Aas the title states, designing a custom bladestyle for a custom font using Fett263 os6 bladestyle library. Center out unstable ignition, smoke blade. Upon activation saber is extremely laggy, ignition is choppy, and blasters lag the saber. Thought it was the complex style, changed to normal audioflicker, still laggy and choppy.
I browsed a few posts and checked what version I was running to make sure it was up to date, which it says it’s running proffie v3.6 in the boards manager; the only other thing it couls apparently be is the sd card ‘speed’ but i got mine from crimson dawn, so I don’t think its the SD card and I don’t know how to check because I don’t know how to access the serial manager. Anyone else having issues?
Also, would having a lot of stuff on your sd card effect its speed? I have a LOT of stuff on my sd card
The most likely cause is still sd card speed.
You can run sdtest
in the serial monitor to test your sd card.
(Note that if you have DISABLE_DIAGNOSTIC_COMMANDS
in your config file, sdtest won’t work.)
Or, I suppose you could just try a different sd card to see if that works better.
Having lots of stuff on the SD card doesn’t slow things down per se, but having lots of directory entries can. What you can do to prevent that type of slowdown is to just create a single directory in the top-level for all the extra stuff and put the extra stuff in that directory.
Note that deleted directory entries also count, so an SD card can be slow if it had lots of entries in the past.
How would i access the serial monitor?
“Time to read blocks: Average speed: 1076.07 kb/s, 12.20 simultaneous audio streams”
Hmmm. Is it possible that a really long hum or really long swing sounds would cause lag?
The hum for the saber is over 2 minutes long, and the swing h and l are also similar in length
Those aren’t terrible speeds. No, really long files are not a factor.
Have you organized your font hierarchy to be optimized for FAT32 performance?
Read the Speeding Things Up entry in the Wiki: Speeding things up · profezzorn/ProffieOS Wiki · GitHub
Have you reformatted the SD using SDFormatter? SD Memory Card Formatter | SD Association
LOL i figured it out. All my custom sounds were in stereo and i think it was using a ton of info trying to play that. Shortened my swingh and swingl, split all my sounds to mono, working like a charm now!
Note to self; that was really dumb
12.2 streams should be good enough, unless there are outliers, which I would need to see the whole output for.
i think it was a general combo of the stereo, advanced bladestyle, and insanely long hum/swing sounds that altogether messed with it; I can look into it further but its working like a charm now
