Hello there,
I had an installer write a style code for an accent light (red jewel on a TFU2). At the moment, he’s away and unreachable. For some reason, he made the light white. I thought i could swap “white” for “red” in the code but it didn’t work. Would someone be able to help me properly replace this code so that it pulses red instead of white? Code:
StylePtr<Layers<Pulsing<Black,RotateColorsX<Variation,Rgb<180,130,0>>,3000>,TransitionEffectL<TrConcat<TrInstant,White,TrFade<400>>,EFFECT_BLAST>,LockupTrL<AudioFlickerL<White>,TrInstant,TrFade<500>,SaberBase::LOCKUP_NORMAL>,LockupTrL<AudioFlickerL<White>,TrInstant,TrFade<500>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,TransitionEffectL<TrConcat<TrInstant,White,TrFade<400>>,EFFECT_CLASH>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<White,Int<100>>,TrFade<1200>>,EFFECT_IGNITION>,InOutTrL<TrInstant,TrInstant,Layers<Black,TransitionEffectL<TrConcat<TrInstant,RotateColorsX<Variation,White>,TrDelay<45000>,RotateColorsX<Variation,White>,TrFade<500>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrInstant,RotateColorsX<Variation,White>,TrDelay<45000>,RotateColorsX<Variation,White>,TrFade<500>>,EFFECT_NEWFONT>,TransitionEffectL<TrConcat<TrInstant,RotateColorsX<Variation,White>,TrDelay<45000>,RotateColorsX<Variation,White>,TrFade<500>>,EFFECT_BOOT>>>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<RotateColorsX<Variation,Rgb<130,130,180>>,Int<100>>,TrFade<1200>>,EFFECT_RETRACTION>>>()},
Thank you!
