Can't flash Proffieboard
Hi all! Would love some help if possible. I’m getting an error message.
c:/users/user/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/…/lib/gcc/arm-none-eabi/9.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe:C:\Users\User\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\3.6\variants\STM32L452RE-ProffieboardV3/linker_scripts/STM32L452RE_FLASH.ld:224: warning: memory region `SRAM2’ not declared
c:/users/user/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/…/lib/gcc/arm-none-eabi/9.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: warning: changing start of section .bss by 24 bytes
Sketch uses 228352 bytes (44%) of program storage space. Maximum is 507904 bytes.
The current directory is invalid.
Failed uploading: uploading error: exit status 255
And keep failing on flashing Proffieboard, actually succeed it last night, but now I can’t do it anymore. Could someone take a look at my config?
Thank you!
Could you post the full error messages along with your config to look at?
Post your config as follows:
[paste config here]
error messages are like this
c:/users/user/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe:C:\Users\User\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\3.6\variants\STM32L452RE-ProffieboardV3/linker_scripts/STM32L452RE_FLASH.ld:224: warning: memory region `SRAM2' not declared
c:/users/user/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .bss by 24 bytes
s3config_v3 config:
// ProffieOS7 Config File
#define NUM_BLADES 2
#define VOLUME 1300
#define CLASH_THRESHOLD_G 4.5
#define AUDIO_CLASH_SUPPRESSION_LEVEL 5
#define KILL_OLD_PLAYERS
#define FILTER_ORDER 8
#define BLADE_DETECT_PIN 6
#define SAVE_PRESET
#define FETT263_ENABLE_SPIN_MODE
#define FETT263_BM_CLASH_DETECT 8
#define FETT263_FORCE_PUSH
#define FETT263_TWIST_ON
#define FETT263_DISABLE_MULTI_BLAST
#define FETT263_DISABLE_MULTI_BLAST_TOGGLE
#include "../props/saber_sabertrio_buttons.h"
//#include "../props/saber_fett263_buttons.h"
Preset blade[] = {
{ "19-EX-TFA;common", "tracks/track_19.wav",
  OS7.14 v2.242p
  Base Style: Hyper Responsive Rotoscope (Sequels)
  Base Color: BaseColorArg (0)
  Ignition Effect: Dual Mode Wipe (Up = Fast) [Color: IgnitionColorArg]
  PowerUp Effect: Power Flash [Color: Rgb<0,40,255>]
  Lockup Effect:
[Color: LockupColorArg]
Lightning Block Effect:
[Color: LBColorArg]
Drag Effect:
[Color: DragColorArg]
Melt Effect:
[Color: StabColorArg]
Blast Effect: Responsive Blast Wave (Sound Based) [Color: BlastColorArg]
Clash Effect: Responsive Clash [Color: ClashColorArg]
  StylePtr<Layers<
    Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<14000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-4000>,Int<-400>>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<300>>,TrInstant>,Rgb<0,40,255>,TrFade<1000>>,EFFECT_IGNITION>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<WavLen<>,Int<100>,Int<400>>,Int<100>,Scale<WavLen<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Mult<IgnitionTime<300>,Int<16384>>,IgnitionTime<300>>>,TrWipeInX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>>>(),
StylePtr(),
"EX TFA"
       WS281XBladePtr<1, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin1> >(),
      CONFIGARRAY(blade)
s3config_v3_CC config:
#define NUM_BLADES 3
#define VOLUME 1300
#define SAVE_PRESET
Preset blade[] = {
  OS7.14 v2.242p
  Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
  StylePtr<Layers<
  /* copyright Fett263 Rotoscope (Crystal Chamber) OS7 Style
  OS7.14 v2.242p
  Off Behavior: Fast Pulse Off-On [Color: BaseColorArg]
  PowerUp Effect: Power Surge (Unstable V1) [Color: BaseColorArg]
0: crystalDragMulti0Shape - Begin: Wipe In - Style: Intensity Sparking Drag - End: Wipe Out
Melt Effect:
0: crystalMeltMulti0Shape - Begin: Wipe In - Style: Intensity Melt - End: Wipe Out
Blast Effect: Full Blade Blast Fade [Color: BaseColorArg]
Clash Effect: Flash on Clash (Full Blade) [Color: ClashColorArg]
Battery Level: Full Blade (Green to Red)
  StylePtr<Layers<
   Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<14000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-4000>,Int<-400>>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>,TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Saw<Int<100>>,Gradient<RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>,RotateColorsX<Int<-4000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>,RotateColorsX<Int<-8000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RotateColorsX<Saw<Int<100>>,Gradient<RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>,RotateColorsX<Int<-4000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>,RotateColorsX<Int<-8000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>>>>,Black>,BrownNoiseFlicker<RotateColorsX<Saw<Int<100>>,Gradient<RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>,RotateColorsX<Int<-4000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>,RotateColorsX<Int<-8000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>>>,Mix<Int<7710>,Black,RotateColorsX<Saw<Int<100>>,Gradient<RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>,RotateColorsX<Int<-4000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>,RotateColorsX<Int<-8000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>>>>,200>,RandomPerLEDFlicker<Mix<Int<16384>,Black,RotateColorsX<Saw<Int<100>>,Gradient<RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>,RotateColorsX<Int<-4000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>,RotateColorsX<Int<-8000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>>>>,Mix<Int<7710>,Black,RotateColorsX<Saw<Int<100>>,Gradient<RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>,RotateColorsX<Int<-4000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>,RotateColorsX<Int<-8000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>>>>>>,TrFade<1200>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RotateColorsX<Saw<Int<100>>,Gradient<RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>,RotateColorsX<Int<-4000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>,RotateColorsX<Int<-8000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>>>,TrFade<300>>,EFFECT_BLAST>,TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFade<300>>,EFFECT_CLASH>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrInstant,TrInstant,Pulsing<Black,RotateColorsX<Saw<Int<10>>,Gradient<RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>,RotateColorsX<Int<-4000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>,RotateColorsX<Int<-8000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>>>,2000>>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,Mix<BatteryLevel,Red,Green>,TrFade<300>>,EFFECT_BATTERY_LEVEL>>>(),
  /* copyright Fett263 Rotoscope (Accent LED / PCB) OS7 Style
  OS7.14 v2.242p
Melt Effect:
Blast Effect: Full Blade Blast Fade [Color: BlastColorArg]
  StylePtr<Layers<
    Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<14000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-4000>,Int<-400>>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>,TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Saw<Int<100>>,Gradient<RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>,RotateColorsX<Int<-4000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>,RotateColorsX<Int<-8000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RotateColorsX<Saw<Int<100>>,Gradient<RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>,RotateColorsX<Int<-4000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>,RotateColorsX<Int<-8000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>>>>,Black>,BrownNoiseFlicker<RotateColorsX<Saw<Int<100>>,Gradient<RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>,RotateColorsX<Int<-4000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>,RotateColorsX<Int<-8000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>>>,Mix<Int<7710>,Black,RotateColorsX<Saw<Int<100>>,Gradient<RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>,RotateColorsX<Int<-4000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>,RotateColorsX<Int<-8000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>>>>,200>,RandomPerLEDFlicker<Mix<Int<16384>,Black,RotateColorsX<Saw<Int<100>>,Gradient<RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>,RotateColorsX<Int<-4000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>,RotateColorsX<Int<-8000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>>>>,Mix<Int<7710>,Black,RotateColorsX<Saw<Int<100>>,Gradient<RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>,RotateColorsX<Int<-4000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>,RotateColorsX<Int<-8000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>>>>>>,TrFade<1200>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,TrFade<300>>,EFFECT_BLAST>,TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFade<300>>,EFFECT_CLASH>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrInstant,TrInstant,Pulsing<Black,RotateColorsX<Saw<Int<10>>,Gradient<RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>,RotateColorsX<Int<-4000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>,RotateColorsX<Int<-8000>,RgbArg<BASE_COLOR_ARG,Rgb<0,10,255>>>>>,2000>>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,Mix<BatteryLevel,Red,Green>,TrFade<300>>,EFFECT_BATTERY_LEVEL>>>(),
    "Ex TFA"
  { 0,
    SubBlade(1, 132, WS281XBladePtr<133, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >()),
    SubBlade(0,0, NULL),
    CONFIGARRAY(blade)
The config does have issues (which I’ve not yet delved into proper).
However the error The current directory is invalid. means your problem is completely separate from anything config-related.
Did you extract/unzip the ProffieOS folder? Is the ProffieOS folder actually on your computer’s drive?
oh…maybe I unzipped it, I shouldn’t have done that right?
these files came with my saber and I copied the entire thing
This is an unusual error.
It could be some anti-virus software interferring.
Another possibility might be that the arduino installation path has some characters in it that it doesn’t like. This could for instance happen if your login name has international characters in it, or even spaces. Although in the error message, it looks like your login name is “user” which is also a bit weird I suppose.
hmmm
I’ll try to change my user name.
I don’t have any anti-virus software active btw so that’s not the issue I assume.
What version of arduino do you have?
