i triple checked
#define NUM_BUTTONS 1
#define VOLUME 1550
#define CLASH_THRESHOLD_G 3.0
#define ENABLE_SERIAL
#define BC_THRUST_ON
#define BC_TWIST_ON
#define BC_TWIST_OFF
#define BC_FORCE_PUSH
#define FEMALE_TALKIE_VOICE
#define VOLUME_MENU_CYCLE
#define SPEAK_BLADE_ID
#include "../props/saber_BC_buttons.h"
{ "apacolypse;common", "tracks/TFA_Battle.wav",
StylePtr<Layers<
Mix<SmoothStep<Scale<SwingSpeed<400>,Int<6000>,Int<24000>>,Int<10000>>,Mix<Sin<Int<30>>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,Red>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,0,0>>,RotateColorsX<Variation,Rgb<60,0,0>>>,300>,RotateColorsX<Variation,Rgb<30,0,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,25,0>>,RotateColorsX<Variation,Rgb<60,15,0>>>,300>,RotateColorsX<Variation,Rgb<30,2,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>>,HumpFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<125,0,0>>,40>>,
//Swing responsive humpflicker/rotating red/orange unstable base, unstable takes over the blade the harder you swing
//HumpFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>,50>,
//Alternate plain humpflicker
AlphaL<AlphaL<AudioFlickerL<RotateColorsX<Variation,Rgb16<65535,8729,0>>>,SwingSpeed<350>>,SmoothStep<Scale<SwingSpeed<450>,Int<29000>,Int<9500>>,Int<16000>>>,
//Responsive edge audioflicker swing - starts at the tip and takes over the blade the harder you swing
LockupTrL<Layers<
AlphaL<AudioFlickerL<Rgb<255,150,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
AlphaL<Moccasin,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<500>>,TrConcat<TrInstant,White,TrFade<600>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,25,0>>,RotateColorsX<Variation,Rgb<60,15,0>>>,300>,RotateColorsX<Variation,Rgb<30,2,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,TrFade<50>,RotateColorsX<Variation,Rgb16<65535,8729,0>>,TrFade<525>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,25,0>>,RotateColorsX<Variation,Rgb<60,15,0>>>,300>,RotateColorsX<Variation,Rgb<30,2,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,TrFade<50>,RotateColorsX<Variation,Rgb16<35913,7294,0>>,TrFade<250>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,25,0>>,RotateColorsX<Variation,Rgb<60,15,0>>>,300>,RotateColorsX<Variation,Rgb<30,2,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,TrFade<100>,RotateColorsX<Variation,Rgb16<20393,1818,0>>,TrBoing<950,3>>,SaberBase::LOCKUP_NORMAL>,
//Responsive lockup with unstable cooldown
//AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrJoinR<TrWipe<100>,TrWipeIn<100>>,White,TrFade<3000>>,SaberBase::LOCKUP_NORMAL>,
//Alternate normal endlock effect
//Responsive lightning block
ResponsiveStabL<RotateColorsX<Variation,Orange>>,
//Responsive stab
//ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
//Alternate responsive blast
ResponsiveClashL<TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
//Responsive Clash
//ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
//Alternate white clash
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Orange>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<70,25,5>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RotateColorsX<Variation,Rgb<75,20,5>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<155,25,0>>,RotateColorsX<Variation,Rgb<65,15,0>>>>,TrFade<2500>,Stripes<3000,-2250,RotateColorsX<Variation,DarkOrange>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<195,15,0>>,RotateColorsX<Variation,Rgb<50,15,0>>>,BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RotateColorsX<Variation,Rgb<85,15,0>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<155,25,0>>,RotateColorsX<Variation,Rgb<95,15,0>>>>,TrFade<1000>,Stripes<3000,-1500,RotateColorsX<Variation,Rgb16<65535,8729,0>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<195,10,0>>,RotateColorsX<Variation,Rgb<55,5,0>>>,BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RotateColorsX<Variation,Rgb<185,10,0>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<255,13,0>>,RotateColorsX<Variation,Rgb<105,3,0>>>>,TrFade<2500>>,EFFECT_IGNITION>,
//Unstable ignition
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<255,75,0>>,40>,TrFade<500>>,EFFECT_RETRACTION>,
//Humpflicker retraction
//Drag
//Responsive melt
InOutTrL<TrWipeSparkTip<White,175,250>,TrColorCycle<500>>,
//Spark tip ignition, cycle down retraction
TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<White,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<500>,Int<5500>>,Int<-4000>>>,TrFade<1100>>,EFFECT_RETRACTION>,
//White flicker retraction effect
TransitionEffectL<TrConcat<TrInstant,AlphaL<White,Bump<Int<0>,Int<10000>>>,TrFade<1600>,AlphaL<RotateColorsX<Variation,Orange>,Bump<Int<0>,Int<8000>>>,TrFade<1400>,AlphaL<RotateColorsX<Variation,Red>,Bump<Int<0>,Int<6000>>>,TrFade<1000>>,EFFECT_RETRACTION>,
//Emitter cool off retraction effect
TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Red>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb16<14386,0,0>>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Red>,RotateColorsX<Int<4000>,RotateColorsX<Variation,Red>>>,DarkOrange,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-1000>,Int<25000>>,Int<-4000>>>,TrDelay<6500>>,EFFECT_PREON>,
//Noise responsive preon
TransitionEffectL<TrConcat<TrDelay<3000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Red>,Int<115>,Int<400>,Int<250>,Int<0>>>,TrDelay<1000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Red>,Int<215>,Int<300>,Int<395>,Int<0>>>,TrDelay<1500>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Red>,Int<345>,Int<200>,Int<500>,Int<0>>>,TrDelay<1500>,AlphaL<RotateColorsX<Variation,Red>,Bump<Int<0>,Int<6000>>>,TrBoing<500,2>>,EFFECT_PREON>,
//Charge up, wave out preon
TransitionEffectL<TrConcat<TrFade<1500>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Red>,10>,Bump<Int<0>,Int<4000>>>,TrFade<2000>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Orange>,15>,Bump<Int<0>,Int<5000>>>,TrFade<2500>,AlphaL<HumpFlickerL<White,20>,Bump<Int<0>,Int<6000>>>,TrBoing<500,2>>,EFFECT_PREON>
//Emitter heat up preon
{ "crispity;common", "tracks/Prism.wav",
StylePtr<Layers<
StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,Red>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb16<11805,0,1587>>,RotateColorsX<Variation,Rgb<60,0,0>>>,300>,RotateColorsX<Variation,Rgb<80,0,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,
//Unstable red/pink
TransitionEffectL<TrConcat<TrFade<200>,AlphaL<RotateColorsX<Variation,DeepPink>,SwingSpeed<400>>,TrDelay<30000>,AlphaL<RotateColorsX<Variation,DeepPink>,SwingSpeed<400>>,TrFade<800>>,EFFECT_FORCE>,
//Force effect, temporarily allows color change based on swing speed
AlphaL<AudioFlickerL<RotateColorsX<Variation,DeepPink>>,SwingSpeed<400>>,
//Swing effect, audioflicker, Deep Pink connects the tip and emitter when swinging
LockupTrL<Layers<
AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrWaveX<TransitionEffect<NavajoWhite,Rgb<255,225,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>>>,SaberBase::LOCKUP_NORMAL>,
//Responsive lockup
AlphaL<RotateColorsX<Variation,DeepPink>,SmoothStep<Scale<SlowNoise<Int<2500>>,Int<1500>,Int<4500>>,Int<-6000>>>,
//Sparking emitter flare
ResponsiveStabL<Orange>,
//Responsive stab
//Responsive clash
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Rgb<255,150,150>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<60,0,0>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,DeepPink>,RotateColorsX<Variation,Rgb<60,0,0>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,0,0>>,RotateColorsX<Variation,Rgb<60,0,0>>>>,TrFade<1200>>,EFFECT_IGNITION>,
//Unstable ignition effect
AlphaL<RotateColorsX<Variation,DeepPink>,SmoothStep<Scale<SlowNoise<Int<2500>>,Int<28000>,Int<33000>>,Int<10000>>>,
//Sparking tip flare
//Drag
//Responsive melt
InOutTrL<TrWipeSparkTip<White,100>,TrColorCycle<1065>>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Sin<Scale<Trigger<EFFECT_RETRACTION,Int<3000>,Int<1000>,Int<500>>,Int<70>,Int<550>>>,RotateColorsX<Variation,DeepPink>,RotateColorsX<Variation,Rgb16<65535,0,2716>>>,Bump<Scale<Trigger<EFFECT_PREON,Int<3000>,Int<1000>,Int<500>>,Int<41000>,Int<32768>>>>,TrDelay<3000>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,DeepPink>,Bump<Int<0>,Int<4000>>>,TrFade<520>>,TrWaveX<RotateColorsX<Variation,DeepPink>,Int<520>,Int<550>,Int<520>,Int<0>>>,AlphaL<Black,Int<0>>,TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,Rgb16<65535,0,2716>>,Bump<Int<0>,Int<4000>>>,TrFade<420>>,TrWaveX<RotateColorsX<Variation,Rgb16<65535,0,2716>>,Int<420>,Int<450>,Int<420>,Int<0>>>,AlphaL<Black,Int<0>>,TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,DeepPink>,Bump<Int<0>,Int<4000>>>,TrFade<340>>,TrWaveX<RotateColorsX<Variation,DeepPink>,Int<340>,Int<430>,Int<340>,Int<0>>>,AlphaL<Black,Int<0>>,TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,Rgb16<65535,0,2716>>,Bump<Int<0>,Int<4000>>>,TrFade<300>>,TrWaveX<RotateColorsX<Variation,Rgb16<65535,0,2716>>,Int<300>,Int<400>,Int<300>,Int<0>>>,AlphaL<Black,Int<0>>,TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,DeepPink>,Bump<Int<0>,Int<4000>>>,TrFade<240>>,TrWaveX<RotateColorsX<Variation,DeepPink>,Int<240>,Int<380>,Int<240>,Int<0>>>,AlphaL<Black,Int<0>>,TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,Rgb16<65535,0,2716>>,Bump<Int<0>,Int<4000>>>,TrFade<210>>,TrWaveX<RotateColorsX<Variation,Rgb16<65535,0,2716>>,Int<210>,Int<360>,Int<210>,Int<0>>>,AlphaL<Black,Int<0>>,TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,DeepPink>,Bump<Int<0>,Int<4000>>>,TrFade<190>>,TrWaveX<RotateColorsX<Variation,DeepPink>,Int<190>,Int<340>,Int<190>,Int<0>>>,AlphaL<Black,Int<0>>,TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,Rgb16<65535,0,2716>>,Bump<Int<0>,Int<4000>>>,TrFade<170>>,TrWaveX<RotateColorsX<Variation,Rgb16<65535,0,2716>>,Int<170>,Int<320>,Int<170>,Int<0>>>,AlphaL<Black,Int<0>>,TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,DeepPink>,Bump<Int<0>,Int<4000>>>,TrFade<160>>,TrWaveX<RotateColorsX<Variation,DeepPink>,Int<160>,Int<300>,Int<160>,Int<0>>>,AlphaL<Black,Int<0>>,TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,Rgb16<65535,0,2716>>,Bump<Int<0>,Int<4000>>>,TrFade<150>>,TrWaveX<RotateColorsX<Variation,Rgb16<65535,0,2716>>,Int<150>,Int<250>,Int<150>,Int<0>>>,AlphaL<Black,Int<0>>,TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,DeepPink>,Bump<Int<0>,Int<4000>>>,TrFade<130>>,TrWaveX<RotateColorsX<Variation,DeepPink>,Int<130>,Int<150>,Int<130>,Int<0>>>,AlphaL<Black,Int<0>>,TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,Rgb16<65535,0,2716>>,Bump<Int<0>,Int<4000>>>,TrFade<100>>,TrWaveX<RotateColorsX<Variation,Rgb16<65535,0,2716>>,Int<100>,Int<100>,Int<100>,Int<0>>>,AlphaL<Black,Int<0>>,TrJoin<TrConcat<TrInstant,AlphaL<RotateColorsX<Variation,DeepPink>,Bump<Int<0>,Int<4000>>>,TrFade<70>>,TrWaveX<RotateColorsX<Variation,DeepPink>,Int<70>,Int<500>,Int<70>,Int<0>>>,Black,TrInstant>,EFFECT_PREON>
//Preon effect, HUGE thanks to /u/NoSloppy for this!
{ "decay;common", "tracks/cantina.wav",
StylePtr<Layers<
StripesX<Int<3500>,Int<1200>,Mix<Sin<Int<20>>,RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<75,0,165>>>,Mix<Sin<Int<23>>,RotateColorsX<Variation,Rgb<52,0,125>>,RotateColorsX<Variation,Rgb<84,0,210>>>,Mix<Sin<Int<16>>,RotateColorsX<Variation,Rgb<115,15,220>>,RotateColorsX<Variation,Rgb<95,0,210>>>,Mix<Sin<Int<18>>,RotateColorsX<Variation,Rgb<26,0,42>>,RotateColorsX<Variation,Rgb<60,0,132>>>>,
//Bright purple absorb effect
//StripesX<Int<3500>,Int<1200>,Mix<Sin<Int<20>>,RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<75,0,165>>>,Mix<Sin<Int<23>>,RotateColorsX<Variation,Rgb<52,0,125>>,RotateColorsX<Variation,Rgb<84,0,210>>>,Mix<Sin<Int<16>>,RotateColorsX<Variation,Rgb<115,0,220>>,RotateColorsX<Variation,Rgb<95,0,210>>>,Mix<Sin<Int<18>>,RotateColorsX<Variation,Rgb<26,0,42>>,RotateColorsX<Variation,Rgb<60,0,132>>>>,
//Alternate darker purple absorb effect, color change friendly (for reds and such)
AlphaL<BrownNoiseFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Black,300>,SwingSpeed<400>>,
//Unstable swing
AlphaL<Stripes<1000,2000,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Black>,Black,RotateColorsX<Variation,Rgb<95,0,210>>,Black>,SwingSpeed<500>>,
//Ripple down swing
AlphaL<RotateColorsX<Variation,Rgb<160,60,255>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,
//Bright hard swings
LockupTrL<Layers<
AlphaL<AudioFlickerL<Azure>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrWaveX<White,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>>,StripesX<Int<3500>,Int<1200>,Mix<Sin<Int<20>>,RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<75,0,165>>>,Mix<Sin<Int<23>>,RotateColorsX<Variation,Rgb<52,0,125>>,RotateColorsX<Variation,Rgb<84,0,210>>>,Mix<Sin<Int<16>>,RotateColorsX<Variation,Rgb<115,15,220>>,RotateColorsX<Variation,Rgb<95,0,210>>>,Mix<Sin<Int<18>>,RotateColorsX<Variation,Rgb<26,0,42>>,RotateColorsX<Variation,Rgb<60,0,132>>>>,TrFade<1225>,RotateColorsX<Variation,Rgb<160,60,255>>,TrFade<250>>,SaberBase::LOCKUP_NORMAL>,
//Responsive lockup with reset
AlphaL<RotateColorsX<Variation,Rgb<160,60,255>>,SmoothStep<Scale<SlowNoise<Int<1750>>,Int<1500>,Int<4500>>,Int<-6000>>>,
//AlphaL<RotateColorsX<Variation,Rgb16<45025,0,65535>>,SmoothStep<Scale<SlowNoise<Int<1750>>,Int<1500>,Int<4500>>,Int<-6000>>>,
//Alternate darker sparking emitter flare, color change friendly (for reds and such)
ResponsiveStabL<Red>,
//Responsive stab
ResponsiveClashL<TransitionEffect<Azure,White,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
//Responsive clash
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Rgb<160,60,255>>,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<175,80,255>>,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<1650>>,EFFECT_IGNITION>,
//Bright unstable ignition
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<160,60,255>>,40>,TrFade<1200>>,EFFECT_RETRACTION>,
//Bright HumpFlicker retraction
//Drag
//Responsive melt
InOutTrL<TrWipeInSparkTip<White,200>,TrWipeInSparkTip<White,1125>>,
//Spark tip in ignition and retraction
//InOutTrL<TrWipeSparkTip<White,200>,TrWipeInSparkTip<White,1125>>,
//Alternate spark tip ignition and retraction
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,40>,TrWipe<150>,HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,40>,TrBoing<350,2>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,30>,Bump<Int<0>,Int<5000>>>,TrFade<625>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,30>,Bump<Int<0>,Int<9000>>>,TrFade<625>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,40>,Bump<Int<0>,Int<13000>>>,TrFade<500>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,69>,Bump<Int<0>,Int<18000>>>,TrFade<750>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,69>,Bump<Int<0>,Int<23000>>>,TrFade<750>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,30>,Bump<Int<0>,Int<7000>>>,TrFade<500>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,50>,Bump<Int<0>,Int<19000>>>,TrBoing<1950,9>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrInstant,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<500>,Int<200>,Int<400>,Int<32768>>>,TrDelay<1250>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<300>,Int<300>,Int<32768>>>,TrDelay<1000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<315>,Int<215>,Int<32768>>>,TrDelay<1000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<115>,Int<375>,Int<115>,Int<32768>>>,TrDelay<1250>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<300>,Int<300>,Int<32768>>>,TrDelay<1500>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<100>,Int<400>,Int<100>,Int<32768>>>,TrDelay<1750>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<300>,Int<300>,Int<32768>>>,TrDelay<2000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<315>,Int<215>,Int<32768>>>,TrDelay<450>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<100>,Int<400>,Int<100>,Int<32768>>>,TrDelay<1450>,AlphaL<RotateColorsX<Variation,Rgb<95,0,210>>,Bump<Int<0>,Int<6000>>>,TrBoing<1450,5>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrDelay<4350>,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<5000>,Int<3000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb16<33124,0,65535>>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb16<56306,0,65535>>,RotateColorsX<Variation,Rgb16<21919,0,22863>>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Rgb16<33124,0,65535>>,RotateColorsX<Int<2750>,RotateColorsX<Variation,Rgb16<33124,0,65535>>>>,RotateColorsX<Variation,Rgb16<42753,14386,65535>>,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-5000>,Int<42500>>,Int<-4000>>>,TrDelay<7750>>,EFFECT_PREON>
//Life force drain preon
{ "decimate;common", "tracks/TFA_Battle.wav",
StylePtr<Layers<StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Black,20>,RotateColorsX<Variation,Rgb<4,0,8>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,
Rgb<115,15,220>>,70>,RotateColorsX<Variation,Rgb<42,0,105>>>,RotateColorsX<Variation,Rgb<30,0,66>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,
LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,
SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,
HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,
ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb<160,60,255>>>,
TrFade<1200>>,EFFECT_RETRACTION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,
Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,800>,TrWipeInSparkTip<White,880>,Black>,TransitionEffectL<TrConcat<TrWipe<300>,
AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<21,0,52>>,90>,SmoothStep<Int<2000>,Int<-500>>>,TrDelay<1000>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<21,0,52>>,90>,SmoothStep<Int<2000>,Int<-500>>>,
TrWipe<300>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<42,0,105>>,60>,SmoothStep<Int<4000>,Int<-500>>>,TrDelay<1000>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<42,0,105>>,60>,SmoothStep<Int<4000>,
Int<-500>>>,TrWipe<300>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<64,0,145>>,30>,SmoothStep<Int<6000>,Int<-500>>>,TrDelay<5100>>,EFFECT_PREON>>>()},
{ "deadlink;common", "tracks/TFA_Battle.wav",
StylePtr<Layers<
HumpFlicker<RotateColorsX<Variation,Magenta>,RotateColorsX<Variation,Rgb<150,0,150>>,50>,
//Magenta HumpFlicker
AlphaL<Stripes<2500,-3000,RotateColorsX<Variation,DeepPink>,RotateColorsX<Variation,Rgb16<12482,0,18076>>,Pulsing<RotateColorsX<Variation,Rgb<10,0,26>>,Black,800>>,SwingSpeed<350>>,
//Ripple swing effect
//AlphaL<AudioFlickerL<Stripes<2500,-3000,RotateColorsX<Variation,DeepPink>,RotateColorsX<Variation,Rgb16<12482,0,18076>>,Pulsing<RotateColorsX<Variation,Rgb<10,0,26>>,Black,800>>>,SwingSpeed<300>>,
//Alternate audioflicker ripple swing effect
LockupTrL<Layers<
AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrWaveX<White,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>>>,SaberBase::LOCKUP_NORMAL>,
//Responsive lockup
AlphaL<RotateColorsX<Variation,Rgb16<33124,0,65535>>,SmoothStep<Scale<SlowNoise<Int<2500>>,Int<1000>,Int<3500>>,Int<-4000>>>,
//Responsive stab
ResponsiveClashL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
//Responsive clash
TransitionEffectL<TrConcat<TrDelay<875>,Stripes<3000,-3500,RotateColorsX<Variation,Rgb<160,0,255>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<21,0,52>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<160,0,255>>,RotateColorsX<Variation,Rgb<21,0,52>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<42,0,105>>,RotateColorsX<Variation,Rgb<21,0,52>>>>,TrFade<250>,HumpFlicker<RotateColorsX<Variation,Magenta>,RotateColorsX<Variation,Rgb<80,0,80>>,50>,TrFade<400>,Stripes<3000,-3500,RotateColorsX<Variation,DeepPink>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<21,0,52>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<160,0,255>>,RotateColorsX<Variation,Rgb<21,0,52>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<42,0,105>>,RotateColorsX<Variation,Rgb<21,0,52>>>>,TrFade<1500>>,EFFECT_IGNITION>,
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<180,60,255>>,40>,TrFade<2000>>,EFFECT_RETRACTION>,
//Bright HumpFlicker retraction effect
//Drag
//Responsive melt
InOutTrL<TrConcat<TrWipeIn<200>,RandomBlink<30000,RotateColorsX<Variation,Rgb16<65535,13655,65535>>>,TrWipeIn<200>,Mix<SmoothStep<Scale<SlowNoise<Int<30000>>,Int<1000>,Int<6000>>,Int<-3000>>,Black,RotateColorsX<Variation,Rgb16<65535,13655,65535>>>,TrDelay<400>,Mix<SmoothStep<Int<4000>,Int<-3000>>,Black,White>,TrWipe<175>>,TrColorCycle<2000>>,
//Lightning strike ignition, cycle down retraction
StylePtr<Layers<
Mix<SwingSpeed<400>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,Red>,RandomPerLEDFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<60,0,0>>>,300>,RotateColorsX<Variation,Rgb<80,0,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,AudioFlicker<RotateColorsX<Variation,Rgb16<65535,8357,0>>,RotateColorsX<Variation,Rgb16<42307,1982,0>>>>,
//Unstable red with blood orange audioflicker swing effects
AlphaL<Stripes<2500,-3000,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<60,0,0>>,Pulsing<RotateColorsX<Variation,Rgb<30,0,0>>,Black,800>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,
//Hard swings cause red to ripple up the blade
LockupTrL<Layers<
//Responsive lockup
AlphaL<RotateColorsX<Variation,Rgb16<65535,11439,0>>,SmoothStep<Scale<SlowNoise<Int<3000>>,Int<2000>,Int<3500>>,Int<-3000>>>,
//Responsive stab
//Responsive clash
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Rgb16<65535,8357,0>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<60,0,0>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Orange>,RotateColorsX<Variation,Rgb<60,0,0>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,0,0>>,RotateColorsX<Variation,Rgb<60,0,0>>>>,TrFade<1200>>,EFFECT_IGNITION>,
//Unstable fiery ignition effect
//Drag
//Responsive melt
InOutTrL<TrWipeSparkTip<White,250>,TrColorCycle<1450>,Black>,
//,TransitionEffectL<TrConcat<TrFade<100>,AlphaL<Pulsing<Rgb<120,120,165>,Rgb<50,50,80>,500>,Bump<Int<0>,Int<6000>>>,TrBoing<600,9>>,EFFECT_PREON>
//Optional Clickity Preon, I recommend using Analog's preon :) Make sure to leave the comma at the beginning in if you're using the on demand battery level
{ "rotoscope;common", "tracks/TFA_Battle.wav",
StylePtr<Layers<ColorSelect<IntArg<STYLE_OPTION_ARG,0>,TrInstant,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>>,RandomFlicker<Stripes<10000,-2600,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelay<30000>,TrFade<300>>,Pulsing<RgbArg<SWING_COLOR_ARG,Rgb<180,130,0>>,Mix<Int<16384>,Black,RgbArg<SWING_COLOR_ARG,Rgb<180,130,0>>>,3000>,TrFade<300>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,Stripes<3000,3500,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,0,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,0,255>>>,Black>,BrownNoiseFlicker<RgbArg<RETRACTION_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,0,255>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,0,255>>>>>,TrFade<800>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,0,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,14,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,14,0>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,0,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,0,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,0,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,0,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrJoinR<TrCenterWipeInX<IgnitionTime<400>,Int<16384>>,TrSmoothFadeX<IgnitionTime<400>>>,TrCenterWipeInX<RetractionTime<0>,Int<16384>>,Black>,TransitionEffectL<TrConcat<TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,10>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,15>,SmoothStep<Sum<Int<2000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,20>,SmoothStep<Sum<Int<4000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrBoingX<Mult<Int<8192>,WavLen<EFFECT_PREON>>,3>>,EFFECT_PREON>,TransitionEffectL<TrConcat<TrInstant,AlphaL<White,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Orange,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Red,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-2000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>>,EFFECT_POSTOFF>>>(),
