Can't Upload Config
I just got Krossguard off a friend and I wanted to modify some of the gestures and on Arduino I verified it with no issues, but once I try to connect my saber through USB and upload it, I get this error:
Arduino: 1.8.16 (Windows 10), Board: “Proffieboard V3, Serial + Mass Storage + WebUSB, SDCARD (SDIO High Speed), 80 MHz, Smallest Code”
Sketch uses 301152 bytes (59%) of program storage space. Maximum is 507904 bytes.
dfu-util 0.9
Opening DFU capable USB device…
ID 0483:df11
Claiming USB DFU Interface…
Setting Alternate Setting #0
dfuERROR, clearing status
Last page at 0x08049867 is not writeable
the selected serial port Last page at 0x08049867 is not writeable
does not exist or your board is not connected
dfuIDLE, continuing
Downloading to address = 0x08000000, size = 301160
Start here, it looks like you don’t have the drivers set up for your Proffieboard:
Run proffie-dfu-setup.exe
That’s weird I downloaded the DFU setup already
I did run that before and still no luck I get this now:
dfu-util 0.9
ID 0483:df11
Last page at 0x08048cc7 is not writeable
dfuIDLE, continuing
Downloading to address = 0x08000000, size = 298184
the selected serial port Downloading to address = 0x08000000, size = 298184
“proffie-dfü-setup” is not signed, I had to give permission for my virus program and my firewall to install. I have Win10 but only Proffie v2.2 boards. I used the driver search program without my board being connected. Then set up the Arduino correctly + plugin for Proffie v3 and select the correct COM. Here’s another link for Arduino: https://youtu.be/XKvu6xcskIU
Sorry for my bad English ! I hope I could help and understand the problem. :slightly_smiling_face:
Alrighty I was able to figure out the problem. I should have been using V2 of the proffieboard. Once I changed the version and used a different config that used less styles it worked. Thank you all for your help!
Signing binaries is expensive unfortunately.
Yes, I know, that’s why I wrote it. I was very happy that it worked for me straight away (if you remember). I thought maybe I could help too, but he managed it. :grin:
