I tried adding a greyscales font for the first time and once i pasted it into the config i got this error and dont know what to do
In file included from S:\Proffie 7.14\ProffieOS-v7.14\ProffieOS\ProffieOS.ino:620:
S:\Proffie 7.14\ProffieOS-v7.14\ProffieOS\config\mysaber_config.h:121:1: error: cannot convert ‘’ to ‘StyleFactory*’ in initialization
121 | };
Compilation error: cannot convert ‘’ to ‘StyleFactory*’ in initialization
and this is my config file
#define NUM_BLADES 2
#define VOLUME 2000
#define CLASH_THRESHOLD_G 1.0
#define FETT263_SWING_ON_SPEED 300
#define FETT263_TWIST_ON
#define IDLE_OFF_TIME 5 * 60 * 1000
#define FETT263_MULTI_PHASE
// #define KEEP_SAVEFILES_WHEN_PROGRAMMING
// Before using KEEP_SAVEFILES_WHEN_PROGRAMMING be sure to read documentation
// https://github.com/profezzorn/ProffieOS/wiki/ProffieOS6-Keeping-Edits-When-Uploading
#define FETT263_MAX_CLASH 16
//#define FETT263_SAVE_CHOREOGRAPHY
{ "Stitch;common", "Stitch/tracks/Stitchtrack.wav",
{ "Stitched;common", "common/tracks/mercury.wav",
StylePtr<Layers<
//Base Fett263 Ice Blue Audioflicker
AudioFlicker<RotateColorsX<Variation,Rgb16<13655,53737,65535>>,RotateColorsX<Variation,Rgb<45,95,135>>>,
//Ice Blue HumpFlicker Swing Effect
AlphaL<HumpFlicker<RotateColorsX<Variation,Rgb16<33124,58942,65535>>,RotateColorsX<Variation,Rgb<45,95,135>>,90>,SwingSpeed<375>>,
//Fett263 Unstable Charge-Up Ignition
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-1550,Rgb16<33124,58942,65535>,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<Rgb16<33124,58942,65535>,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFadeX<Percentage<WavLen<EFFECT_IGNITION>,35>>,Stripes<3000,-1950,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,300>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFadeX<Percentage<WavLen<EFFECT_IGNITION>,65>>>,EFFECT_IGNITION>,
//HumpFlicker Bright Retraction
TransitionEffectL<TrConcat<TrFadeX<WavLen<EFFECT_RETRACTION>>,HumpFlicker<RotateColorsX<Variation,Rgb16<33124,58942,65535>>,RotateColorsX<Variation,White>,50>,TrInstant>,EFFECT_RETRACTION>,
//Fett263 Responsive Intensity Lockup
TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,White>,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>>>,SaberBase::LOCKUP_NORMAL>,
//Responsive Stab
//Fett263 Real Clash
//Fett263 Intensity Drag
//Fett263 Spark Tip Ignition and Retraction
InOutTrL<TrJoin<TrWipeX<Percentage<WavLen<EFFECT_IGNITION>,8>>,TrSparkX<White,Int<400>,Percentage<WavLen<EFFECT_IGNITION>,8>,Int<0>>>,TrJoin<TrWipeInX<WavLen<EFFECT_RETRACTION>>,TrSparkX<White,Int<400>,WavLen<EFFECT_RETRACTION>,Int<32768>>>>,
//Overload Preon Effect
TransitionEffectL<TrConcat<TrFadeX<Percentage<WavLen<>,15>>,AlphaL<HumpFlickerL<RotateColorsX<Variation,DeepSkyBlue>,10>,Bump<Int<0>,Int<3000>>>,TrFadeX<Percentage<WavLen<>,20>>,AlphaL<HumpFlickerL<RotateColorsX<Variation,DeepSkyBlue>,15>,Bump<Int<0>,Int<5000>>>,TrFadeX<Percentage<WavLen<>,30>>,AlphaL<HumpFlickerL<RotateColorsX<Variation,DeepSkyBlue>,25>,Bump<Int<0>,Int<7000>>>,TrFadeX<Percentage<WavLen<>,35>>>,EFFECT_PREON>,
//Noise Responsive Charge Up Preon
TransitionEffectL<TrConcat<TrDelayX<Percentage<WavLen<EFFECT_PREON>,66>>,AlphaL<BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb16<33124,58942,65535>>,150>,SmoothStep<Scale<NoisySoundLevel,Int<-1500>,Trigger<EFFECT_PREON,WavLen<EFFECT_PREON>,Int<0>,Int<0>>>,Int<-13500>>>,TrDelayX<Percentage<WavLen<EFFECT_PREON>,34>>>,EFFECT_PREON>
>>(), "stitched"},
WS281XBladePtr<1, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin6> >()
, CONFIGARRAY(presets) },
