CC led going very dim when Blue
Strange issue, my CC led goes very dark almost off when the blade is plugged in.
Its fine without the blade plugged in and only affects the blue colour… any ideas…
Its a single RGB led
Affects all blade styles too
Actually all colours are going dimmer when the blade is plugged in but blue is most noticable
Most likely this due to a weak battery.
Can you measure the battery voltage when the color is dim and when it isn’t?
The battery charge is about 50% and voltage is 3.58v unplugged, difficult to get the voltage when blade is attached because its inside the hilt then
my blade config for ref
BladeConfig blades = {
{ 0, WS281XBladePtr<125, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
WS281XBladePtr<1, blade2Pin, Color8::GRB, PowerPINS >(),
SimpleBladePtr<CH2LED,NoLED, NoLED, NoLED,bladePowerPin4, -1,-1,-1>(),
SimpleBladePtr<CH1LED,NoLED, NoLED, NoLED,bladePowerPin5, -1,-1,-1>(),
Sorted, wiring error on my behalf lol
