Hi Fett, when your new library comes out will you still be able to code by hand and use the style editor with all the new features?
Thanks
Not sure what you’re asking. The library can’t take hand coded styles, the library uses dropdowns to generate styles based on user selection, it is impossible for me to let custom code run in library, way too many variables to handle. So the new new library will not let you hand code.
You can always use the Style Editor to build your own styles, if that was what you’re asking.
