I seem to be having a problem with one font in particular on my Sabertrio when I check it in Arduino. It’s the second one called “Defect”. The first one called “Assassin” works just fine.
I’ve used the font “Defect” before, so I’m not sure why it’s giving me the error “‘HoldPeakF’ was not declared in this scope”. I’ve never seen this one before and I have no idea what it means. Here is the config file. Any ideas?
// Sabertrio Proffie Saber - Blade & Sound Font Configuration
#define NUM_BLADES 4
#define VOLUME 250
#define CLASH_THRESHOLD_G 3.4
#define ENABLE_SSD1306
#define IDLE_OFF_TIME 60*2*1000
#define MOTION_TIMEOUT 60*10*1000
#define SHARED_POWER_PINS
#define BLADE_DETECT_PIN 17
#define SAVE_PRESET
#include"../props/s3button_config.h"
Preset no_blade[] = {
{ "0-NO_BLADE","",
StylePtr<Black>(),
StylePtr<Black>(),
StylePtr<Black>(),
StylePtr<Pulsing<White,Black,1200>>()
Preset blade[] = {
{ "1-Assassin;common", "common/tracks/mars.wav",
StylePtr<Layers<
HumpFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>,50>,
//Green humpflicker
AlphaL<Stripes<2500,-2750,RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<25,60,0>>,Pulsing<RotateColorsX<Variation,Rgb<0,30,0>>,Black,800>>,SwingSpeed<375>>,
//Swing effect, rippling green
LockupTrL<Layers<
AlphaL<AudioFlickerL<Rgb<255,240,80>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
AlphaL<LemonChiffon,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
//Responsive lockup
//Responsive lightning block
AlphaL<RotateColorsX<Variation,Rgb16<21301,65535,0>>,SmoothStep<Scale<SlowNoise<Int<2500>>,Int<1000>,Int<3000>>,Int<-4000>>>,
//Sparking emitter flare
ResponsiveStabL<Red>,
//Responsive stab
//Responsive clash
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Rgb16<38402,65535,3934>>,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb16<38402,65535,3934>>,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<500>>,EFFECT_IGNITION>,
//Unstable ignition
TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb16<54757,65535,0>>>,TrFade<1000>>,EFFECT_RETRACTION>,
//Bright retraction
//Drag
//Responsive melt
InOutTrL<TrWipeSparkTip<White,250>,TrWipeInSparkTip<White,656>>,
//Spark tip ignition and retraction
TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>
StylePtr<Black>(),
StylePtr<Black>(),
StylePtr<Pulsing<White,Black,1200>>(),
{ "2-Defect;common", "common/tracks/mars.wav",
StylePtr<Layers<
//Fett263 HumpFlicker with Erratic Swing
Mix<SwingSpeed<400>,HumpFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>,50>,HumpFlicker<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<128,0,0>>,30>>,
//Ripple swing effect using Fett263's scaled responsive swing
AlphaL<AlphaL<Stripes<2000,-2250,RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<60,30,0>>,Pulsing<RotateColorsX<Variation,Rgb<30,15,0>>,Black,800>>,HoldPeakF<Scale<IsLessThan<SwingSpeed<850>,Int<13600>>,Scale<SwingSpeed<850>,Int<-19300>,Int<32768>>,Int<0>>,Int<550>,Scale<SwingAcceleration<100>,Int<20000>,Int<10000>>>>,SmoothStep<Scale<Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>,Int<15000>,Int<5000>>,Int<-16000>>>,
//Fett263 Unstable Ignition
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-1550,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFadeX<Percentage<WavLen<EFFECT_IGNITION>,15>>>,EFFECT_IGNITION>,
//HumpFlicker Bright Retraction
TransitionEffectL<TrConcat<TrFadeX<WavLen<EFFECT_RETRACTION>>,HumpFlicker<RotateColorsX<Variation,Rgb16<65535,42753,42753>>,RotateColorsX<Variation,White>,50>,TrInstant>,EFFECT_RETRACTION>,
//Fett263 Responsive Intensity Lockup with Unstable End
TrConcat<TrInstant,White,TrFade<650>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb16<65535,11439,0>>,Black,300>,TrFade<1000>,AudioFlickerL<BrownNoiseFlicker<RotateColorsX<Variation,Red>,Black,300>>,TrFade<1200>>,SaberBase::LOCKUP_NORMAL>,
//Fett263 Responsive flame emitter effect, point the blade up to speed up the flame
AlphaL<Mix<Scale<BladeAngle<19000>,Int<32768>,Int<0>>,StyleFire<Gradient<RotateColorsX<Variation,White>,RotateColorsX<Variation,Rgb16<65535,42753,42753>>,RotateColorsX<Variation,Rgb16<65535,42753,42753>>,RotateColorsX<Variation,Rgb16<65535,42753,42753>>>,RotateColorsX<Variation,Rgb<30,30,30>>,0,2,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>>,StyleFire<Gradient<RotateColorsX<Variation,Rgb16<65535,42753,42753>>,RotateColorsX<Variation,White>,RotateColorsX<Variation,White>,RotateColorsX<Variation,White>>,RotateColorsX<Variation,Rgb<30,30,30>>,0,1,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>>>,SmoothStep<Scale<SlowNoise<Int<3000>>,Int<1750>,Int<4125>>,Int<-3500>>>,
//Responsive Stab
//Fett263 Real Clash
//Fett263 Intensity Drag
//Fett263 Spark Tip Ignition and Retraction
InOutTrL<TrJoin<TrWipeX<Percentage<WavLen<EFFECT_IGNITION>,5>>,TrSparkX<White,Int<400>,Percentage<WavLen<EFFECT_IGNITION>,5>,Int<0>>>,TrJoin<TrWipeInX<WavLen<EFFECT_RETRACTION>>,TrSparkX<White,Int<400>,WavLen<EFFECT_RETRACTION>,Int<32768>>>>,
//Noise Responsive Sparky Hilt Postoff
TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb16<65535,42753,42753>>,150>,SmoothStep<Scale<NoisySoundLevel,Int<-1000>,Int<9500>>,Int<-7000>>>,TrFadeX<WavLen<EFFECT_POSTOFF>>>,EFFECT_POSTOFF>,
//Ripple Out Preon
TransitionEffectL<TrConcat<TrFadeX<Percentage<WavLen<EFFECT_PREON>,10>>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb16<65535,42753,42753>>,Int<125>,Int<350>,Int<315>,Int<0>>>,TrDelayX<Percentage<WavLen<EFFECT_PREON>,90>>>,EFFECT_PREON>,
//Noise Responsive Charge Up Preon
TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb16<65535,42753,42753>>,150>,SmoothStep<Scale<NoisySoundLevel,Int<-1500>,Trigger<EFFECT_PREON,WavLen<EFFECT_PREON>,Int<0>,Int<0>>>,Int<-8000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,EFFECT_PREON>
WS281XBladePtr<20, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4> >(),
WS281XBladePtr<20, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin5> >(),
SimpleBladePtr<CreeXPE2WhiteTemplate<550>, NoLED, NoLED, NoLED, bladePowerPin1, -1, -1, -1>()
, CONFIGARRAY(blade) },
{ NO_BLADE, WS281XBladePtr<115, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
, CONFIGARRAY(no_blade) },
