i tried to add a new style but now the config has tons of errors the style i added is OMEN.
config: mysaber.h - Pastebin.com
errors: https://pastebin.com/PRa7Da7F
In file included from D:\saber\ProffieOS\ProffieOS.ino:563:
D:\saber\ProffieOS\config\mysaber.h:278:3: error: 'OS6' was not declared in this scope
278 | OS6 Fett263 Random Responsive Blast
D:\saber\ProffieOS\config\mysaber.h:346:3: error: template argument 8 is invalid
346 | >>(),
D:\saber\ProffieOS\config\mysaber.h:240:5: error: parse error in template argument list
240 | StylePtr<Layers<
241 |
242 | //OS6 Magenta AudioFlicker
243 | AudioFlicker<RotateColorsX<Variation,Rgb<130,0,215>>,RotateColorsX<Variation,Rgb<78,0,131>>>,
244 |
245 | //OS6 Unstable Deep Pink Swing
246 | AlphaL<Stripes<2500,2000,BrownNoiseFlicker<RotateColorsX<Variation,Magenta>,Black,300>,BrownNoiseFlicker<RotateColorsX<Variation,Magenta>,Black,300>,RotateColorsX<Variation,DeepPink>,BrownNoiseFlicker<RotateColorsX<Variation,DeepPink>,Black,300>>,SwingSpeed<365>>,
247 |
248 |
249 | //OS6 Fett263 Responsive Intensity Lockup Effect with Sizzle Endlock Selection
250 | ColorSelect<WavNum<EFFECT_LOCKUP_END>,TrInstant,
251 | LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>>>,TrConcat<TrExtend<50,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrExtend<3000,TrFade<300>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrFade<3000>>,
252 | TrConcat<TrInstant,White,TrFade<320>,AudioFlicker<RotateColorsX<Variation,Rgb<125,0,205>>,RotateColorsX<Variation,Rgb<53,0,101>>>,TrInstant,BrownNoiseFlicker<RotateColorsX<Variation,Rgb16<64971,17247,59477>>,Black,300>,TrFade<240>,AudioFlicker<RotateColorsX<Variation,Rgb<125,0,205>>,RotateColorsX<Variation,Rgb<53,0,101>>>,TrInstant,BrownNoiseFlicker<RotateColorsX<Variation,Rgb16<64971,17247,59477>>,Black,300>,TrFade<127>,AudioFlicker<RotateColorsX<Variation,Rgb<125,0,205>>,RotateColorsX<Variation,Rgb<53,0,101>>>,TrInstant,BrownNoiseFlicker<RotateColorsX<Variation,Rgb16<64971,17247,59477>>,Black,300>,TrFade<188>,AudioFlicker<RotateColorsX<Variation,Rgb<125,0,205>>,RotateColorsX<Variation,Rgb<53,0,101>>>,TrInstant,BrownNoiseFlicker<RotateColorsX<Variation,Rgb16<64971,17247,59477>>,Black,300>,TrFade<438>,AudioFlicker<RotateColorsX<Variation,Rgb<125,0,205>>,RotateColorsX<Variation,Rgb<53,0,101>>>,TrInstant,BrownNoiseFlicker<RotateColorsX<Variation,Rgb16<64971,17247,59477>>,Black,300>,TrFade<100>>,SaberBase::LOCKUP_NORMAL>,
253 |
254 | LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>>>,TrConcat<TrExtend<50,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrExtend<3000,TrFade<300>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrFade<3000>>,
255 | TrConcat<TrInstant,White,TrFade<315>,AudioFlicker<RotateColorsX<Variation,Rgb<125,0,205>>,RotateColorsX<Variation,Rgb<53,0,101>>>,TrInstant,BrownNoiseFlicker<RotateColorsX<Variation,DeepPink>,Black,300>,TrFade<263>,AudioFlicker<RotateColorsX<Variation,Rgb<125,0,205>>,RotateColorsX<Variation,Rgb<53,0,101>>>,TrInstant,BrownNoiseFlicker<RotateColorsX<Variation,Rgb16<64971,17247,59477>>,Black,300>,TrFade<110>,AudioFlicker<RotateColorsX<Variation,Rgb<125,0,205>>,RotateColorsX<Variation,Rgb<53,0,101>>>,TrInstant,BrownNoiseFlicker<RotateColorsX<Variation,Rgb16<64971,17247,59477>>,Black,300>,TrFade<313>,AudioFlicker<RotateColorsX<Variation,Rgb<125,0,205>>,RotateColorsX<Variation,Rgb<53,0,101>>>,TrInstant,BrownNoiseFlicker<RotateColorsX<Variation,Rgb16<64971,17247,59477>>,Black,300>,TrFade<188>,AudioFlicker<RotateColorsX<Variation,Rgb<125,0,205>>,RotateColorsX<Variation,Rgb<53,0,101>>>,TrInstant,BrownNoiseFlicker<RotateColorsX<Variation,Rgb16<64971,17247,59477>>,Black,300>,TrFade<100>>,SaberBase::LOCKUP_NORMAL>,
256 |
257 | LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>>>,TrConcat<TrExtend<50,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrExtend<3000,TrFade<300>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrFade<3000>>,
258 | TrConcat<TrInstant,White,TrFade<250>,AudioFlicker<RotateColorsX<Variation,Rgb<125,0,205>>,RotateColorsX<Variation,Rgb<53,0,101>>>,TrInstant,BrownNoiseFlicker<RotateColorsX<Variation,Red>,Black,300>,TrFade<312>,AudioFlicker<RotateColorsX<Variation,Rgb<125,0,205>>,RotateColorsX<Variation,Rgb<53,0,101>>>,TrInstant,BrownNoiseFlicker<RotateColorsX<Variation,DeepPink>,Black,300>,TrFade<125>,AudioFlicker<RotateColorsX<Variation,Rgb<125,0,205>>,RotateColorsX<Variation,Rgb<53,0,101>>>,TrInstant,BrownNoiseFlicker<RotateColorsX<Variation,DeepPink>,Black,300>,TrFade<375>,AudioFlicker<RotateColorsX<Variation,Rgb<125,0,205>>,RotateColorsX<Variation,Rgb<53,0,101>>>,TrInstant,BrownNoiseFlicker<RotateColorsX<Variation,DeepPink>,Black,300>,TrFade<312>,AudioFlicker<RotateColorsX<Variation,Rgb<125,0,205>>,RotateColorsX<Variation,Rgb<53,0,101>>>,TrInstant,BrownNoiseFlicker<RotateColorsX<Variation,DeepPink>,Black,300>,TrFade<100>>,SaberBase::LOCKUP_NORMAL>,
259 |
260 | LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>>>,TrConcat<TrExtend<50,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrExtend<3000,TrFade<300>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrFade<3000>>,
261 | TrConcat<TrInstant,White,TrFade<250>,AudioFlicker<RotateColorsX<Variation,Rgb<125,0,205>>,RotateColorsX<Variation,Rgb<53,0,101>>>,TrInstant,BrownNoiseFlicker<RotateColorsX<Variation,Magenta>,Black,300>,TrFade<312>,AudioFlicker<RotateColorsX<Variation,Rgb<125,0,205>>,RotateColorsX<Variation,Rgb<53,0,101>>>,TrInstant,BrownNoiseFlicker<RotateColorsX<Variation,Rgb16<64971,17247,59477>>,Black,300>,TrFade<125>,AudioFlicker<RotateColorsX<Variation,Rgb<125,0,205>>,RotateColorsX<Variation,Rgb<53,0,101>>>,TrInstant,BrownNoiseFlicker<RotateColorsX<Variation,Rgb16<64971,17247,59477>>,Black,300>,TrFade<312>,AudioFlicker<RotateColorsX<Variation,Rgb<125,0,205>>,RotateColorsX<Variation,Rgb<53,0,101>>>,TrInstant,BrownNoiseFlicker<RotateColorsX<Variation,Rgb16<64971,17247,59477>>,Black,300>,TrFade<250>,AudioFlicker<RotateColorsX<Variation,Rgb<125,0,205>>,RotateColorsX<Variation,Rgb<53,0,101>>>,TrInstant,BrownNoiseFlicker<RotateColorsX<Variation,Rgb16<64971,17247,59477>>,Black,300>,TrFade<100>>,SaberBase::LOCKUP_NORMAL>>,
262 |
263 | //OS6 Fett263 Responsive Lightning Block
264 | ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,
265 |
266 | //OS6 Deep Pink Noise Responsive Sparking Emitter
267 | AlphaL<RotateColorsX<Variation,DeepPink>,SmoothStep<Scale<NoisySoundLevel,Int<1500>,Int<7500>>,Int<-4000>>>,
268 |
269 |
270 | //OS6 Responsive Stab
271 | ResponsiveStabL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Red>>,TrWipeInX<Percentage<WavLen<EFFECT_STAB>,50>>,TrFadeX<Percentage<WavLen<EFFECT_STAB>,50>>>,
272 |
273 |
274 | //OS6 Random Fett263 Responsive Multi-Blast
275 | ColorSelect<RandomF,TrInstant,
276 | ResponsiveBlastL<RgbArg<BLAST_COLOR_ARG,White>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,LocalizedClashL<RgbArg<BLAST_COLOR_ARG,White>,80,30,EFFECT_BLAST>,ResponsiveBlastWaveL<RgbArg<BLAST_COLOR_ARG,White>,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,BlastL<RgbArg<BLAST_COLOR_ARG,White>,200,200>,ResponsiveBlastFadeL<RgbArg<BLAST_COLOR_ARG,White>,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<RgbArg<BLAST_COLOR_ARG,White>,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,
277 |
279 | MultiTransitionEffectL<TrRandom<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<28000>,Int<8000>>>,TrConcat<TrInstant,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<16384>,Int<6000>>>,TrFade<50>,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Int<0>>,TrSparkX<Remap<CenterDistF<EffectPosition<>>,Stripes<2000,-2000,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<2096>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>>,Int<100>,Int<300>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>>,TrConcat<TrInstant,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<16384>,Int<6000>>>,TrFade<50>,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Int<0>>,TrWaveX<Remap<CenterDistF<EffectPosition<>>,Stripes<1500,-2000,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<2096>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>>,Int<160>,Int<100>,Int<300>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>>,TrConcat<TrInstant,AlphaMixL<Bump<EffectPosition<>,Scale<WavLen<>,Int<9000>,Int<12000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<300>>,TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>,TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<000>>,Scale<WavLen<>,Int<9000>,Int<13000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<300>>>,EFFECT_BLAST>,
280 |
281 | //OS5 Fett263 Multi-Blast, blaster reflect cycles through different responsive effects (I like the look of this one the best even with the new OS6 stuff)
282 | EffectSequence<EFFECT_BLAST,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,LocalizedClashL<White,80,30,EFFECT_BLAST>,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,BlastL<White,200,200>,ResponsiveBlastFadeL<White,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<White,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,
283 |
284 | //OS6 Fett263 Real Clash
285 | Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,187,108>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,187,108>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,
286 |
287 | //OS6 Responsive Clash
288 | ResponsiveClashL<TransitionEffect<RgbArg<CLASH_COLOR_ARG,Rgb<255,225,0>>,NavajoWhite,TrInstant,TrFadeX<Percentage<WavLen<EFFECT_CLASH>,25>>,EFFECT_CLASH>,TrInstant,TrFadeX<WavLen<EFFECT_CLASH>>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
289 |
290 | //OS6 Erratic Unstable Pink Ignition Effect
291 | TransitionEffectL<TrConcat<TrInstant,HumpFlicker<BrownNoiseFlicker<RotateColorsX<Variation,DeepPink>,Black,225>,AudioFlicker<RotateColorsX<Variation,Rgb<125,0,205>>,RotateColorsX<Variation,Rgb<53,0,101>>>,35>,TrDelayX<Percentage<WavLen<>,49>>>,EFFECT_IGNITION>,
292 |
293 | //OS6 Unstable Purple Ignition Effect
294 | TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Rgb<160,60,255>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<21,0,52>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<160,60,255>>,RotateColorsX<Variation,Rgb<21,0,52>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<42,0,105>>,RotateColorsX<Variation,Rgb<21,0,52>>>>,TrFadeX<Percentage<WavLen<>,49>>>,EFFECT_IGNITION>,
295 |
296 | //OS6 Bright Retraction Effect
297 | TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<160,60,255>>,40>,TrFadeX<Percentage<WavLen<>,200>>>,EFFECT_RETRACTION>,
298 |
299 |
300 | //OS6 Fett263 Intensity Drag
301 | LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,27500>,Int<5000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,29250>,Int<5000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
302 |
303 | //OS6 Responsive Drag
304 | //LockupTrL<AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,White>,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeInX<WavLen<EFFECT_DRAG_BEGIN>>,TrFadeX<WavLen<EFFECT_DRAG_END>>,SaberBase::LOCKUP_DRAG>,
305 |
306 |
307 | //OS6 Fett263 Responsive Intensity Melt
308 | LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,OrangeRed,DarkOrange>,Mix<TwistAngle<>,OrangeRed,Orange>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<6000>>>,TrConcat<TrWipeIn<100>,AlphaL<Red,SmoothStep<Int<29000>,Int<8000>>>,TrExtend<2000,TrFade<300>>,AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<29000>,Int<8000>>>,TrFade<3000>>,TrFade<250>,SaberBase::LOCKUP_MELT>,
309 |
310 |
311 | //Fett263 Power Save, if using fett263's prop file hold Aux and click PWR while ON (pointing up) to dim blade in 25% increments.
312 | EffectSequence<EFFECT_POWERSAVE,AlphaL<Black,Int<8192>>,AlphaL<Black,Int<16384>>,AlphaL<Black,Int<24576>>,AlphaL<Black,Int<0>>>,
313 |
314 | //OS6 Reversed Ignition/Retraction
315 | InOutTrL<TrWipeInX<Percentage<WavLen<EFFECT_IGNITION>,4>>,TrWipeX<WavLen<EFFECT_RETRACTION>>>,
316 |
317 | //OS5 Reversed Ignition/Retraction
318 | //InOutTrL<TrWipeIn<135>,TrWipe<250>>,
319 |
320 | //OS6 Noise Responsive Sparky Hilt Retraction
321 | TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<125,0,205>>,150>,SmoothStep<Scale<NoisySoundLevel,Int<-1500>,Int<20000>>,Int<-4000>>>,TrFadeX<WavLen<EFFECT_POSTOFF>>>,EFFECT_RETRACTION>,
322 |
323 |
324 | //OS6 Spark-In Retraction
325 | TransitionEffectL<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,Rgb<125,0,205>>,Bump<Scale<Trigger<EFFECT_POSTOFF,Int<0>,Int<0>,Percentage<WavLen<EFFECT_POSTOFF>,4>>,Int<0>,Int<32768>>,Int<15000>>>,TrFadeX<Percentage<WavLen<EFFECT_POSTOFF>,15>>>,EFFECT_RETRACTION>,
326 |
327 |
328 | //Fett263 On-Demand Battery Level, if using fett263's prop file Hold AUX and click PWR while OFF, the battery level is represented by the location on the blade; tip = full, hilt = low and color; green = full, yellow = half, red = low
329 | TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>,
330 |
331 | //Optional/alternate Fett263 Passive Battery Monitor (fett263 prop file not required), on boot (1st line) or font change (2nd line) you will get a visual indicator at the emitter of your current battery level. This also works without a blade if you have a lit emitter or blade plug. Green is Full, Red is Low (the color will blend from Green to Red as the battery is depleted), the indicator will fade out after 3000 ms and not display again until powered down and back up or fonts change.
332 | //TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>,
333 | //TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_NEWFONT>,
334 |
335 | //OS6 Noise Responsive Charge-Up Preon
336 | TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Percentage<WavLen<>,110>,Percentage<WavLen<>,50>,Percentage<WavLen<>,50>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<125,0,205>>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Magenta>,RotateColorsX<Variation,Rgb16<14386,0,14386>>>,StyleFire<Gradient<RotateColorsX<Variation,Rgb<125,0,205>>,RotateColorsX<Variation,Magenta>,RotateColorsX<Variation,DeepPink>,RotateColorsX<Variation,DeepPink>>,RotateColorsX<Variation,Rgb<60,0,100>>,0,2,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>>>,SmoothStep<Scale<NoisySoundLevel,Int<-1000>,Int<20000>>,Int<-4000>>>,TrDelayX<Percentage<WavLen<>,110>>>,EFFECT_PREON>,
337 |
338 | //OS5 Noise Responsive Charge-Up Preon
339 | //TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<600>,Int<250>,Int<250>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<125,0,205>>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Magenta>,RotateColorsX<Variation,Rgb16<14386,0,14386>>>,StyleFire<Gradient<RotateColorsX<Variation,Rgb<125,0,205>>,RotateColorsX<Variation,Magenta>,RotateColorsX<Variation,DeepPink>,RotateColorsX<Variation,DeepPink>>,RotateColorsX<Variation,Rgb<60,0,100>>,0,2,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>>>,SmoothStep<Scale<NoisySoundLevel,Int<-1000>,Int<20000>>,Int<-4000>>>,TrDelay<635>>,EFFECT_PREON>,
340 |
341 | //OS6 Spark-Out Preon
342 | TransitionEffectL<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,Rgb<125,0,205>>,Bump<Scale<Trigger<EFFECT_PREON,WavLen<>,Percentage<WavLen<>,50>,Percentage<WavLen<>,50>>,Int<0>,Int<33768>>,Int<8000>>>,TrDelayX<WavLen<>>>,EFFECT_PREON>
343 |
344 | //OS5 Spark-Out Preon
345 | //TransitionEffectL<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,Rgb<125,0,205>>,Bump<Scale<Trigger<EFFECT_PREON,Int<500>,Int<250>,Int<250>>,Int<0>,Int<33768>>,Int<8000>>>,TrDelay<500>>,EFFECT_PREON>
346 | >>(),
D:\saber\ProffieOS\config\mysaber.h:350:2: error: expected '}' before '{' token
350 | { "Bank10", "tracks/Endgame.wav",
D:\saber\ProffieOS\config\mysaber.h:239:4: note: to match this '{'
239 | { "OMEN", "tracks/ATLA.wav",
D:\saber\ProffieOS\config\mysaber.h:31:20: note: to match this '{'
31 | Preset presets[] = {
D:\saber\ProffieOS\config\mysaber.h:350:2: error: cannot resolve overloaded function 'StylePtr' based on conversion to type 'StyleFactory*'
D:\saber\ProffieOS\config\mysaber.h:351:3511: error: expected unqualified-id before ',' token
351 | StylePtr<Layers<Stripes<3000,-3000,Rgb<100,100,150>,Rgb<25,25,40>,ColorChange<TrDelay<400>,Rgb<130,130,180>,Rgb<95,0,210>,Blue,Red,DarkOrange,Green,Yellow,Mix<TwistAngle<1>,Rgb<95,0,210>,Blue,Red,DarkOrange,Green,Yellow>>,Rgb<50,50,75>>,AlphaL<ColorChange<TrWipeIn<400>,Rgb<130,130,180>,Rgb<95,0,210>,Blue,Red,DarkOrange,Green,Yellow,Mix<TwistAngle<1>,Rgb<95,0,210>,Blue,Red,DarkOrange,Green,Yellow>>,SmoothStep<Int<4000>,Int<-6000>>>,TransitionEffectL<TrWaveX<ColorChange<TrInstant,Rgb<130,130,180>,Rgb<95,0,210>,Blue,Red,DarkOrange,Green,Yellow,White>,Int<400>,Int<100>,Int<400>,Int<32768>>,EFFECT_CHANGE>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<150>,TrWipeIn<1800>,Black>,TransitionEffectL<TrConcat<TrWaveX<Rgb<95,0,210>,Int<400>,Int<200>,Int<300>,Int<32768>>,AlphaL<PulsingL<Rgb<95,0,210>,Int<1000>>,SmoothStep<Int<2000>,Int<-3000>>>,TrDelay<1000>,AlphaL<PulsingL<Rgb<95,0,210>,Int<1000>>,SmoothStep<Int<2000>,Int<-3000>>>,TrWaveX<Blue,Int<400>,Int<200>,Int<300>,Int<32768>>,AlphaL<PulsingL<ColorSequence<400,Rgb<95,0,210>,Blue>,Int<1000>>,SmoothStep<Int<2000>,Int<-3000>>>,TrDelay<800>,AlphaL<PulsingL<ColorSequence<400,Blue,Rgb<95,0,210>>,Int<1000>>,SmoothStep<Int<2000>,Int<-3000>>>,TrWaveX<Red,Int<350>,Int<200>,Int<350>,Int<32768>>,AlphaL<PulsingL<ColorSequence<350,Blue,Rgb<95,0,210>,Red>,Int<800>>,SmoothStep<Int<2000>,Int<-3000>>>,TrDelay<800>,AlphaL<PulsingL<ColorSequence<350,Red,Blue,Rgb<95,0,210>>,Int<800>>,SmoothStep<Int<2000>,Int<-3000>>>,TrWaveX<DarkOrange,Int<350>,Int<400>,Int<350>,Int<32768>>,AlphaL<PulsingL<ColorSequence<350,Red,Blue,Rgb<95,0,210>,DarkOrange>,Int<700>>,SmoothStep<Int<2000>,Int<-3000>>>,TrDelay<700>,AlphaL<PulsingL<ColorSequence<350,DarkOrange,Red,Blue,Rgb<95,0,210>>,Int<700>>,SmoothStep<Int<2000>,Int<-3000>>>,TrWaveX<Green,Int<300>,Int<400>,Int<300>,Int<32768>>,AlphaL<PulsingL<ColorSequence<300,Red,Blue,Rgb<95,0,210>,DarkOrange,Green>,Int<600>>,SmoothStep<Int<2000>,Int<-3000>>>,TrDelay<700>,AlphaL<PulsingL<ColorSequence<300,Green,Red,Blue,Rgb<95,0,210>,DarkOrange>,Int<600>>,SmoothStep<Int<2000>,Int<-3000>>>,TrWaveX<Yellow,Int<300>,Int<400>,Int<300>,Int<32768>>,AlphaL<PulsingL<ColorSequence<250,Red,Blue,Rgb<95,0,210>,DarkOrange,Green,Yellow>,Int<400>>,SmoothStep<Int<2000>,Int<-3000>>>,TrDelay<600>,AlphaL<PulsingL<ColorSequence<200,Yellow,Red,Blue,Rgb<95,0,210>,DarkOrange,Green>,Int<500>>,SmoothStep<Int<2000>,Int<-3000>>>,TrDelay<1250>>,EFFECT_PREON>>>()},
D:\saber\ProffieOS\config\mysaber.h:353:1: error: expected unqualified-id before '{' token
353 | { "Galvanic", "tracks/MSV.wav",
D:\saber\ProffieOS\config\mysaber.h:416:2: error: expected unqualified-id before ',' token
416 | },
D:\saber\ProffieOS\config\mysaber.h:418:4: error: expected unqualified-id before '{' token
418 | { "Batt00", "tracks/TFA_Duel.wav",
D:\saber\ProffieOS\config\mysaber.h:421:1: error: expected declaration before '}' token
421 | };
