Config , and numbers of blades
Hello guys, I have soldered the configuration from the screenshot. I connected 1 negative, 1 positive, and 1 data wire. However, the configuration shows that I have 3 blades, and I don’t understand that part since I only intend to use one blade. Should I modify it to set it to just 1 blade, or should I leave it as is with 3 blades?
Yes, the config should only have one blade in your case. I would go run the configurator again, then copy the config text. It changes the text as you change the diagram.
ok , thank you so much , will check it out.
The configurator generates two blades for the LEDs on the illuminated pogo pin adapter. This is specifcally for pogo pin PCBs which have two rings of LEDs; one blade for each ring.
You don’t have to do it that way, but that’s why it does that.
When you use the V3 configurator, select WS2811/Neopixel for the single blade set up.
