What’s been happening is while I’m walking around with the hilt on my hip, it will activate seemingly at random, so I figured it was probably one of the gesture ignitions. So, I deleted them out of the config (stab, swing, and twist ignitions), but it still ignites on a swing. Haven’t tested twist or stab yet. Are gesture ignitions a part of another define I should be looking at? Or just a part of battle mode now, perhaps?
Post your config, also which OS?
If it’s OS6 with my prop you can just use “Gesture Sleep”, check the controls at the top of the .h file or on this page. Fett263 ProffieOS6 Prop File (Buttons and Controls)
Gesture Sleep is designed specifically for this, it allows you to toggle gesture ignitions on or off for when you’re wearing the hilt on your hip without having to permanently disable ![]()
Using OS6. Ah, gesture sleep! I’d forgotten about that feature. I’d much rather do that, then delete defines. I’m not near a computer right now so I can’t post my config, but I know exactly what your talking about. Thank you!
Follow up: gesture sleep works as expected! I’m curious though, how is it that gestures work at all without the defines being included in my config file? (I deleted those lines before you reminded me about gesture sleep, and never put them back in) They must be built in to the OS, I’m assuming? Which begs the question, how many other defines do I not need to include in my config since OS6.7?
They are not built in, I’ll need to see your config.
Here is the top half:
#define NUM_BLADES 2
#define VOLUME 1800
#define CLASH_THRESHOLD_G 4.5
#define IDLE_OFF_TIME 5 * 60 * 1000
#define FETT263_MULTI_PHASE
#define FETT263_MAX_CLASH 16
//#define FETT263_SAVE_CHOREOGRAPHY
This is going to hold your previous gesture settings. So you’ll need to use Edit Control settings or remove gestures.ini from your SD.
ok, now I understand. Thank you for your help!
