Color change?
How do i make sure each blade style allows for color change? some of the blade styles i have don’t change colors or only go through a certain range. I’ve heard that you use color arg or something in the config.h file
The styles have to be built to use, it’s controlled in the style code itself.
My library will automatically include the Color ARG values in all styles. If you build your own styles you need to include the necessary ARG values within each style.
Do you mean the old-fashioned color change that just rotates all the colors, or do you mean “edit mode”, where you can change each color (match, clash, lockup, etc.) individually?
os 5.9 old fashioned. Updated to os 7 so issue resolved
Also, if I don’t have “say color change” active in the config file then will I still see the color changing visually on the blade or do I need those voice files to know? If I don’t have the 2 color change defines enabled will edit mode not work at all?
