More questions on how this works…
My current config file is basically the default config file with an added Tron sound font I bought from JuanSith at Saberfont. :
#define VOLUME 1000
#define CLASH_THRESHOLD_G 1.0
{ "TRON", "tracks/track4.wav",
StyleFirePtr<RED, YELLOW>(), "fire"},
StyleFirePtr<BLUE, CYAN>(), "blue fire"},
{ "SmthGrey", "tracks/venus.wav",
{ "SmthFuzz", "tracks/mars.wav",
{ "RgueCmdr", "tracks/mercury.wav",
{ "TthCrstl", "tracks/uranus.wav",
&style_pov, "POV"},
{ 0, WS281XBladePtr<63, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), CONFIGARRAY(presets) },
If I change the BladeConfig part to:
{ 0, SubBlade(0, 23, WS281XBladePtr<63, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >()),
SubBlade(24, 63, NULL),
How would the presets change? Looking at what @NoSloppy did (and simply copying it for now), would I change the first entry in presets to:
// Tron Disc inner ring
StylePtr<Layers<
Pulsing<RotateColorsX<Variation,Rgb<0,20,140>>,RotateColorsX<Variation,Rgb<20,100,240>>,1500>,
TransitionEffectL<TrConcat<TrInstant,HumpFlicker<White,RotateColorsX<Variation,Rgb<50,220,250>>,50>,TrFade<500>>,EFFECT_CLASH>,
TransitionEffectL<TrConcat<TrInstant,Black,TrDelay<4000>>,EFFECT_BOOT>,
TrInstant, Black,
TrDelay<1000>,Black,
TrInstant, AlphaL<RotateColorsX<Variation,Rgb<20,100,240>>,SmoothStep<Int<4681>,Int<-1>>>,
TrDelay<500>,AlphaL<RotateColorsX<Variation,Rgb<20,100,240>>,SmoothStep<Int<9362>,Int<-1>>>,
TrDelay<500>,AlphaL<RotateColorsX<Variation,Rgb<20,100,240>>,SmoothStep<Int<14043>,Int<-1>>>,
TrDelay<500>,AlphaL<RotateColorsX<Variation,Rgb<20,100,240>>,SmoothStep<Int<18724>,Int<-1>>>,
TrDelay<500>,AlphaL<RotateColorsX<Variation,Rgb<20,100,240>>,SmoothStep<Int<23405>,Int<-1>>>,
TrDelay<500>,AlphaL<RotateColorsX<Variation,Rgb<20,100,240>>,SmoothStep<Int<28086>,Int<-1>>>,
TrDelay<500>, RotateColorsX<Variation,Rgb<20,100,240>>,TrFade<1000>>,EFFECT_BOOT>>>(),
// Outer ring
StylePtr<Layers<
Mix<SwingSpeed<400>,
ColorCycle<Rgb<0,100,140>,0,1,Pulsing<RotateColorsX<Variation,Rgb<0,100,140>>,RotateColorsX<Variation,Rgb<20,200,240>>,500>,70,4000,500>,
HumpFlicker<RotateColorsX<Variation,Rgb<100,220,250>>,RotateColorsX<Variation,Rgb<20,100,140>>,10>>,
TransitionEffectL<TrConcat<TrInstant,HumpFlicker<White,RotateColorsX<Variation,Rgb<100,220,250>>,50>,TrFade<200>>,EFFECT_CLASH>,
TransitionEffectL<TrConcat<TrFade<75>,White,TrDelay<25>,White,TrFade<50>,Stripes<2000,1,Rgb<0,40,80>,Rgb<20,200,240>>,TrDelay<125>,Stripes<2000,-500,Rgb<0,40,80>,Rgb<20,200,240>>,TrFade<100>>,EFFECT_IGNITION>,
InOutTrL<TrInstant,TrFade<500>>>>(), "cyan"},
How does the system map the style to the two different sub-blades?
