D:\Documents\Lightsaber\ProffieOS\ProffieOS.ino:1:1: error: 'updating' does not name a type
1 | updating /*
In file included from D:\Documents\Lightsaber\ProffieOS\ProffieOS.ino:348:
D:\Documents\Lightsaber\ProffieOS\common\battery_monitor.h: In constructor 'BatteryMonitor::BatteryMonitor()':
D:\Documents\Lightsaber\ProffieOS\common\battery_monitor.h:10:28: error: 'batteryLevelPin' was not declared in this scope
10 | BatteryMonitor() : reader_(batteryLevelPin,
D:\Documents\Lightsaber\ProffieOS\common\battery_monitor.h: In member function 'void BatteryMonitor::SetPinHigh(bool)':
D:\Documents\Lightsaber\ProffieOS\common\battery_monitor.h:34:15: error: 'batteryLevelPin' was not declared in this scope
34 | pinMode(batteryLevelPin, OUTPUT);
D:\Documents\Lightsaber\ProffieOS\common\battery_monitor.h:38:15: error: 'batteryLevelPin' was not declared in this scope
38 | pinMode(batteryLevelPin, INPUT);
In file included from D:\Documents\Lightsaber\ProffieOS\ProffieOS.ino:552:
D:\Documents\Lightsaber\ProffieOS\blades\ws2811_blade.h: At global scope:
D:\Documents\Lightsaber\ProffieOS\blades\ws2811_blade.h:295:47: error: 'bladePin' was not declared in this scope
295 | template<int LEDS, int CONFIG, int DATA_PIN = bladePin, class POWER_PINS = PowerPINS<bladePowerPin1, bladePowerPin2, bladePowerPin3>,
D:\Documents\Lightsaber\ProffieOS\blades\ws2811_blade.h:295:86: error: 'bladePowerPin1' was not declared in this scope
D:\Documents\Lightsaber\ProffieOS\blades\ws2811_blade.h:295:102: error: 'bladePowerPin2' was not declared in this scope
D:\Documents\Lightsaber\ProffieOS\blades\ws2811_blade.h:295:118: error: 'bladePowerPin3' was not declared in this scope
D:\Documents\Lightsaber\ProffieOS\blades\ws2811_blade.h:295:132: error: template argument 1 is invalid
D:\Documents\Lightsaber\ProffieOS\blades\ws2811_blade.h:295:132: error: template argument 2 is invalid
D:\Documents\Lightsaber\ProffieOS\blades\ws2811_blade.h:295:132: error: template argument 3 is invalid
D:\Documents\Lightsaber\ProffieOS\blades\ws2811_blade.h:308:26: error: 'bladePin' was not declared in this scope
308 | int DATA_PIN = bladePin,
D:\Documents\Lightsaber\ProffieOS\blades\ws2811_blade.h:310:40: error: 'bladePowerPin1' was not declared in this scope
310 | class POWER_PINS = PowerPINS<bladePowerPin1, bladePowerPin2, bladePowerPin3>,
D:\Documents\Lightsaber\ProffieOS\blades\ws2811_blade.h:310:56: error: 'bladePowerPin2' was not declared in this scope
D:\Documents\Lightsaber\ProffieOS\blades\ws2811_blade.h:310:72: error: 'bladePowerPin3' was not declared in this scope
D:\Documents\Lightsaber\ProffieOS\blades\ws2811_blade.h:310:86: error: template argument 1 is invalid
D:\Documents\Lightsaber\ProffieOS\blades\ws2811_blade.h:310:86: error: template argument 2 is invalid
D:\Documents\Lightsaber\ProffieOS\blades\ws2811_blade.h:310:86: error: template argument 3 is invalid
D:\Documents\Lightsaber\ProffieOS\blades\ws2811_blade.h:322:25: error: 'bladePin' was not declared in this scope
322 | int DATA_PIN = bladePin,
D:\Documents\Lightsaber\ProffieOS\blades\ws2811_blade.h:325:39: error: 'bladePowerPin1' was not declared in this scope
325 | class POWER_PINS = PowerPINS<bladePowerPin1, bladePowerPin2, bladePowerPin3>,
D:\Documents\Lightsaber\ProffieOS\blades\ws2811_blade.h:325:55: error: 'bladePowerPin2' was not declared in this scope
D:\Documents\Lightsaber\ProffieOS\blades\ws2811_blade.h:325:71: error: 'bladePowerPin3' was not declared in this scope
D:\Documents\Lightsaber\ProffieOS\blades\ws2811_blade.h:325:85: error: template argument 1 is invalid
D:\Documents\Lightsaber\ProffieOS\blades\ws2811_blade.h:325:85: error: template argument 2 is invalid
D:\Documents\Lightsaber\ProffieOS\blades\ws2811_blade.h:325:85: error: template argument 3 is invalid
In file included from D:\Documents\Lightsaber\ProffieOS\ProffieOS.ino:554:
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h:266:22: error: 'bladePowerPin1' was not declared in this scope
266 | int pin1 = bladePowerPin1,
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h:267:22: error: 'bladePowerPin2' was not declared in this scope
267 | int pin2 = bladePowerPin2,
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h:268:22: error: 'bladePowerPin3' was not declared in this scope
268 | int pin3 = bladePowerPin3,
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h:269:22: error: 'bladePin' was not declared in this scope
269 | int pin4 = bladePin>
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h: In function 'BladeBase* StringBladePtr()':
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h:287:28: error: 'bladePowerPin1' was not declared in this scope
287 | MultiChannelLED<PWMPin<bladePowerPin1, LED>,
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h:287:47: error: template argument 1 is invalid
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h:288:50: error: template argument 1 is invalid
288 | PWMPin<CLASH_PIN, CLASH_LED> >,
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h:289:12: error: 'bladePowerPin2' was not declared in this scope
289 | PWMPin<bladePowerPin2, LED>,
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h:289:31: error: template argument 1 is invalid
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h:290:12: error: 'bladePowerPin3' was not declared in this scope
290 | PWMPin<bladePowerPin3, LED>,
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h:290:31: error: template argument 1 is invalid
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h:291:12: error: 'bladePowerPin4' was not declared in this scope
291 | PWMPin<bladePowerPin4, LED>,
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h:291:31: error: template argument 1 is invalid
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h:292:12: error: 'bladePowerPin5' was not declared in this scope
292 | PWMPin<bladePowerPin5, LED>,
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h:292:31: error: template argument 1 is invalid
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h:293:12: error: 'bladePowerPin6' was not declared in this scope
293 | PWMPin<bladePowerPin6, LED>
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h:293:31: error: template argument 1 is invalid
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h:294:3: error: template argument 1 is invalid
294 | > blade;
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h:294:3: error: template argument 2 is invalid
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h:294:3: error: template argument 3 is invalid
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h:294:3: error: template argument 4 is invalid
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h:294:3: error: template argument 5 is invalid
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h:294:3: error: template argument 6 is invalid
D:\Documents\Lightsaber\ProffieOS\blades\simple_blade.h:295:10: error: cannot convert 'int*' to 'BladeBase*' in return
295 | return &blade;
| int*
In file included from D:\Documents\Lightsaber\ProffieOS\ProffieOS.ino:582:
D:\Documents\Lightsaber\ProffieOS\config\MaxLGTMaulB.h: At global scope:
D:\Documents\Lightsaber\ProffieOS\config\MaxLGTMaulB.h:334:27: error: 'bladePin' was not declared in this scope; did you mean 'blades'?
334 | { 0, WS281XBladePtr<144, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), CONFIGARRAY(presets) },
| blades
D:\Documents\Lightsaber\ProffieOS\config\MaxLGTMaulB.h:334:60: error: 'bladePowerPin2' was not declared in this scope
D:\Documents\Lightsaber\ProffieOS\config\MaxLGTMaulB.h:334:76: error: 'bladePowerPin3' was not declared in this scope
D:\Documents\Lightsaber\ProffieOS\config\MaxLGTMaulB.h:334:90: error: template argument 1 is invalid
D:\Documents\Lightsaber\ProffieOS\config\MaxLGTMaulB.h:334:90: error: template argument 2 is invalid
D:\Documents\Lightsaber\ProffieOS\config\MaxLGTMaulB.h:334:94: error: no matching function for call to 'WS281XBladePtr<144,
<expression error>
, Color8::GRB,
<expression error>
D:\Documents\Lightsaber\ProffieOS\blades\ws2811_blade.h:314:18: note: candidate: 'template<int LEDS, int DATA_PIN, Color8::Byteorder byteorder, class POWER_PINS, template<int
<anonymous>
, int
<anonymous>
, Color8::Byteorder
<anonymous>
, int
<anonymous>
, int
<anonymous>
, int
<anonymous>
, int
<anonymous>
> class PinClass, int frequency, int reset_us, int t0h, int t1h, int POWER_OFF_DELAY_MS> BladeBase* WS281XBladePtr()'
314 | class BladeBase *WS281XBladePtr() {
D:\Documents\Lightsaber\ProffieOS\blades\ws2811_blade.h:314:18: note: template argument deduction/substitution failed:
D:\Documents\Lightsaber\ProffieOS\config\MaxLGTMaulB.h:334:94: error: template argument 2 is invalid
D:\Documents\Lightsaber\ProffieOS\config\MaxLGTMaulB.h:334:94: error: template argument 4 is invalid
In file included from D:\Documents\Lightsaber\ProffieOS\ProffieOS.ino:558:
D:\Documents\Lightsaber\ProffieOS\props\prop_base.h: In member function 'float PropBase::id()':
D:\Documents\Lightsaber\ProffieOS\blades\blade_id.h:84:40: error: 'bladeIdentifyPin' was not declared in this scope
84 | #define BLADE_ID_CLASS SnapshotBladeID
<bladeIdentifyPin>
D:\Documents\Lightsaber\ProffieOS\blades\blade_id.h:92:33: note: in expansion of macro 'BLADE_ID_CLASS'
92 | #define BLADE_ID_CLASS_INTERNAL BLADE_ID_CLASS
D:\Documents\Lightsaber\ProffieOS\props\prop_base.h:354:5: note: in expansion of macro 'BLADE_ID_CLASS_INTERNAL'
354 | BLADE_ID_CLASS_INTERNAL blade_id;
D:\Documents\Lightsaber\ProffieOS\blades\blade_id.h:84:56: error: template argument 1 is invalid
<bladeIdentifyPin>
In file included from D:\Documents\Lightsaber\ProffieOS\props\saber_sa22c_buttons.h:82,
from D:\Documents\Lightsaber\ProffieOS\config\MaxLGTMaulB.h:26,
from D:\Documents\Lightsaber\ProffieOS\ProffieOS.ino:586:
D:\Documents\Lightsaber\ProffieOS\props\prop_base.h:355:26: error: request for member 'id' in 'blade_id', which is of non-class type 'int'
355 | float ret = blade_id.id();
In file included from D:\Documents\Lightsaber\ProffieOS\ProffieOS.ino:640:
D:\Documents\Lightsaber\ProffieOS\config\MaxLGTMaulB.h:339:34: error: 'powerButtonPin' was not declared in this scope; did you mean 'PowerButton'?
339 | Button PowerButton(BUTTON_POWER, powerButtonPin, "pow");
| PowerButton
D:\Documents\Lightsaber\ProffieOS\ProffieOS.ino: In member function 'virtual bool Commands::Parse(const char*, const char*)':
D:\Documents\Lightsaber\ProffieOS\ProffieOS.ino:858:23: error: 'boosterPin' was not declared in this scope
858 | digitalWrite(boosterPin, HIGH);
D:\Documents\Lightsaber\ProffieOS\ProffieOS.ino:863:23: error: 'boosterPin' was not declared in this scope
863 | digitalWrite(boosterPin, LOW);
In file included from D:\Documents\Lightsaber\ProffieOS\ProffieOS.ino:1651:
D:\Documents\Lightsaber\ProffieOS\motion\lsm6ds3h.h: In member function 'virtual void LSM6DS3H::Loop()':
D:\Documents\Lightsaber\ProffieOS\motion\lsm6ds3h.h:129:15: error: 'motionSensorInterruptPin' was not declared in this scope
129 | pinMode(motionSensorInterruptPin, INPUT);
In file included from D:\Documents\Lightsaber\ProffieOS\ProffieOS.ino:1671:
D:\Documents\Lightsaber\ProffieOS\sound\amplifier.h: In member function 'void Amplifier::Enable()':
D:\Documents\Lightsaber\ProffieOS\sound\amplifier.h:45:22: error: 'amplifierPin' was not declared in this scope; did you mean 'Amplifier'?
45 | if (!digitalRead(amplifierPin)) {
| Amplifier
D:\Documents\Lightsaber\ProffieOS\sound\amplifier.h: In member function 'virtual void Amplifier::Setup()':
D:\Documents\Lightsaber\ProffieOS\sound\amplifier.h:58:13: error: 'amplifierPin' was not declared in this scope; did you mean 'Amplifier'?
58 | pinMode(amplifierPin, OUTPUT);
| Amplifier
D:\Documents\Lightsaber\ProffieOS\sound\amplifier.h: In member function 'virtual void Amplifier::Loop()':
D:\Documents\Lightsaber\ProffieOS\sound\amplifier.h:78:15: error: 'amplifierPin' was not declared in this scope; did you mean 'Amplifier'?
78 | pinMode(amplifierPin, INPUT_ANALOG); // Let the pull-down do the work
| Amplifier
D:\Documents\Lightsaber\ProffieOS\sound\amplifier.h: In member function 'virtual bool Amplifier::Parse(const char*, const char*)':
D:\Documents\Lightsaber\ProffieOS\sound\amplifier.h:98:10: error: 'amplifierPin' was not declared in this scope; did you mean 'Amplifier'?
98 | pinMode(amplifierPin, INPUT_ANALOG); // Let the pull-down do the work
| Amplifier
In file included from D:\Documents\Lightsaber\ProffieOS\ProffieOS.ino:1673:
D:\Documents\Lightsaber\ProffieOS\common\booster.h: In member function 'void Booster::Enable()':
D:\Documents\Lightsaber\ProffieOS\common\booster.h:30:15: error: 'boosterPin' was not declared in this scope; did you mean 'Booster'?
30 | pinMode(boosterPin, OUTPUT);
| Booster
D:\Documents\Lightsaber\ProffieOS\common\booster.h: In member function 'virtual void Booster::Setup()':
D:\Documents\Lightsaber\ProffieOS\common\booster.h:41:13: error: 'boosterPin' was not declared in this scope; did you mean 'Booster'?
41 | pinMode(boosterPin, OUTPUT);
| Booster
D:\Documents\Lightsaber\ProffieOS\common\booster.h: In member function 'virtual void Booster::Loop()':
D:\Documents\Lightsaber\ProffieOS\common\booster.h:55:20: error: 'boosterPin' was not declared in this scope; did you mean 'Booster'?
55 | digitalWrite(boosterPin, LOW); // turn the booster off
| Booster
D:\Documents\Lightsaber\ProffieOS\common\booster.h: In member function 'virtual bool Booster::Parse(const char*, const char*)':
D:\Documents\Lightsaber\ProffieOS\common\booster.h:70:22: error: 'boosterPin' was not declared in this scope; did you mean 'Booster'?
70 | digitalWrite(boosterPin, LOW); // turn the booster off
| Booster
D:\Documents\Lightsaber\ProffieOS\ProffieOS.ino: In function 'void setup()':
D:\Documents\Lightsaber\ProffieOS\ProffieOS.ino:1691:11: error: 'boosterPin' was not declared in this scope; did you mean 'booster'?
1691 | pinMode(boosterPin, OUTPUT);
| booster
D:\Documents\Lightsaber\ProffieOS\ProffieOS.ino:1722:44: error: 'batteryLevelPin' was not declared in this scope; did you mean 'BatteryLevel'?
1722 | srand((rand() * 917823) ^ LSAnalogRead(batteryLevelPin));
| BatteryLevel
D:\Documents\Lightsaber\ProffieOS\ProffieOS.ino:1739:9: error: 'sdCardSelectPin' was not declared in this scope
1739 | if (sdCardSelectPin >= 0 && sdCardSelectPin < 255) {
Compilation error: 'updating' does not name a type
MaxLGTMaulB.h (65.5 KB)
