here’s my pastebin of what I’m working with: SwampFox218's Pastebin - Pastebin.com
as you can probably tell, I’ve never done anything close to this. There’s probably a super obvious and easy fix so don’t facepalm too hard when you see it! ( I already looked for similar problems on here, couldn’t find/understand the answers)
Your config has no issues.
region `FLASH' overflowed by 10048 bytes
You’ve simply run out of space.
“region `FLASH’ overflowed by 10048 bytes”
That means your config is too big! You will need to delete some presets (fonts+blade styles). It would fit on a Proffie v3.9 but not on a v2.2
ohhh I see, thanks so much!
that worked, thanks so much!
