlphaL<RandomBlink<10000,RgbArg<SWING_COLOR_ARG,Rgb<255,68,0>>,Black>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,SmoothStep<Int<16000>,Int<16000>>>,TransitionEffectL<TrSelect<IntArg<IGNITION_POWER_UP_ARG,0>,TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,14,0>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,14,0>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,14,0>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,14,0>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,14,0>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,14,0>>>>>,TrFade<800>>,TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,RgbArg<IGNITION_COLOR_ARG,Rgb<255,14,0>>,TrFade<1000>>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RandomPerLEDFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,0,0>>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,MultiTransitionEffectL<TrRandom<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<28000>,Int<8000>>>,TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>,TrConcat<TrInstant,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<3000>,Int<29000>>,Int<6000>>>,TrCenterWipeX<Int<100>,Scale<BladeAngle<>,Int<3000>,Int<29000>>>,AlphaL<Remap<CenterDistF<Scale<BladeAngle<>,Int<3000>,Int<29000>>>,Stripes<1600,-2000,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<2096>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>>,Bump<Scale<BladeAngle<>,Int<3000>,Int<29000>>,Int<32000>>>,TrJoin<TrSmoothFade<50>,TrCenterWipeX<Int<100>,Scale<BladeAngle<>,Int<3000>,Int<29000>>>>>>,EFFECT_BLAST>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<Stripes<2000,3000,RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>,Mix<Sin<Int<30>>,Black,RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>>,Mix<Int<8192>,Black,RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26000>,Int<3000>>>,TrWipeIn<200>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrSelect<IntArg<IGNITION_OPTION_ARG,0>,TrConcat<TrJoin<TrDelayX<Mult<IgnitionTime<0>,Int<16384>>>,TrWipeX<Mult<IgnitionTime<0>,Int<16384>>>>,Mix<SmoothStep<NoisySoundLevel,Int<-1>>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,14,0>>>,TrWipeX<Mult<IgnitionTime<0>,Int<16384>>>>,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,14,0>>,IgnitionTime<0>>,TrColorCycleX<IgnitionTime<0>>>,TrSelect<IntArg<RETRACTION_OPTION_ARG,0>,TrWipeInX<RetractionTime<0>>,TrFadeX<RetractionTime<0>>>,Black>,TransitionEffectL<TrSelect<IntArg<PREON_OPTION_ARG,0>,TrConcat<TrFadeX<Mult<WavLen<EFFECT_PREON>,Int<8192>>>,AlphaL<HumpFlickerL<Red,10>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-2000>>>,TrFadeX<Mult<WavLen<EFFECT_PREON>,Int<8192>>>,AlphaL<HumpFlickerL<Orange,15>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-3000>>>,TrFadeX<Mult<WavLen<EFFECT_PREON>,Int<8192>>>,AlphaL<HumpFlickerL<White,20>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<WavLen<EFFECT_PREON>,Int<8192>>>>,TrInstant,TrConcat<TrFadeX<Mult<Int<4096>,WavLen<EFFECT_PREON>>>,AlphaL<PulsingL<RgbArg<PREON_COLOR_ARG,Rgb<255,14,0>>,Int<800>>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrDelayX<Mult<Int<28672>,WavLen<EFFECT_PREON>>>>>,EFFECT_PREON>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<EMITTER_SIZE_ARG,979>,Int<-4000>>>,TrFade<300>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<EMITTER_SIZE_ARG,979>,Int<-4000>>>,TrFade<300>>,EFFECT_NEWFONT>>>(),"SplitBlade"},
{ "RealFire;common", "common/tracks/Halotrak.wav",
StylePtr<Layers<Mix<Scale<BladeAngle<>,Int<32768>,Int<0>>,StyleFire<Gradient<RotateColorsX<Variation,Orange>,RotateColorsX<Variation,OrangeRed>,RotateColorsX<Variation,Red>>,RotateColorsX<Variation,Rgb<60,0,0>>,0,4,FireConfig<0,1500,5>,FireConfig<0,1500,5>,FireConfig<0,1500,5>,FireConfig<0,0,0>>,StyleFire<Gradient<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Red>>,Black,0,2,FireConfig<0,1600,30>,FireConfig<0,1600,30>,FireConfig<0,1600,30>,FireConfig<0,0,0>>>,AlphaL<AlphaL<BrownNoiseFlicker<Orange,Black,300>,SwingSpeed<600>>,SmoothStep<Int<16000>,Int<16000>>>,EffectSequence<EFFECT_POWERSAVE,AlphaL<Black,Int<3277>>,AlphaL<Black,Int<6554>>,AlphaL<Black,Int<9831>>,AlphaL<Black,Int<13108>>,AlphaL<Black,Int<16385>>,AlphaL<Black,Int<19662>>,AlphaL<Black,Int<22939>>,AlphaL<Black,Int<26216>>,AlphaL<Black,Int<29493>>,AlphaL<Black,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<32000>>,Int<4000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<32000>>,Int<4000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,AlphaL<Magenta,Bump<Int<0>,Int<6000>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,EffectSequence<EFFECT_BLAST,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,LocalizedClashL<White,80,30,EFFECT_BLAST>,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,BlastL<White,200,200>,ResponsiveBlastFadeL<White,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<White,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<32000>>,Int<4000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<Yellow,Int<300>>,SmoothStep<Int<26000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<26000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<Yellow,300>,TrWipeInSparkTip<Magenta,500>,Black>,TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<4000>>>,TrFade<3000>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<4000>>>,TrFade<3000>>,EFFECT_NEWFONT>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Int<4000>,Int<-4000>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Int<4000>,Int<4000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>>>(), "RealFire"},
{ "Foul;common", "common/tracks/last.wav",
StylePtr<Layers<StripesX<Sin<Int<12>,Int<3000>,Int<7000>>,Scale<SwingSpeed<100>,Int<75>,Int<125>>,StripesX<Sin<Int<10>,Int<1000>,Int<3000>>,Scale<SwingSpeed<100>,Int<75>,Int<100>>,Pulsing<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,20,0>>,1200>,Mix<SwingSpeed<200>,RotateColorsX<Variation,Rgb<0,120,0>>,Black>>,RotateColorsX<Variation,Rgb<0,60,0>>,Pulsing<RotateColorsX<Variation,Rgb<0,50,0>>,StripesX<Sin<Int<10>,Int<2000>,Int<3000>>,Sin<Int<10>,Int<75>,Int<100>>,RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,96,0>>>,2000>,Pulsing<RotateColorsX<Variation,Rgb<0,128,0>>,RotateColorsX<Variation,Rgb<0,5,0>>,3000>>,AlphaL<StyleFire<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,2,0>>,0,1,FireConfig<10,2000,2>,FireConfig<10,2000,2>,FireConfig<10,2000,2>,FireConfig<0,0,25>>,Int<10000>>,AlphaL<AlphaL<BrownNoiseFlicker<Green,Black,300>,SwingSpeed<600>>,SmoothStep<Int<16000>,Int<16000>>>,EffectSequence<EFFECT_POWERSAVE,AlphaL<Black,Int<3277>>,AlphaL<Black,Int<6554>>,AlphaL<Black,Int<9831>>,AlphaL<Black,Int<13108>>,AlphaL<Black,Int<16385>>,AlphaL<Black,Int<19662>>,AlphaL<Black,Int<22939>>,AlphaL<Black,Int<26216>>,AlphaL<Black,Int<29493>>,AlphaL<Black,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,EffectSequence<EFFECT_BLAST,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,LocalizedClashL<White,80,30,EFFECT_BLAST>,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,BlastL<White,200,200>,ResponsiveBlastFadeL<White,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<White,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,ResponsiveBlastWaveL<White,Int<300>,Int<100>,Int<300>,Int<32000>,Int<4000>,EFFECT_CLASH>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<24000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<22000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,500>,TrWipeInSparkTip<White,800>,Black>,TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<4000>>>,TrFade<3000>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<4000>>>,TrFade<3000>>,EFFECT_NEWFONT>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Int<4000>,Int<-4000>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Int<4000>,Int<4000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>>>(), "GreenSmoke"},
{ 0, WS2811BladePtr<132, WS2811_ACTUALLY_800kHz | WS2811_GRB>(),
CONFIGARRAY(presets)},
Button PowerButton(BUTTON_POWER, auxPin, "pow");
Button AuxButton(BUTTON_AUX, powerButtonPin, "aux");
ERROR BELOW
c:/users/nickm/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe: region `FLASH' overflowed by 15520 bytes
I donāt know how to reply so this is the only way I can figure how to post what you are asking for
These arenāt in 6.7, are you uploading the current git master? Thatās pre-OS7, so it is not the same OS.
You can get OS6.7 here
Remove this, it doesnāt belong.
This is not a valid define, if you want this feature it should be
FETT263_DUAL_MODE_SOUND
Okay I will change that one
This error means your config uses up too much Flash memory. However, you need this define, itās listed as required for Edit Mode in the Set Up Instructions it will free up more memory. But if youāre using wrong version I recommend getting OS6.7
Okay I havenāt seen that define before Iām going to add it a read that post
Itās been required in the Set Up instructions for my prop and Edit Mode since OS6 Alpha. ![]()
Sorry I havenāt been an avid reader just enough to get by. Iām just an old trucker.
I know itās just a poor excuse. But I promise Iāll read more ![]()
No worries, there was a lot in OS6, but without that define youāre wasting a large chunk of memory.
I still donāt understand why the config worked a months and a half ago on the same OS6.7 and now it donāt.
Iāve had to shorten it up by 4 blade styles
You have defines that didnāt exist in OS6, so youāre using a different OS or changed something since then, itās not apples to apples. Those defines I noted above were just added to the pre OS7 testing version.
Additional questions:
Where did you download ProffieOS?
What settings are you using in Arduino ā Tools ā USB Type? What about Arduino ā Tools ā Optimise?
If you have multiple version of ProffieOS on your computer, are you sure that Arduino opened the right one? (Because it can be stubborn and confusing about opening the wrong one in some circumstances.)
PS: The ā15 packageā thing, is a part of the installation path of the arduino compiler, itās not the actual error message. The error is this:
