Hey peeps, I was creating a new config for the ProffieOS v7.7 using the config helper tool and when I had installed the arduino plugin 3.6 installed and the v7.7 downloaded from the official release site I get the following error
Arduino: 1.8.19 (Linux), Board: "Proffieboard V2, Serial, SDCARD (SPI), 80 MHz, Smallest Code"
/home/max/.arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld:/home/max/.arduino15/packages/proffieboard/hardware/stm32l4/3.6.0/variants/STM32L433CC-ProffieboardV2/linker_scripts/STM32L433CC_FLASH.ld:224: warning: memory region `SRAM2' not declared
/home/max/.arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld: warning: changing start of section .bss by 8 bytes
fork/exec /home/max/.arduino15/packages/proffieboard/hardware/stm32l4/3.6.0/tools/linux//dfu-suffix: no such file or directory
I followed the installation guide of the arduino ide for my linux distro (ubuntu 22.0.4 LTS) am I missing something?
so I was looking at the sketch and applied the config and got the FLASH error, so I started removing the functions and the relevant preset and I’m getting the following error.
Operating System: Ubuntu 22.04.2 LTS
Kernel: Linux 5.19.0-42-generic
Architecture: x86-64
To run a 32-bit executable file on a 64-bit multi-architecture Ubuntu system, you have to add the i386 architecture and install the three library packages libc6:i386, libncurses5:i386, and libstdc++6:i386:
