Can you turn off base lighting on a neopixel blade?
Hey all!
I recently encountered an issue with my Saberforge pixelcore (preassembled hilt insert). I noticed my blade would flicker on harder swings, and I discovered that the recessing pin connector was getting slowly pushed back into the pixelcore. After taking it apart, I realized the connector was held in place with a whole bunch of hot glue. The connector has the recessing pins, as well as LEDs for baselighting, and I believe the LEDs are getting warm enough after extended use that it is melting the hot glue just enough to allow the connector to be pushed back into the hilt. I would like to avoid replacing the glue with pins or screws, as well as permanently mounting it with superglue or something of the sort. Are there any ways to turn off those LEDs, either through config or in blade style codes?
It depends on how they are connected.
They are connected in series, or with their own data line, then yes.
If they are connected in parallel with the main blade, then no.
