Can anyone point me to where I can edit the swing sensitivity for a responsive swing effect? Using the default unstable swing effect in fett’s library, I have to swing pretty hard/fast to see the unstable effect of the swing. I want the blade to break up a little when swinging to give it an unstable or flame effect not unlike Greyscale’s Omen bladestyle.
Here is the blade style I am using from Fett’s library now (Note I am using OS7 phase 3 preview if that makes a difference).
https://fett263library.com/early-access/#Rotoscope
OS7.14 v3.1
Base Style: Hyper Responsive Rotoscope (Sequels)
Base Color: BaseColorArg (0)
Effect Reaction: Unstable Ripple Medium, AltColor3Arg, Type: Responsive Center, Direction: Normal, Duration: 2000, Consecutive Effects to Max: 2
Effect Reactions: Clash, Blast, Lockup, Lightning BlockIgnition Effect: SparkTip Ignition [Color: IgnitionColorArg]
Retraction Effect: SparkTip Retraction [Color: RetractionColorArg]
Lockup Effect:
[Color: LockupColorArg]
Lightning Block Effect:
[Color: LBColorArg]
Drag Effect:
[Color: DragColorArg]
Melt Effect:
[Color: StabColorArg]
Blast Effect (Randomly Selected): Responsive Blast Wave (Sound Based), Responsive Blast Fade (Sound Based), Responsive Blast Fade (Large) [Color: BlastColorArg]
Clash Effect: Responsive Clash [Color: ClashColorArg]
Swing Effect: Unstable Swing (Scaled Full Blade) [Color: AltColor2Arg]
Display Volume: % Blade [Color: BaseColorArg]
Special Ability 1: Play Quote
Special Ability 5: Ignite
Special Ability 6: Ignite
StylePtr<Layers<Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<14000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-4000>,Int<-400>>,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>>,ColorSelect<EffectIncrementF<EFFECT_USER1,Int<2>>,TrFade<100>,AlphaL<White,Int<0>>,AlphaL<RgbArg<ALT_COLOR3_ARG,Rgb<255,14,0>>,SparkleF<300,800>>>,AlphaL<AlphaL<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<20000>,Int<32000>>,Int<8000>>>,Stripes<1600,-1500,RandomPerLEDFlicker<Mix<Int<8000>,Black,RgbArg<ALT_COLOR3_ARG,Rgb<255,14,0>>>,RgbArg<ALT_COLOR3_ARG,Rgb<255,14,0>>>,RgbArg<ALT_COLOR3_ARG,Rgb<255,14,0>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<20000>,Int<32000>>,Int<8000>>,Int<70000>>>,HoldPeakF<Mult<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,IncrementWithReset<ThresholdPulseF<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,Int<30000>>,ThresholdPulseF<InvertF<HoldPeakF<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,Int<500>,Int<8172>>>,Int<30000>>,Int<32768>,Int<16384>>>,Int<2000>,Int<10000>>>,AlphaL<Stripes<2000,-3000,RgbArg<ALT_COLOR2_ARG,Rgb<255,50,0>>,RandomPerLEDFlicker<RgbArg<ALT_COLOR2_ARG,Rgb<255,50,0>>,Mix<Int<8192>,Black,RgbArg<ALT_COLOR2_ARG,Rgb<255,50,0>>>>,RandomPerLEDFlicker<Mix<Int<3932>,Black,RgbArg<ALT_COLOR2_ARG,Rgb<255,50,0>>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,50,0>>>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_QUOTE,Int<-1>,Int<-1>>,EFFECT_USER1>,TransitionEffectL<TrRandom<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<191,255,255>>,Scale<WavLen<>,Int<100>,Int<400>>,Int<100>,Scale<WavLen<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>,TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Scale<WavLen<>,Int<9000>,Int<13000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<191,255,255>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<191,255,255>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Int<14000>>,RgbArg<BLAST_COLOR_ARG,Rgb<191,255,255>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<191,255,255>>>>,TrFade<300>>>,EFFECT_BLAST>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<191,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<191,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<191,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<191,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<191,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<191,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,199,119>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,199,119>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,25,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,25,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,25,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,25,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,25,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,25,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,25,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,25,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,25,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,25,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrSelect<IncrementWithReset<ThresholdPulseF<Sum<EffectPulseF<EFFECT_USER5>,EffectPulseF<EFFECT_USER6>>,Int<30000>>,EffectPulseF<EFFECT_RETRACTION>,Int<1>,Int<1>>,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<191,255,255>>,BendTimePowInvX<IgnitionTime<275>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrInstant>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<191,255,255>>,BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<Int<500>>,TrInstant>,Stripes<3000,-3500,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>>,Black>,BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>>>>,TrFade<800>>,EFFECT_USER5>,TransitionEffectL<TrConcat<TrInstant,Black,TrWipeX<Int<275>>>,EFFECT_USER5>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<Int<500>>,TrInstant>,RgbArg<PREON_COLOR_ARG,Rgb<255,150,112>>,TrFade<1000>>,EFFECT_USER6>,TransitionEffectL<TrConcat<TrInstant,Black,TrWipeX<Int<275>>>,EFFECT_USER6>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_FAST_ON,Int<-1>,Int<-1>>,EFFECT_USER5>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_FAST_ON,Int<-1>,Int<-1>>,EFFECT_USER6>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrExtend<2000,TrWipe<100>>,AlphaL<RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<VolumeLevel,Int<-1>>>,TrFade<300>>,EFFECT_VOLUME_LEVEL>>>(),
