Hiya
Im using 1 button saber.
Current its holder power and clash to enter volume.
Is it possible to change this to 4 short clicks while blade is off?
I have found thr fett buttons config h file if needs changing in there…
Hiya
Technically you can edit the prop, however, you’ll need to make sure you’re not impacting other controls, especially on 1 button as my prop has a lot of functionality mapped already to the limited available controls.
Changing things around can cause other things to not work or create conflicts. But if you’re wanting to I’d siggest starting here:
Thanks Fett
Whats the EVENT_ function for a quad click? I cant seem to find an example in the .h file…
Button events can be found here:
thank you working perfectly
Glad to hear.
