If I click 4 times and get into the color wheel menu and rotate to different colors it seems to automatically save the color once selected. Even when turn off and even when I remove the battery it holds the same color. Is there a way it can go back to the original color when I turn off the saber?
These look like defines that allow you to save. I don’t have these defines and they automatically save when I change color. I would rather it NOT save the color change.
If you don’t have any of these defines, then it shouldn’t save.
(Unless your prop is forcing it somehow, what prop are you using?)
#define NUM_BLADES 2
#define NUM_BUTTONS 1
#define VOLUME 1000
#define CLASH_THRESHOLD_G 2
#define IDLE_OFF_TIME 60 * 3 * 1000
#define FETT263_DISABLE_QUOTE_PLAYER
This enables Color Change saving BUT it will also depend on the style itself. If you’re using an OS6 or OS7 style, Color Change mode is using Color Editing (ARG) values, so these changes are ALWAYS saved to the preset, there currently is no way to disable as these are ARG values being saved to presets.ini.
If you want a “temporary” change I’d recommend setting up a Multi-Phase blade in the Blade Builder on the library, Multi-Phase styles are “temporary” color/style changes that will revert when the preset is changed.
OK, got it. I was just messing around with the color wheel and couldn’t get it back to the exact blue I had it on. I enabled say color list CC so now I know what blue to get back to. I can alway re-upload the config as well.
